Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Media Engine > ME Archive
Old 06-23-2003, 10:59 PM   #1
EBJUSTIN
Red face Setting up DSB-R100 radio w/ mediaengine
Can someone tell me how to install the DSB-R100 so it will work with media engine? I have installed it to the default directory c:\radio but mediaengine does not recognize it. I've tried installing the DSB-R100 in the mediaengine directory but with no success
Please help..
Eric
EBJUSTIN is offline
Advertisement Sponsored links
Old 06-24-2003, 12:18 AM   #2
az1324
if the radio works with the included software on your computer it should work with media engine.
az1324 is offline
Old 06-24-2003, 12:32 AM   #3
VENDOR - SpatialMinds
millec's Avatar
millec
That is not entirely true. If you are running WindowsXP the default install uses a dll with a different signature than the one that MediaEngine uses and it works. The trick is to:
1. Go to DLink's support site and download the latest XP drivers.
2. Get the latest version of MediaEngine. A few older versions had a couple of bugs that have been fixed.
millec is offline
Old 06-24-2003, 02:02 AM   #4
gargoyle
D-links website says they dont have drivers or support for Win XP. Maybe you can send me a link?
gargoyle is offline
Old 06-24-2003, 02:06 AM   #5
gargoyle
http://flesko.cz/radiator.htm
Those say they work with WinXP.....Anyone tried it out?
gargoyle is offline
Old 06-26-2003, 11:13 PM   #6
EBJUSTIN
The DSB-R100 is installed on my computer and works fine except for the volume adjust but mediaengine still does not sync up with it.
My Celica Carputer Install
EBJUSTIN is offline
Old 06-27-2003, 12:47 AM   #7
az1324
Make sure that radio.dll in your Media Engine directory is registered.
az1324 is offline
Old 06-27-2003, 02:00 PM   #8
EBJUSTIN
What do you mean by registering? Do I need to find a register key? I know that that the radio.dll is installed but I'm not sure if it is registered.
EBJUSTIN is offline
Old 06-29-2003, 11:04 PM   #9
EBJUSTIN
I just did a clean install of Win2000. The Dlink USB radio works fine but still cannot be controlled with Mediaengine. The only thing Mediaengine will control is the radio volume and that is only if I open the radio before running Mediaengine. Any guesses why the radio still isn't working?
EBJUSTIN is offline
Old 07-01-2003, 01:19 AM   #10
millec's Avatar
millec
I got mine from DLINK Australia. The DLINK US website does not support this product.
Here they are...
http://www.dlink.com.au/tech/drivers...sb/dsbr100.htm
millec is offline
Old 07-02-2003, 05:59 AM   #11
Red Daniel's Avatar
Red Daniel
Resolve Problem??
Hi, guys!!! This link explains what u do for use the DLink radio!!
D-Link USB radio DSB-R100 is reported by Phil to be working perfectly - it is necessary to:
download drivers for GemTek FMRadio 21 USB (23 kB) on
uninstall original software
connect radio to another USB port to force Windows to detect it again
then, when Windows recognize the new hardware on the different port, just install usbradio.sys driver
select GemTek FMRadio 21 USB in Radiator options
I hope this help u!!!
LINK: flesko.cz/radiator.htm#DLINK%20USB
P.S. Excuse me for my bad bad english!!
STATUS 0%||||||||||||||-------100%
Power: Inverter 300 Watt + PS 148 Watt ATX
MOBO: EPIA M
CPU: C3 933 MHz
RAM: 512 MB
HDD: 40 GB
CD-ROM Drive 32x
GPS: ????
ADD-ON: ????
Red Daniel is offline
Old 07-03-2003, 12:01 AM   #12
EBJUSTIN
Red Daniel
That resolved the problem...Thank you. The radio is fully functional with mediaengine on my machine.
EBJUSTIN is offline
Old 07-03-2003, 03:17 AM   #13
Red Daniel's Avatar
Red Daniel
I'm merry to help u!!!!
Not at all!!
MOBO: EPIA M
CPU: C3 933 MHz
RAM: 512 MB
HDD: 40 GB
CD-ROM Drive 32x
GPS: ????
ADD-ON: ????
Old 07-03-2003, 12:33 PM   #14
Bbrian
How is the reception of this DLink in the car? I see it has an antenna but how will reception be affected since it has to be mounted inside the car? Can it be integrated into the factory antenna?
Shuttle xPC w/ Athlon 2400+
512MB ddr266
GeForce4 128MB agp video
250GB WD SE
USB2.0 DVD/CD-RW slim drive
7" Xenarc TSV touchscreen
PAC Audio AUX input module
Opus 150W PS
iGuidance usb GPS
RF keyboard/mouse
Mobile Media Center
Bbrian is offline
Old 07-03-2003, 06:42 PM   #15
az1324
Quote:
Yes reception is drastically better with the radio connected to the factory antenna.
az1324 is offline
