The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Media Engine > ME Archive
Thread Tools Display Modes
Old 10-27-2003, 02:37 AM   #1
fluffy2097's Avatar
Vehicle: 93 Honda Accord SE
My Photos: (0)
Partial support for OGG playback in ME 2.0
I have been able to get OGG playing in a limited fashion in ME by installing the OGGDS filter package. http://tobias.everwicked.com/oggds.htm
These codecs are the only way that I know of to allow playback of OGG files in WMP9. The first time you play an OGG file in WMP9 you get a Yes/No dialog box stating, "The file you are attempting to play has an extension that does not match the file format. Playing the file may result in unexpected behavior. Do you want to try to play the file?" Along with a, "Do not ask me this question again" checkbox. By checking the check box and clicking yes, Windows Media Player 9 will play OGG files.
When attempting to play OGG files in ME the same dialog box pops up. Clicking yes once makes the box disappear then reappear. Clicking yes on the second box will start playback of the file. The process must be repeated each time playback of an OGG file is started. Checking the "Do not ask me this question again" checkbox has no effect on this.
I am running win2k lite with DX9 and WMP9 installed and fully patched.
I am also using the latest versions of the mediaengine.exe and DB_UPDATE.exe
In addition I also have installed the OGGDS filter package. http://tobias.everwicked.com/oggds.htm
I'm posting this as a seperate topic because it's not quite a bug, and not quite a feature request either. If the Dev crew cares to poke at making it work, that would be cool.
EDIT
I forgot to mention that I have added the OGG extension to the "Supported Audio Extensions" box in the Directories & Startup tab of the Settings menu.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
fluffy2097 is offline
Sponsored Links
Old 10-28-2003, 12:57 AM   #2
fluffy2097's Avatar
My Photos: (0)
Upon poking at this more, I have found that OGG files refuse to play without popping up the dialog box every time in WMP9 as well as ME. Does anyone else have this problem with WMP9?
Old 10-28-2003, 01:20 AM   #3
9 Fingered Administrator
Lesbian
frodobaggins's Avatar
Vehicle: 1998 Ranger/1991 Sunbird
My Photos: (0)
after I chose yes and do not ask (in wmp9) it worked fine
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline
Old 10-28-2003, 02:20 AM   #4
fluffy2097's Avatar
My Photos: (0)
Oi. Must be a problem with my OS then. What OS are you using? I'm running an install of 2k lite.
Old 10-28-2003, 02:30 AM   #5
Lesbian
My Photos: (0)
xp pro
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 10-28-2003, 11:53 AM   #6
fluffy2097's Avatar
My Photos: (0)
Ok. It looks like I've narrowed the problem down to the Windows Media Hotfix KB828026 "Update for Windows Media Player Script Commands"
If anyone else is having problems like mine, uninstall WMP9 and reinstall, then don't update it.
If it does work for you. Don't update WMP9.
Anyone able to confirm my findings?
Old 11-02-2003, 08:35 AM   #7
mutilator's Avatar
Vehicle: 2003 MINI Cooper S Schnitzer
My Photos: (0)
same problem as you with the popup wil try to reinstall later
Car: 2005 Mini Cooper Convertable
Status: startin from scratch. [|--------]
Hardware:
EPIA 1000M
Dlink USB radio
7" In dash touchscreen
Harmain GPS unit
RF remote
ODB2
....IBUS comin soon
Running: media engine
mutilator is offline
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
