09-15-2005, 04:49 AM
#31
Quote: Originally Posted by markbuts3
What is the full path to the exe ??
C:\DestinatorApps\Map Monkey\Plugins\Garo's Extra POI Plugin\Garo's Extra POI Plugin.exe
This is correct but remember to enable it in the MapMonkey configuration!
09-15-2005, 05:03 AM
#32
I actually have it working Garo, that was in response to rickyaswell. My thought was that he may have extracted it into another folder so ending up with...
C:\DestinatorApps\Map Monkey\Plugins\ExtraPOIPlugin\Garo's Extra POI Plugin\Garo's Extra POI Plugin.exe
I just tried that and it stops it from showing in MM config.
Old setup Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
09-15-2005, 05:17 AM
#33
Garonav 1.0 preview
Ok I didn't understand!
However, stay tuned because my new Destinator frontend is almost finished. It is completely skinnable and it has a LOT of features, from a better poi management, full text search for pois and address, analog/digital compass and speedometer, and many more. I did everything keeping an eye on tomtom, since I think it is very comfortable and easier to use than the software we used on our carpc.
Just a couple of screenshot.
If someone wants to betatest, post me in pvt.
09-16-2005, 06:23 AM
#34
MySQL Error
bwhahahaha Look:
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
09-16-2005, 06:35 AM
#35
Quote: Originally Posted by Scouse Monkey
bwhahahaha Look:
09-16-2005, 04:56 PM
#36
The Vauxhall Vectra Project
TMC TMC TMC TMC TMC TMC
Terran
EDIT: Nice
09-21-2005, 05:27 PM
#37
Another POI site for you http://www.poidatabase.com/
And some more info....
Any news on the DLL ? Would love to use this with FD as you know...
Terran
09-22-2005, 03:54 AM
#38
That new frontend looks great! does it also work with the new destinator?
09-22-2005, 05:18 AM
#39
For the moment it is based on the old one since the new SDK still doesn't work... However, It should be very easy to convert it with the new SDK as soon as they release a working copy of it!
10-07-2005, 07:04 AM
#40
Garo - do you have the format of the Destinator DAT file ? I want to use POI Edit with this but the guy who wrote it says he does not have the format to out put.
I know worse case I can use Tomtom files but I would rather have Destinator types so I have the option of using say Freedrive.
If its long and complicated can you give him a shout here - http://www.poiedit.com/contact.htm ?
BIG Thanks
Terran
10-07-2005, 09:05 AM
#41
BIG Thanks
Terran
I don't have specific of the file, I just have some guidelines and then I proceeded with attempts... However, there are more than just one dat format (I found 5 different formats).
I am coding an alternative program different from poiedit, look on my website, so I won't give around my code. However I'll implement the possibility to autoupdate poi files as soon as I finish GaroNav (I will release it in the next days, stay tuned).
10-07-2005, 09:44 AM
#42
Cool just what I need... thats why I was playing with POI edit to DL what I need and update dynamically.
Terran
10-09-2005, 08:05 PM
#43
Does this only show up the POI's when looking in my favourites folder? They only show up there and not in the normal POI folder is that normal?
Cheers,
Richard
10-09-2005, 08:19 PM
#44
Cheers,
Richard
Yep, but lists them in order of distance from your current location.
10-13-2005, 08:28 PM
#45
Theres bug in extraPOI
it is supposed to work with .CSV .DAT files right? but it doesnt. Correct behavior can only be observed with .ov2 files.
I needed to do tests with POI thats easy for human to input. So i typed CSV file by hand... however that didnt work in extraPOI like it was supposed to. So i convert hand written file with your POIconverter to .DAT, that didnt work either. But when i convert same original hand written file with your converter to .ov2 file extraPOI plugin works like it is supposed to!
Problem is that .CSV .DAT file contained POIs appear correctly on favorites (even distance is counted like it should be) but when u look additional information from these favorites, u noticed that lat and lon values both appear to be zero, which also causes that these POIs can't appear on map or u can't ruote to them.
Because of this goddamn bug... i lost quite a bit of time when pondering around it... so i would be really grateful if u could give me info about .DAT (destinator) POI format... I mean if u dont... ill find it out anyhow... u could just save bit of my time....
BTW great software.
| Thread Tools |
| Display Modes |
Linear Mode
