Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > Map Monkey
Old 10-13-2005, 08:37 PM   #46
markbuts3 is on a distinguished road
It works fine with .dat files from http://www.poihandler.com/
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 10-13-2005, 08:52 PM   #47
garo's Avatar
garo is on a distinguished road
Quote: Originally Posted by P3rv3rt B3ar
Theres bug in extraPOI
it is supposed to work with .CSV .DAT files right? but it doesnt. Correct behavior can only be observed with .ov2 files.
I needed to do tests with POI thats easy for human to input. So i typed CSV file by hand... however that didnt work in extraPOI like it was supposed to. So i convert hand written file with your POIconverter to .DAT, that didnt work either. But when i convert same original hand written file with your converter to .ov2 file extraPOI plugin works like it is supposed to!
Problem is that .CSV .DAT file contained POIs appear correctly on favorites (even distance is counted like it should be) but when u look additional information from these favorites, u noticed that lat and lon values both appear to be zero, which also causes that these POIs can't appear on map or u can't ruote to them.
Because of this goddamn bug... i lost quite a bit of time when pondering around it... so i would be really grateful if u could give me info about .DAT (destinator) POI format... I mean if u dont... ill find it out anyhow... u could just save bit of my time....
BTW great software.
It should work but I will be glad to help you. Can you send me one of those CSV?
garo is offline   Reply With Quote
Old 10-13-2005, 09:01 PM   #48
P3rv3rt B3ar's Avatar
P3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud of
Ok, im too lazy to registered the site u mentioned...
But i did repeated test, this time not with file written by me, but .ov2 file downloaded from net (swedish gasoline stations). And if u feed it to garos extraPOI as it is (as .ov2 file) everything works fine, but if u before that use garos POIedit to convert it to .dat file... results are same as in my tests with my own file.
P3rv3rt B3ar is offline   Reply With Quote
Old 10-15-2005, 11:26 AM   #49
garo's Avatar
GaroNav 1.0
As promised, I released my frontend!
Go to the specific thread here:
http://www.mp3car.com/vbulletin/other-cool-stuff/61450-garonav-1-0-beta-1-released-post644395.html
Old 10-15-2005, 04:51 PM   #50
Hmmm looks cool.
Have to give it a try.
Any hope for CF look and feel skin?
Old 10-15-2005, 04:59 PM   #51
garo's Avatar
Hmmm looks cool.
I don't think I will create such I skin but if you or someone want to try... I will be glad to publish on the website
Old 10-19-2005, 05:47 PM   #52
RichardB is on a distinguished road
I have a problem with this on my car pc but it works on my home pc
When MM is starting up it throws an error that ends in 0000135 I think, only option is to press ok to terminate the plugin. Also when I press configure in the plugin section of MM config it doesnt pop another box up. What is going on here? I really want to get it working in the car
Cheers,
Richard
RichardB is offline   Reply With Quote
Old 10-19-2005, 06:01 PM   #53
garo's Avatar
Cheers,
Richard
Install .net framework OR (better choice) use my GaroNav (check my signature).
Old 10-19-2005, 06:16 PM   #54
Where do I get .net from? I am already using a frontend I am used to now, but might give it a try at some point
Old 10-20-2005, 04:48 PM   #55
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
Microsoft / Windows Update...
Terran
ccsnet is offline   Reply With Quote
Old 10-23-2005, 07:43 PM   #56
Ok I downloaded the 1.1 .net framework and now the plugin works yay!
Only problem is that when the plugin is turned on it makes my system run slow. When in MM if I press the next track button it changes but takes about 5 or more seconds to show it in the display box, it aso makes my audio menus in RR very very slow. Anyone else had this problem or could perhaps shed some light on the situation?
cheers,
Richard
Old 10-23-2005, 08:15 PM   #57
garo's Avatar
cheers,
Richard
You may have too many pois. Or try to lower update speed. Or get rid of MM and download GaroNav
Old 10-23-2005, 08:42 PM   #58
Only put McDonalds, Cinemas and supermarkets on. Will have a look at the update speed, see if it makes a difference. May try GaroNav but would assume it should work the same in MM as GaroNav....
Old 10-24-2005, 04:41 AM   #59
garo's Avatar
It is completely different because in GN I update pois just when I need it, so there's no slow down due to the plugin refresh.
Old 11-25-2005, 08:00 AM   #60
peijffertje's Avatar
peijffertje is on a distinguished road
bitmaps
Hi,
I got it to work and I get notified when I aproach POI's but what I dont get are the bitmaps on the map that correspond with the POI's.
I emptied my database with cam's in MM so that I use the cams I import from Tomtom in Garo's plugin only, but the cam's from MM are still displayed on the map. Does that have something to do with it?
I apreciate your help.
peijffertje is offline   Reply With Quote
Problems installing Girlfriend 1.0... gospeed.racer Off Topic 28 10-18-2005 06:17 PM
RELEASE: Garo's Poi Converter 1.0 beta... Please betatest ;) garo FreeDrive 33 10-18-2005 02:38 PM
RELEASE: Garo's Poi Converter 1.0 beta... Please betatest ;) garo Map Monkey 4 08-12-2005 10:51 AM
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Blackwind's keypad plugin v2.0 beta released Blackwind Software & Software Development 14 02-11-2001 04:54 AM
