01-06-2004, 08:20 PM
#1
Error #91
I am patched to the latest as of today, and here's the error I'm getting. ME is restarting many times..
Quote:
1/6/2004 6:13:46 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:13:48 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:13:50 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:13:52 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:13:54 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:13:56 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:13:58 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:00 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:02 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:07 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:09 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:11 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:14 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:16 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:35 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:37 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:39 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:41 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:43 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:46 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:48 PM - An error occured in modDB.UpdateDB : : Error number 91
1/6/2004 6:14:50 PM - An error occured in modDB.UpdateDB : : Error number 91
What would that error be?
1993 BMW 325is - 15.2sec
01-06-2004, 08:36 PM
#2
number 91.
sorry
Car: 2005 Mini Cooper Convertable
Status: startin from scratch. [|--------]
Hardware:
EPIA 1000M
Dlink USB radio
7" In dash touchscreen
Harmain GPS unit
RF remote
ODB2
....IBUS comin soon
Running: media engine
01-06-2004, 11:11 PM
#3
Quote: Originally Posted by mutilator
number 91.
sorry
Well, what is error #91!?
01-07-2004, 02:23 AM
#4
Hmmm... For a start, what OS are you running?
01-07-2004, 03:01 AM
#5
I'm sorry, and you are....?
I would suggest running the unregger and then restarting me
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
01-07-2004, 03:13 PM
#6
Error number 91 indicates that an object variable or with block variable is not set. This translates to some sort of variable was being set to a type of object, only the object didn't want to be created (so to speak) and there was an error.
I suggest you check your option to install MDAC in the installer.
Then install m.e
01-07-2004, 03:53 PM
#7
I'll try reinstalling ME, but I did install the MDAC..
burnout.no - WinXP
01-08-2004, 03:34 AM
#8
burnout.no - WinXP
Did you play with xplite?
01-08-2004, 03:42 AM
#9
Yes, with XPLite a lot  I reinstalled ME and its working now!! I also messed w/ XPLite some more.. Not all sure WHAT I did to fix it.. Any one have ideas?  What options need to be set in XPLite to make it work?
01-08-2004, 03:56 AM
#10
Thought so.. Basically, it's nice to install me first.. About the things that can be removed with xplite.. Go ahead and try - see for yourself.. Different systems may require different components..  Just keep a backup!
01-08-2004, 04:41 AM
#11
lol ok.. I'm trying some stuff now, might work
01-08-2004, 04:49 AM
#12
Yeah, just fire it up!  Good luck!
01-08-2004, 05:47 AM
#13
Hey it did work! Streamline and working!
01-08-2004, 05:54 AM
#14
Nice.. How much did you throw out?  I also think it should work fine to remove IE, but only AFTER the installation of M.E..
01-08-2004, 08:47 PM
#15
SMKFree
i just got this same error and behavior from what used to be a zero problem instalation.
It happend right after i tried to change the location of my media to a different folder. The database started to update then for some reason ME trid to go back to the main screen and just started looping.
Maybe this can help track down the bug.
| Thread Tools |
| Display Modes |
Linear Mode
