Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Media Engine > ME Archive
Old 10-28-2003, 07:06 PM   #31
Super Moderator
hijinks21's Avatar
mut, i'll talk to you on IRC tomorrow. I thought i had that fixed, it might not be in the latest build.. not sure
'98 Explorer Sport
80% done
hijinks21 is offline
Old 10-28-2003, 09:20 PM   #32
vcbb5's Avatar
can someone post screen shots?
My Mazda 3s
My Mazda 3s on Car Domain
[||||||||||||||||||--] (90%)
vcbb5 is offline
Old 10-29-2003, 03:42 AM   #33
Raw Wave
Confused's Avatar
I had that too when I tested it out, i had the 0.7 downloaded about a month ago
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline
Old 10-31-2003, 06:25 AM   #34
Is this going to be implemented into the Media Engine code base or as an external app? It looks nice. There are some things I noticed.
-UI control needs some work. Or maybe I just need to map Tab on my remote.
-Window size should adjust for resolution.
It looks really promising though and I can't wait to see the finished product.
1BlackHatch is offline
Old 10-31-2003, 06:35 AM   #35
Super Moderator
hijinks21's Avatar
1BlackHatch, thats not how it'll look. I was just seeing if i could get it working. It'll be fully in ME, so you can switch from gps to mp3 and if you are viewing a movie or in mp3 mode it'll prompt you that your turn is coming up.. thats the plan anyway
'98 Explorer Sport
80% done
Old 10-31-2003, 12:44 PM   #36
Ok. That is exactly what I am hoping for. I am running a composite LCD so mappoint is pretty illegible at best. I can't wait to see it!
Old 11-25-2003, 01:23 AM   #37
once again, i'll ask - is there any update on this?
nodeel is offline
Old 11-25-2003, 09:38 AM   #38
CarComp's Avatar
Yes, I have started work on the MediaEngine GPS section. I haven't gotten a whole lot done yet though, so I can't tell you much about it. Only that it will be totally integrated into MediaEngine and all you need to use it is install mappoint.
Get MediaEngine !!!
Media Engine Download
CarComp is offline
Old 12-01-2003, 12:58 AM   #39
is this going to be as good as say Destinator???
You have me drooling...
nodeel is offline
Old 12-21-2003, 03:04 AM   #40
Has there been any progress on this...like I posted before, the implementation of this has me absolutely chomping at the bit. My Destinator implementation is falling a little flat and below expectations....
nodeel is offline
Old 12-21-2003, 08:12 AM   #41
Super Moderator
hijinks21's Avatar
carcomp is putting it into ME as we are typing this
'98 Explorer Sport
80% done
Old 12-22-2003, 11:24 PM   #42
AWESOME news....i'm so drooling. When can we try it out? What will it require other than MS Map Point?
nodeel is offline
Old 12-23-2003, 07:04 AM   #43
Super Moderator
hijinks21's Avatar
i'm not sure when it'll be ready. Since i built the core I know there needed to be some fine tuning done. The problem with going GPS is you gotta take some time to test your code on the road. So it makes it a bit more time consuming. More so since we are doing real time routing and turn by turn directions.
Most apps that use mappoint you actually have to type in your start location and your destination. With this you just enter your destination and at any time you can hit a button and it'll find where you are and create a route for you. If you get off track you simply hit the button again and it'll re-route for you.
'98 Explorer Sport
80% done
Old 12-26-2003, 09:10 PM   #44
I played with the beta w/Earthmate USB...it takes a lot to get it to work nicely, but I suspect its more of the shoddy Earthmate serial drivers...the virtual port KEEPS dissappearing on me, forcing reboot/reinstall of the virtual com port...any solutions?
nodeel is offline
Old 12-27-2003, 08:53 AM   #45
Super Moderator
hijinks21's Avatar
not a clue.. i have never had a problem with the com port going away.
'98 Explorer Sport
80% done
