The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Media Engine
Thread Tools Display Modes
Old 03-21-2006, 01:21 PM   #1
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
Embedded GPS problem
I know i'm supposed to submit the bug report on the website, but there is no way to attach pictures there.
This is what happens when I try to launch either map monkey or free drive from ME, if I set them up as external applications they work just fine. I have tested this both on my machine in the car and my machine on my desk and they both do it.
I know it's hard to see but it says memory problem,maybe program already launched. Which I know is not true.
And this one says INI Data are not saved
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Sponsored Links
Old 04-21-2006, 01:12 PM   #2
My Photos: (0)
Has an answer been found for this?
I am having the same problem with launching map monkey from within Media Engine. I assumed there was no response because the question may have been answered many times. However I have searched this forum for days and still have not found the answer. I understand that other media consoles use a laucher, but I have not seen anything like that for Media Engine.
How is Map Monkey launched using the GPS button so that it runs embedded?
jflygare is offline   Reply With Quote
Old 04-22-2006, 03:36 PM   #3
MySQL Error
jcdillin's Avatar
My Photos: (3)
Yeah I havent heard anything on it, for now i've just been using iguidance to get around it
肚子笑痛了
S60 Install
Old 04-22-2006, 11:21 PM   #4
sebberry's CarPC Specs
My Photos: (4)
Submit a bug report on the media engine site and link to this thread...
sebberry is offline   Reply With Quote
Old 04-23-2006, 06:43 PM   #5
My Photos: (0)
Seems to be ok
For some reason (typical) as soon as I posted the problem, it went away. I think what may have been happening is that a mapmonkey instance was still running in memory after I had tried to shut it down, then open it in Media Engine. I have had to manually kill the mapmonkey process on several occations. I think I have run into every issue in the book, but still very impressed with both products. Keep up the good work.
Old 04-24-2006, 08:33 AM   #6
Tim Lake's CarPC Specs
Tim Lake's Avatar
Vehicle: 1999 Nissan Primera
My Photos: (0)
You need to make sure you aren't quitting MapMonkey from it's own menu and you aren't launching it outside Media Engine either.
Basically ME launches it the first time you use it (after a reboot) and then when you 'close' it using the ME button, it actually stays loaded in memory. If it is opened outside ME first, it will try to run it and you'll get the memory error.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
Tim Lake is offline   Reply With Quote
Old 04-24-2006, 10:09 AM   #7
My Photos: (0)
Thank you
Good advice. Thank you.
Old 04-24-2006, 02:55 PM   #8
MySQL Error
jcdillin's Avatar
My Photos: (3)
Yeah mine is still doing it and I get an error after every time I come out of hibernation.
肚子笑痛了
S60 Install
Old 04-24-2006, 05:07 PM   #9
My Photos: (0)
This may help
http://www.mp3car.com/vbulletin/show...bscript+SELECT
perhaps you can leverage this vbscript to kill mapmonkey.exe after resuming from hibernate.
Sponsored Links
vB code is On
Trackbacks are Off
Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ? ccsnet GPS 91 11-07-2006 04:47 PM
problem connecting a GPS Touran Map Monkey 0 02-25-2006 11:08 AM
GPS not found problem ThEScReW GPS 5 12-20-2004 05:39 PM
com port problem for gps in D3 FireDJ Map Monkey 1 12-10-2004 04:58 AM
Start embedded gps? Maņana PowerVoice 5 11-28-2004 07:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
