10-26-2003, 04:54 PM
#16
Registered User
OK, just a quick update for anyone watching this.
I did a recalibrate of the touchscreen to be on the safe side (full 25 pointer).
Also I changed the way the touch panel worked as a mouse, from click on press (options, click on press, click on release, and normal) to normal. I also disabled the left/right click applet.
I then tried media engine again. Buttons now work as expected.
Works as shell, and as application.
Managed a strange thing though.
Had an album running in MP3. managed to get to the media library, and select a DivX movie.
The movie started. but the MP3 Album also restarted, after pausing to view the library.
Also the screens randonly flicked between music and movie, and then when I clicked the home button, all three screens.
Very weird listening to the soundtrack of Debbie does Dallas, with a Marilyn Manson backing track. Especially as it was cycling between classic porn, and track listings. Like watching one of those late night dutch Satellite TV station music video shows.
4x4 in a turbo stylee.
10-26-2003, 05:32 PM
#17
Select Browse Media, then Build New Playlist. Press Search button. Select any kind of search (artist, title). The OSK appears but you can type only one character. then you can scroll through it but no button work. By pressing Quit button, the program goes back to the Browse Media.
-NicGalla-
custom-made aluminum case | MK2.8+ PSU | EPIA 800 | 256 Mb DDR | 120 Gb 7.2k WD | Wireless Chieftec mouse & keyb | Trust USB Keypad & USB webcam | Majestic TFT 7" 16:9 | WinXP & ME2 | connected to factory head-unit in a PT Cruiser 2.0L
10-27-2003, 05:05 AM
#18
I cannot make the automatic file synchronizer sync OGG files. I have added the OGG extension to the list of supported audio extensions in the 'directories and startup' tab of settings menu. I have also tried making ME sync .ogm and .avi files with no success. In both cases, the extension was on the list of supported file types.
I am running a Win2k Lite install with fully updated versions of ME 2.0, WMP9 and DirectX 9.0b.
512MB RAM
60BG HD (2 NTFS partitions)
900 MHz Pentium M
(Fujitsu Lifebook, P5010D)
A note.
I have been able to make oggmux (*.ogm) files play in ME, by installing the following codecs, and including OGM as a supported video extension.
The OGG Direct Show filters, and a subtitle mixer, available at: http://tobias.everwicked.com/
The proper Video codec (Xvid or Divx)
You cannot change the audio or subtitle tracks however, without mucking about with things outside of ME.
10-27-2003, 07:25 AM
#19
I also have a good one for you!
MediaEngine Version 2.0 Build 2.0.20 - Logfile created on 27-10-2003
27-10-2003 13:07:50 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:07:52 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:07:53 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:07:55 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:07:57 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:07:58 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:00 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:01 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:03 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:05 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:06 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:08 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:09 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:11 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:13 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:14 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:16 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:17 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:19 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:21 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:22 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:24 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:25 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:27 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:29 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:30 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:32 - An error occured in modDB.UpdateDB : : Error number 91
27-10-2003 13:08:39 - An error occured in modDB.UpdateDB : : Error number 91
I don't know what it is.
Something is closing and restarting ME all the time.
I hope you can help me.
Thanks.
10-27-2003, 08:42 AM
#20
Error, while playing mp3's
Updated the .exe today but am still getting an error every now and again, 2 small windows pop up one saying switch to and retry, somehting about application is already in use? does this mean anything to you,
Also when running the VIs, the screen somtimes freezes while playing, so the vis just sitts there but the music still play's, then after a while it will come back.
Another thing, when a track is finished playing the Vis stops and goes back to the playlist screen, rather then just playing the next track and keeping the vis on screen.
Still impressed with it though, I'm sure the little niggles will be ironed out
Ron
www.fsplanes.net NEW site
AMD XP 1800+ / 256mb ram ddr / 2 x 60gig hdd / Asus mobo micro ATX / GF-FX5200 / BU 303 GPS reciever / dlink usb radio
Software:
Window's XP SP1 / USB Radio / Destinator v2 / Mediacar / 3000 mp3's / 30 movies
10-27-2003, 09:40 AM
#21
Media Engine Devoloper/Moderator
Are you running the latest version of the .exes? If so, I need more details about what you were doing when you noticed this.
I actually noticed this problem over the weekend while I was fixing another bug. We're tyring to tackle some other issues and should have another bugfix release ready very soon.
'01 Chevy Xtreme Stepside (pics)
FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
10-27-2003, 08:08 PM
#22
ME2 loops on start.
debug log.
28/10/2003 00:54:33 - db background update initiated
28/10/2003 00:54:33 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
28/10/2003 00:54:34 - db background update initiated
28/10/2003 00:54:34 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
28/10/2003 00:54:36 - db background update initiated
28/10/2003 00:54:36 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
28/10/2003 00:54:37 - db background update initiated
28/10/2003 00:54:37 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
This repeats forever.........
Updated to the latest on mediaengine.org today.
Previously ran fine before this!
Used unregger
Restarted it 4 times to clear the message windows
It starts ok, mediaengine big logo, then main screen, then jumps to loading then back to main screen, over and over.........
Home PC - key/mouse
Xp2400AMD
256mb
Sure its something obvious!
Scott
10-28-2003, 11:53 AM
#23
[QUOTE=phat_bastard]Are you running the latest version of the .exes? If so, I need more details about what you were doing when you noticed this.
here is a pic i took while on the road, it only happens now and again, sorry for the ****e quality, but had to use my phone to take it, as I was driving at the time.
Also when I use Shutdown I get a DLL error on exit, do you know what this is, I will find out the name tommorow, its very quick flash up
Software:
10-30-2003, 03:06 AM
#24
An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path,...
here is the scenario:
1. instaling MediaEngine2.0.20setup.exe
2. exec UnRegger.exe
3. update mediaengine.exe and DB_UPDATE.exe
4. start mediaengine.exe (3 times I think)
5. start mediaengine.exe -> now it starts continiously restarting itself, it's hard to kill it (click settings and then taskmanager end process)
6. again start mediaengine.exe - in the settings dialog I have blinking yellow light -> DB offline
please help ... tell me what to do, if steps 2 and 3 are ommited ... the same problem
/////////////////////////////////debug.log/////////////////////////////////
MediaEngine Version 2.0 Build 2.0.19 - Logfile created on 29.10.2003 ã.
29.10.2003 ã. 21:28:21 - db background rebuild initiated
29.10.2003 ã. 21:28:21 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
29.10.2003 ã. 21:28:23 - db background update initiated
29.10.2003 ã. 21:28:23 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
29.10.2003 ã. 21:28:25 - db background update initiated
29.10.2003 ã. 21:28:25 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
29.10.2003 ã. 21:28:26 - db background update initiated
29.10.2003 ã. 21:28:26 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
29.10.2003 ã. 21:28:28 - db background update initiated
29.10.2003 ã. 21:28:28 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
29.10.2003 ã. 21:28:30 - db background update initiated
29.10.2003 ã. 21:28:30 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
10-30-2003, 03:23 AM
#25
As I wrote in an e-mail to phat_bastard With the new updated files the problem that ME2 is restarting all the time is gone! Now it just shuts down :S
This is what my debug.log says.
MediaEngine Version 2.0 Build 2.0.19 - Logfile created on 10/30/2003
10/30/2003 7:09:41 AM - db background update initiated
10/30/2003 7:09:42 AM - An error occured in modDB.UpdateDBMain last_sql= section: 8 : Object variable or With block variable not set : Error number 91
I have updated with the new exe files. 2.0.26 and 1.0.7.
I hope you can find the problem because dispite all the updates the problem isn't solved.
10-30-2003, 12:25 PM
#26
Quote: Originally Posted by phat_bastard
Remember, you paid how much for MediaEngine? We've invested quite a bit in hardware to test with, domain registration fees and numerous other expenses, not to mention the time involved, and we give away the software for free. Is a little patience and understanding so much to ask from you?
I have been working with phat_bastard myself over that period of time. I have found him to be helpful, understanding, and knowledgable. I think that given the circumstances they are dong an outstanding job.
My issue has been resolved totally and I am looking forward to 2.X releases and using the software on my system.
I encourage everyone to be as detailed as possible when providing information about problems they are having, which may include taking notes. We all want the same thing. The developers ware doign great in my book. JMO-Carl
10-31-2003, 02:26 AM
#27
Hi!
First: Great Software!!! I´m happy that you write these kind of Software....
But:
I´ve got a VIA Epia V8000 with Win98SE on it and a 7" Xenarc Touchscreen.
When I´m running a resolution of 800x600 and 16 or 32Bit then the writing of the
lists are scrambled, they are overlaying when I scroll down the list or select another file to play. The same is in the "Browse Media" list.
On 1024x768 there´s everything allright. The same in 800x600 and 256Colors.
I´m using the default skin. WMP9, DX9.0b installed.
And I´ve another Problem:
When I press the shutdown button, ME is trying to shutdown, but in the background a loginmask appears with the username im logged on.
Then ME hangs, and cant shutdown.
Is it a bug or a settingfailure?
Greetz
Tom
10-31-2003, 04:42 AM
#28
Quote: Originally Posted by GTC
dob - what is the " ã " character I see through your post? In the SQL Statement, the reference to '07.3.1999 ã. 10:54:34' probably isn't valid as the expected field is probably a date/time.
The developers may want to cast that value to a date/time before entering it into the database, or better yet format it as a string using explicit formatting (as the cast "cDate" would probably be locale specific and may not play happy with Access ... ) ...
dob - If you want a quick fix, you might try changing your settings (I'm guess locale settings, but not completely sure) to remove this character ...
Because the log is strewn with "[Microsoft][ODBC Microsoft Access Driver]" it is likely that some version of MDAC (or at least the Access drivers) are present.
cheers,
GTC
ã is г.
this is year in bulgarian
I'll try this with tha locale setting .. 10x
10-31-2003, 10:09 AM
#29
Quote: Originally Posted by frodobaggins
You should also update, current ME version is 2.0.20 as in the sticky
Actually it's .27 currently, I neglected to update the sticky.
Also there was some mis-communication between myself and CarComp that caused 2.0.19 to be written to the logfile with the actual program version being 2.0.26 [dont ask].
Also, any problems we've seen with mediaengine not referencing the support .exes seemed to have been resolved by running unregger.exe and then re-launching the app until it gets everything re-registered.
10-31-2003, 01:27 PM
#30
Can you fix the onscreen keyboard to support
å, ä, ö i mean å, ä, ö
| Thread Tools |
| Display Modes |
Linear Mode
