Does anyone else have this problem with MM and UK D3 maps?
Whenever I get to a roundabout, instead of telling me to "take the second exit" (for example) that darn woman tells me to "turn right, followed by turn left".
It's annoying to say the least and didn't happen when I tried out CF and it's built-in Destinator. I can only assume it's because of the D3 maps.
Any help or advice here would be gratefully received (even if you just tell me "that's the way it is, live with it).
For info, I'm using EnglishUK voices and All visualisations.
My DestinatorVoiceManeuvers.inf file looks like this:
{:Standard Voices Maneuvers:}
LANGUAGE=ENG
// All the fields must be placed in one line. The fields will divided by commas.
// Fields description:
// 1) ::MC The maneuver command is a key word.
// 2) A command is being built from two parts (each part is a key word). The two
// parts will be divided by a ‘*’ sign. The first part will describe the maneuver name
// (TURN_LEFT for example) and the second part will describe the distance
// (THIRD_DISTANCE for example).
// 3) For future use, (‘0’ will be entered).
// 4) to N) The words from which the sentence is built. Each word (or words) between two
// commas must refer to a wav files with the same name which exists in the same
// folder as the information file, (if a file or a command for that matter will not be
// found silent mode will be activated).
// The max value of ‘N’ will be ‘13’, (will allow a ten words sentence).
// N+1) The maneuver textual description, (will be written between quotation marks -
// commas are possible).
// FIRST_DISTANCE - three kilometers / two miles.
// SECOND_DISTANCE - five hundred yards/meters.
// THIRD_DISTANCE - two hundred yards/meters.
// FOURTH_DISTANCE - thirty meters, no distance will be specified.
::MC,TURN_LEFT*FIRST_DISTANCE,0,0,t_l;3*2;UNITS,"L eft turn 3/2 miles / three kilometers"
//::MC,TURN_LEFT*SECOND_DISTANCE,0,0,t_l;500;UNITS," Left turn five hundred yards/meters"
::MC,TURN_LEFT*THIRD_DISTANCE,0,0,t_l;200;UNITS,"L eft turn two hundred yards/meters"
::MC,TURN_LEFT*FOURTH_DISTANCE,0,0,t_l,"Turn left"
::MC,TURN_RIGHT*FIRST_DISTANCE,0,0,t_r;3*2;UNITS," Right turn 3/2 miles/kilometers"
//::MC,TURN_RIGHT*SECOND_DISTANCE,0,0,t_r;500;UNITS, "Right turn five hundred yards/meters"
::MC,TURN_RIGHT*THIRD_DISTANCE,0,0,t_r;200;UNITS," Right turn two hundred yards/meters"
::MC,TURN_RIGHT*FOURTH_DISTANCE,0,0,t_r,"Turn right"
::MC,KEEP_LEFT*FIRST_DISTANCE,0,0,k_l;3*2;UNITS,"K eep left 3/2 miles/kilometers"
//::MC,KEEP_LEFT*SECOND_DISTANCE,0,0,k_l;500;UNITS," Keep left five hundred yards/meters"
::MC,KEEP_LEFT*THIRD_DISTANCE,0,0,k_l;200;UNITS,"K eep left two hundred yards/meters"
::MC,KEEP_LEFT*FOURTH_DISTANCE,0,0,k_l,"Keep left"
::MC,KEEP_RIGHT*FIRST_DISTANCE,0,0,k_r;3*2;UNITS," Keep right 3/2 miles/kilometers"
//::MC,KEEP_RIGHT*SECOND_DISTANCE,0,0,k_r;500;UNITS, "Keep right five hundred yards/meters"
::MC,KEEP_RIGHT*THIRD_DISTANCE,0,0,k_r;200;UNITS," Keep right two hundred yards/meters"
::MC,KEEP_RIGHT*FOURTH_DISTANCE,0,0,k_r,"Keep right"
::MC,EXIT_LEFT*FIRST_DISTANCE,0,0,e_l;3*2;UNITS,"K eep left 3/2 miles/kilometers"
//::MC,EXIT_LEFT*SECOND_DISTANCE,0,0,e_l;500;UNITS," Keep left five hundred yards/meters"
::MC,EXIT_LEFT*THIRD_DISTANCE,0,0,e_l;200;UNITS,"K eep left two hundred yards/meters"
::MC,EXIT_LEFT*FOURTH_DISTANCE,0,0,e_l,"Keep left"
::MC,EXIT_RIGHT*FIRST_DISTANCE,0,0,e_r;3*2;UNITS," Keep right 3/2 miles/kilometers"
//::MC,EXIT_RIGHT*SECOND_DISTANCE,0,0,e_r;500;UNITS, "Keep right five hundred yards/meters"
::MC,EXIT_RIGHT*THIRD_DISTANCE,0,0,e_r;200;UNITS," Keep right two hundred yards/meters"
::MC,EXIT_RIGHT*FOURTH_DISTANCE,0,0,e_r,"Keep right"
::MC,U_TURN*FIRST_DISTANCE,0,0,u_t;3*2;UNITS,"U turn three 3/2 miles/kilometers"
//::MC,U_TURN*SECOND_DISTANCE,0,0,u_t;500;UNITS,"U turn five hundred yards/meters"
::MC,U_TURN*THIRD_DISTANCE,0,0,u_t;200;UNITS,"U turn two hundred yards/meters"
::MC,U_TURN*FOURTH_DISTANCE,0,0,u_t,"U turn"
::MC,ROUND_ABOUT*FIRST_DISTANCE,0,0,circle;EXIT_NU MBER;exit;3;UNITS,"Take round about xxxx exit 3/2 miles/kilometers"
//::MC,ROUND_ABOUT*SECOND_DISTANCE,0,0,circle;EXIT_N UMBER;exit;500;UNITS,"Take round about xxxx exit five hundred yards/meters"
::MC,ROUND_ABOUT*THIRD_DISTANCE,0,0,circle;EXIT_NU MBER;exit;200;UNITS,"Take round about xxxx exit two hundred yards/meters"
::MC,ROUND_ABOUT*FOURTH_DISTANCE,0,0,circle;EXIT_N UMBER;exit,"Take round about xxxx exit"
::MC,DESTINATION*FIRST_DISTANCE,0,0,app_destinatio n;3*2;UNITS,"Approacing destination in 3/2 miles/kilometers"
//::MC,DESTINATION*SECOND_DISTANCE,0,0,app_destinati on;500;UNITS,"Approacing destination in five hundred yards/meters"
::MC,DESTINATION*THIRD_DISTANCE,0,0,app_destinatio n;200;UNITS,"Approacing destination in two hundred yards/meters"
::MC,DESTINATION*FOURTH_DISTANCE,0,0,destination," You Have Arrived"
// 1) ::MW The multiple word command is a key word.
// parts will be divided by a ‘*’ sign. The first part will describe the command name
// RED_LIGHT_CAMERA for example) and the second part will describe the distance type
// DISTANCE_TYPE_800 for example).
// 4) For future use, (‘0’ will be entered).
// 5) to N) The words from which the sentence is built. Each word (or words) between two
// N+1) The command textual description, (will be written between quotation marks -
::MW,POI_ALERT_1*DISTANCE_TYPE_1000,0,0,141,1000;; UNITS,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_800,0,0,141,800;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_600,0,0,141,600;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_400,0,0,141,400;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_100,0,0,141,100;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_1*DISTANCE_TYPE_50,0,0,141,50;UNITS ,"Poi Alert 1"
::MW,POI_ALERT_2*DISTANCE_TYPE_1000,0,0,141,1000;; UNITS,"Poi Alert 1"
::MW,POI_ALERT_2*DISTANCE_TYPE_800,0,0,141,800;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_2*DISTANCE_TYPE_600,0,0,141,600;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_2*DISTANCE_TYPE_400,0,0,141,400;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_2*DISTANCE_TYPE_100,0,0,141,100;UNI TS,"Poi Alert 1"
::MW,POI_ALERT_2*DISTANCE_TYPE_50,0,0,141,50;UNITS ,"Poi Alert 1"
// 1) ::SW The single word is a key word.
// 2) The single word definition.
// 4) The relevant single word. The word must refer to a wav file with the same name which exists
// in the same folder as the information file, (if a file or a needed word for that matter will not be
// 5) The maneuver textual description, (will be written between quotation marks -
// Spacify:
// 1) First maneuver followed by second maneuver, (1).
// 2) Second maneuver followed by first maneuver, (2).
// No distance will be specified.
::SW,FOLLOWED_BY,0,0,(1);followed_by,"...Followed by..."
// Will be described by the letters combination 'UNITS'.
::SW,METERS,0,0,meters,"meters"
::SW,KILOMETERS,0,0,kmeters,"kilometers"
::SW,YARDS,0,0,yards,"yards"
::SW,MILES,0,0,miles,"miles"
// Will be described by the letters combination 'EXIT_NUMBER'.
::SW,FIRST,0,0,first,"first"
::SW,SECOND,0,0,second,"second"
::SW,THIRD,0,0,third,"third"
::SW,FOURTH,0,0,fourth,"fourth"
::SW,FIFTH,0,0,fifth,"fifth"
::SW,SIXTH,0,0,sixth,"sixth"
::SW,SEVENTH,0,0,seventh,"seventh"
::SW,EIGHTH,0,0,eighth,"eighth"
::SW,NINTH,0,0,ninth,"ninth"
::SW,TENTH,0,0,tenth,"tenth"
::SW,TURN_LEFT,0,0,t_l,"Turn left"
::SW,TURN_RIGHT,0,0,t_r,"Turn right"
::SW,KEEP_LEFT,0,0,k_l,"Keep left"
::SW,KEEP_RIGHT,0,0,k_r,"Keep right"
::SW,EXIT_LEFT,0,0,e_l,"Exit to the left"
::SW,EXIT_RIGHT,0,0,e_r,"Exit to the right"
::SW,U_TURN,0,0,u_t,"U turn"
::SW,ROUND_ABOUT,0,0,circle,"round about"
::SW,YOU_ARE_OVER_THE_SPEED_LIMIT,0,0,yaotsl,"You are over the speed limit"
::SW,ROUTE_RECALCULATION,0,0,yhltcr,"Route recalculation"
::SW,GPS_SIGNAL_TOO_LOW,0,0,signallow,"GPS signal too low"
::SW,GPS_NOT_FOUND,0,0,gpsnotfound,"GPS not found"
::SW,START_NAVIGATION,0,0,startnavigation,"Start navigation"
::SW,REACHED_DESTINATION,0,0,destination,"You have arrived to your destination"
::SW,TMC_MESSAGE_RECIEVED,0,0,132,"TMC Alert"
