The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Map Monkey
Thread Tools Search this Thread Display Modes
Old 09-18-2005, 02:28 AM   #1
My Photos: (0)
Map Monkey Problems
Hey guys,
I've been having real problems getting my Leadtek 9537 Bluetooth GPS adaptor running with Map Monkey 1.1.3 and Destinator 3. The device is connected via a Belkin Bluetooth USB adaptor. (And yes I've spent the last 3 hours searching through previous threads trying to find a solution )
I'm using the device inside so I'm not expecting any satellite connectivity, but no matter what COM port I change the device to or what program I use to connect to my bluetooth device, nothing works. The device is picked up fine by windows and installs without a hitch, but for some reason I cant get ANY program to connect to it properly or recieve data. Whenever I try in MapMonkey using the advanced mode it says "GPS isnt found". When I try finding it under the GPS status, it also says not found but when i specify the port and baud rate, it says "comport busy".
Can anyone give me any hints as to how to get this working properly, I'm getting a serious headache from fiddling with it for the last 5 hours.
Any help much appreciated,
Thanks.
{icebox425} is offline   Reply With Quote
Sponsored Links
Old 09-18-2005, 03:06 AM   #2
Mr.Fabio's CarPC Specs
Mr.Fabio's Avatar
Vehicle: Ford Focus C-MAX TDCI
My Photos: (5)
Try to use Hyper Terminal to test the connection, before MapMonkey or any other Gps Sw
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 09-18-2005, 03:32 AM   #3
My Photos: (0)
What should I use hyperterminal to do with my bluetooth device though?
Old 09-18-2005, 08:20 AM   #4
Mr.Fabio's Avatar
My Photos: (5)
I'm guessing the reason it's not working is due to the wrong Com port, wrong baud rate or protocol selected. Get SiRFDemo or some other GPS diagnostic like HyperTerminal app and see if that can connect.
So you can see if you're receiving NMEA messages or SiRF (NMEA will be plain text, SiRF will be binary so you'll just get random chars)
Mr.Fabio
Travla C134
Old 09-19-2005, 06:14 AM   #5
My Photos: (0)
Worth a try: disable Use Advanced GPS Mode (under Adv GPS in Configuration). I had the same problem and it fixed it.
Alister is offline   Reply With Quote
Old 09-24-2005, 06:48 AM   #6
My Photos: (0)
GTXP.DLL needed!
Hello,
my mapmonkey freezes afrer 5-20 seconds with a problem in a gtxp.dll
can somebody tell me where can i download a different version of this file? The link, that was given in this forums is not working.
Thanky You!
balatonair is offline   Reply With Quote
Old 09-24-2005, 01:06 PM   #7
My Photos: (0)
The driver of gps emulate a com port ( try - control panel - system -ha
rdware proprieties - & search this driver)
Simply connect hyperterminal to com port emulate blutoth gps.
Check the driver of gps ,or update this .
bye bye
marco
illo41100 is offline   Reply With Quote
Old 09-25-2005, 07:27 AM   #8
Map Monkey Creator
Ninja Monkey's CarPC Specs
Ninja Monkey's Avatar
Vehicle: Toyota MR2 GT T-Bar & VW Golf GT-TDi
My Photos: (0)
Quote: Originally Posted by balatonair
Hello,
Thanky You!
http://www.mp3car.com/vbulletin/map-monkey/59339-where-download-fixed-gtxp-dll-named-gtxp_beta-dll.html
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 10-07-2005, 12:16 PM   #9
My Photos: (0)
please someone help me.i have post a tread before but noone reply.
i doubleclick mapmonkey's icon to open.....it runs.....busy mouse icon appears....and then nothing.map monkey not opening.
by pressing ctrl+alt+del and task manager showing up i see that map monkey appears as not responing program.
i have made a format to my pc but nothing changes.
HEEEEEEEEEEEEEEEEELP
murdocng is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
CF 2 Beta + Map Monkey 1.3 stevieg Centrafuse 15 08-27-2005 11:42 AM
Rr Gps Port Setting Help For Mappoint And Map Monkey?? wsudu Road Runner 4 08-05-2005 03:43 PM
Copying Map Monkey to new laptop UHF Map Monkey 5 07-12-2005 05:10 AM
Map update problems Dunk FD Bugs 1 07-05-2005 03:30 AM
Anyone using Map Monkey 1.1.3 with Deluo USB GPS? Chita79 Map Monkey 0 02-04-2005 01:06 AM
Sponsored Links
Ad Management by RedTyger
