07-30-2007, 06:55 AM
#1
PC Navigator 7 - Europe
I have opened this thread so that we can effectively close the long running "PC navigator 6" thread.
link to company website:
http://directions.ltd.uk/laptop-navigation/
In short-
PC navigator 7 - Europe standard edition now supports being windowed, however you need to pass it some parameters, DOPEHEAD has written an executable to do this
Quote: Originally Posted by _dopehead_
I just made my little application look for a settings.ini in the same dir as the application is in. The settings ini should contain this :
Xpos
Ypos
Xsize
Ysize
on the first four lines of the file, so a setting would ex. be :
0
50
800
550
Which would start pcnav 50 pixels down, and with the size of 800x550, fits on the destinator_gps.skin with a topbar of 50 pixels.
If no settings.ini is found it will use the exact parameters above instead.
Then you can just run startpcnav.exe in your button code in RR.
Link : http://www.csaforum.dk/pcnav.zip
the other intergration option that is still lacking is the ability to mute winamp when the satnav speaks. a solution to this was suggested by SERFIO
Quote: Originally Posted by Serfio
On the whole I have been impressed so far. It has not yet taken me on a obscure route, or got me lost.
one small niggle is when running in a small window the icons/ fonts are not always resized, so for instance when you do a search for your GPS com port, the details of the com port are printed below the bottom of the screen. I will report this in today and see if we get a patch.
07-30-2007, 07:06 AM
#2
ok, 1st thing we need to find is whether we need the professional or the standard,do both versions allow resizing to be embedded in rr?
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
07-30-2007, 07:15 AM
#3
i have the standard, and this allows me to resize (as stated above  )
dopehead has the proffesional which also does
AFAIK - the difference between the standard and the proffesional is that the proffesional allows you to write your own active X front end, but as no doubt dopehead will elaborate on, this is a long arduous task.
07-30-2007, 07:20 AM
#4
oh yes, for it to work in RR, using the BMV2 skin, i needed to select the GPS product as external, and add a clear window (a clip) with the same size window as you are running pcnav. this allows you to see the programme through the skin.
07-30-2007, 07:34 AM
#5
Quote: Originally Posted by wilgartw
i have the standard, and this allows me to resize.
excellent, that saves me 50 bucks!
CarPuter Progress:
07-30-2007, 09:43 AM
#6
they've just come back to me, and actually when i use it in standalone mode everything looks ok, it is only when i run it through RR does in cut the bottom off. I will investigate more tonight (when i'm not at work)
07-30-2007, 10:09 AM
#7
Also, it would be nice to know if there are more keyboard shortcuts than the one i found in the new version 7 (sse old thread), maybe ogradka who initially put up the link for the patch could tell us ?
Oh, and this is the patch for Pcnav7 to get windowed support. http://static.mapfactor.com/files/pc...h-7_1_13-1.exe
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
07-30-2007, 10:16 AM
#8
When embedding in RR what functions have you managed to work with buttons (if any) like the ones you get in FreeDrive so far?
CarPuter Progress:
07-30-2007, 11:15 AM
#9
just gone through the old thread and cannot find this. what post number is it? I will then ask them. i seem to be getting responses within the hour at the moment.
07-30-2007, 01:02 PM
#10
07-30-2007, 03:49 PM
#11
The keycodes i have found are located in the file C:\Program Files\Navigator7\PC_Navigator\config\tyrael\defaul t_settings.xml
They are not really that much use, everything in there can be done in the GUI on the first screen i believe. But maybe some more keycode action are available, we should ask directions.
---- These are the ones that are in there. ---------
<virtualKeyBinding>
<vkCode>38</vkCode>
<action>MoveUp</action>
</virtualKeyBinding>
<virtualKeyBinding>
<vkCode>40</vkCode>
<action>MoveDown</action>
<virtualKeyBinding>
<vkCode>39</vkCode>
<action>MoveRight</action>
<virtualKeyBinding>
<vkCode>37</vkCode>
<action>MoveLeft</action>
<!-- skyway -->
<virtualKeyBinding>
<vkCode>33</vkCode>
<action>ZoomIn</action>
<virtualKeyBinding>
<vkCode>34</vkCode>
<action>ZoomOut</action>
<!-- gvox -->
<virtualKeyBinding>
<vkCode>195</vkCode>
<virtualKeyBinding>
<vkCode>196</vkCode>
<!-- magic370 -->
<virtualKeyBinding>
<vkCode>130</vkCode>
<action>Minimize</action>
<virtualKeyBinding>
<vkCode>133</vkCode>
<action>AddFavourite</action>
07-31-2007, 06:32 AM
#12
what kind of things are you after? i use a touchscreen, so have no use for keyboard shortcuts.
07-31-2007, 07:15 AM
#13
So do i, but some of the features would be nice to have available without having to go into the menu system, like 2D/3D view.
07-31-2007, 03:49 PM
#14
OK Guys, What am I doing wrong?
Navigator 7 Europe (Standard) arrived and was installed yesterday. My front end is iCT. I'm using Dopehead's little programme and installed it in the same directory as Nav 7. I have to run any navigation software as an external programme. No problems with that.
When I open the navigation window I now get Dopehead's programme and starting at X0/Y50 where it should, but the screen stays blank apart from a line at the bottom giving me my altitude and speed.
If I now close that window I see the map behind it which has now moved up slightly so that I can see the part of the front end behind that at top and bottom.
Any ideas ? Thanks
08-01-2007, 03:27 AM
#15
what happens when you run it outside iCT?
| Thread Tools |
| Display Modes |
Linear Mode
