The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Media Engine
Thread Tools Display Modes
Old 04-25-2004, 02:12 PM   #1
Vehicle: 1999 Chevy Venture
My Photos: (0)
DVD problem in MediaEngine
Running the latest version and it works great - can't wait for GPS and XM support when it's ready.
I'm having a problem playing DVDs however as I can browse the DVD and select the title and it then goes to a pink screen with a menu - the menu then disappears and it goes full screen - however the DVD nevr plays and it stays with a pink screen. I can get the menu back and exit etc so it just seems that the DVD player is not running.
I have Ulead DVD Player installed and this plays the DVD perfectly ok although it's not integrated with ME of course.
Any ideas on what I might have missed?
Steve
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
SteveC is offline   Reply With Quote
Sponsored Links
Old 04-25-2004, 04:00 PM   #2
My Photos: (0)
Re: DVD problem in MediaEngine
Forgive me if I'm wrong (complete newbie), but I think it's because you're trying to play a DVD that is from another region to the region your DVD-ROM drive is setup to play (I'm having the same issue).
If you minimize MediaEngine you may find there is a dialog box prompting for the region selection.
Hope this helps.
Chitty
www.leapoflogic.co.uk
chitty is offline   Reply With Quote
Old 04-26-2004, 12:49 AM   #3
My Photos: (0)
I don't think that's the problem as the DVD plays perfectly ok outside of ME using the Ulead Power DVD. I am thinking that maybe ME is incompatible with the Ulead DVD player so I am looking for another DVD player to see if that fixes the problem.
Thanks for the suggestion anyway
Steve
Old 04-26-2004, 04:53 PM   #4
My Photos: (0)
I'm having the same problem in that a Region 1 DVD plays fine through Cyberlink PowerDVD (via http://www.dvdidle.com), but doesn't play through MediaEngine.
Chitty
Old 04-27-2004, 11:54 AM   #5
My Photos: (0)
That's very weird then because I just downloaded PowerDVD and installed it and it works just fine. I wonder if there is a specific order that these need to be installed in eg WinDVD folowed by Media Engine.
I do have the same problem with the XM PCR software installed as an External App - it plays perfectly ok outside of ME but when I launch it from within ME it goes to the Desktop, loads the opening page of XMPCR and then just hangs. If I close it from the taskbar it tells me that XMPCR is not responding and after forcing a close it goes back into ME correctly - very weird.
Steve
Old 04-30-2004, 01:57 PM   #6
mobileh1's Avatar
Vehicle: Hummer H1
My Photos: (0)
Fix for pink screen
I had the exact same problem when trying DVD playback. I used the control panel to remove PowerDVD, then rebooted, reinstalled PowerDVD, ran ME215 and the DVD now works
Hope this helps...
.//Daren
EpiaM10000/C134/Liliput 7"/Slotloading DVD/512MB/80GB/Hummer H1
mobileh1 is offline   Reply With Quote
Old 05-11-2004, 03:37 PM   #7
My Photos: (0)
I have the same problem, I only get a pink screen.. even after reinstalling Power DVD.
I tried different players as well but didn't work either
Royco is offline   Reply With Quote
Old 05-16-2004, 05:01 AM   #8
My Photos: (0)
Reinstalling windows didn't help either
Old 06-08-2004, 10:49 AM   #9
My Photos: (0)
I had done as you said , but nothing change, what can I do now ?
tks.
Hope this helps...
.//Daren
Thinboy is offline   Reply With Quote
Old 06-08-2004, 09:11 PM   #10
My Photos: (0)
Guy, I had take a pack from ms update, and installed DirectX9 ?! After reboot pc, it's okey.
So, if you care , just try it , maybe just dirctx9 take effect
Sponsored Links
Old 06-17-2004, 09:34 AM   #11
swifty8083's Avatar
Vehicle: 2004 Nissan Sentra SE-R Spec V
My Photos: (0)
I treid all of the above techniques, none have worked, my screen will remain black with no DVD (audio or video) playing, any more advice?
Dell Laptop PIII,500Mhz,640MBRAM,20GBHD(Sits under the driver seat)7.2" Widescreen,Earthmate USB GPS,FM,DVD Drive,I use a docking station, and it stand-by+shut down automatically after I take the key out(DC power stops). Audio into 9 Speakers + Sub
swifty8083 is offline   Reply With Quote
Old 06-17-2004, 09:49 AM   #12
swifty8083's Avatar
My Photos: (0)
I installed the k-lite codec pack and the problem was solved, it will go to a pink screen for a hot sec than it will start playing It has a small pink line across the top of the screen about 1mm thick but it is above the video (in the black section not the movie).
http://www.k-litecodecpack.com/
Old 07-20-2004, 04:15 PM   #13
My Photos: (0)
I have a fresh install of XP going. I downloaded k-lite basic and installed all the components minus MP3.
I then insert a DVD, load a fresh install of mediaplayer (installed before k-lite) and try to play a DVD.
black screen.
whats going on?
WhiteRabbit is offline   Reply With Quote
Old 07-20-2004, 06:01 PM   #14
brooksware2000's Avatar
My Photos: (0)
black screen.
whats going on?
Make sure you check the option to install the DVD codec. It is unchecked by default
Check out my hopefully useful site...
www.hobbybotics.com
It's still under design but it is functional
brooksware2000 is offline   Reply With Quote
Old 07-21-2004, 02:53 AM   #15
My Photos: (0)
strange, now I get the pink screen and audio, but still no video.
it actually retains the old paused screen shot of the past vid, doesnt start the video portion of the DVD
Sponsored Links
vB code is On
Trackbacks are Off
Trouble playing dvd switch General Hardware Discussion 4 01-08-2005 05:42 AM
Slim DVD Problem ddt General Hardware Discussion 2 04-14-2003 10:59 AM
DVD Playback on LCD problem jup General Hardware Discussion 1 02-20-2002 08:47 AM
DVD Burners who?, what? how? sleddog4 General Hardware Discussion 6 12-01-2000 05:51 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
