Quote: Originally Posted by
Zeroaviation
Ok, heres the problem i decided to make a video, this is a fresh Xp install full version with SP2 and Windows media player 9. it does this anytime, not when i just go to the media thing, i can load the program and let it sit for' about 8 sec and it does this. The dialog box says "Run-Time Error 424 object required. here is the video i made of the problem
http://www.youtube.com/watch?v=DjoWEuHO2cU
Wow that is cool.. Well not cool for you.. but cool for us all to try and troubleshoot.
First question you said brand new windows xp install
i noticed when you played that song there was no audio. All I could hear is was you car door dinging is that true?
If so does media player play music outside of MI.
Next question Is this a full install or and nlited or tiny xp
Second question could you send me 1 of those audio files or post it at a upload site.
Also when you reinstalled MI did you get any errors on install.. I got one about not able to write to a dll but a simple google search showed the error in the original MI threads..
Also when you go to device manager does it show any codecs installed.
how about java.. These are just all the things i check on my pc.
I dont think red apps use java but that was a weird error.
are logged in as a admin rights? object expected is normally java script. what version of ie is installed? are all the dlls registered from his software
sorry if i am beating a
here..
the original mi should put these file on your pc i think the new version uses them 2
The exact dll files that is installs are as follows:
vb6stkit.dll -> Visual Basic Setup Toolkit Library
asycfilt.dll - > Microsoft OLE 2.30
comcat.dll - > Microsoft Component Category Manager Library
comdlg32.ocx - > Microsoft Common Dialog Control
dx7vb.dll - > Direct X Control
mscomctl.ocx - > Microsoft Common Control
msvbvm60.dll - > Microsoft Visual Basic virtual machine
olepro32.dll - > Microsoft OLE Property Support
scrrun.dll - > Microsoft Script Runtime and i assume you dowloaded flash and directx 9 or better
Just trying to help.
