multiple skins based on time
Well we all know Red is hard at work on the new MI version ..
Does anyone out there use multiple skins.like a skin for daytime and a skin for night time? if so did you automate it.. IF you did what method did you use.
i use hibernate with gammacontrol 2.14. GC can launch
a file at day time and at night time.So this is how i use multiple skins.
I made two batch files that will change the config.ini (in my case line10 column#j skinpath=)
to skinpath=default for my daytime skin
and skinpath=navy for my nightime skin..
i then added it to an autoit script. and used the 2.exes in gamma control
anyone else have anyother ideas let me know.
the exe consists of
ProcessClose( "mi.exe" )
Run("C:\Program Files\Mobile Impact\night.bat") or day.bat
Run("C:\Program Files\Mobile Impact\mi.exe")
Exit
the bat file is
@echo off > night
set /a skintype=0
for /f "tokens=*" %%J in (config.ini) do call :subr1 %%J
copy night config.ini > nul
del night
goto :eof
:subr1
set /a skintype+=1
if %skintype% EQU 10 echo SKINPATH=Navy >> night
if not %skintype% EQU 10 echo %* >> night
goto :eof
im not the greatest coder this is very basic.
the equ 10 is line 10 and the %%j is right after the equal sign in skinpath= in the config.ini
make sure if you use this you count the lines in your config ini
Red love the program now i need to get my phoco license..
and figure out why my home pc asf files are searchable but carpc isnt.
using Mobile Impact,Waiting on the rds radio.
