Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Mobile Impact
Old 08-08-2007, 02:56 PM   #46
Zeroaviation's Avatar
Zeroaviation is on a distinguished road
ok i will try that as soon as i get home, and let u knwo my results, thanx for the help,
Im a pilot.
I have become a cross control stall.
Zeroaviation is offline   Reply With Quote
Old 08-09-2007, 12:17 PM   #47
Quote: Originally Posted by tn6478 View Post
If you receive a message similar to "Run-time error '424': Object required." it means that the application has not been able to open the Windows File dialog box due to a problem in the Windows registry.
To work around this you need ensure that the common dialog control (comdlg32.ocx) is correctly registered. To do this take the following steps.
1. Click Start and select Run
2. Enter "regsvr32.exe comdlg32.ocx" (without the quotes)
If this does not correct the problem take the following steps.
1. Remove the application which had the problem using the Control Panel utility Add/Remove Programs
2. Reinstall the application
3. Click Start and select Run
4. Enter "regsvr32.exe comdlg32.ocx" (without the quotes)
i tried that just now, and i still recive the Run-time error '424': Object required error, everything works fine untill about 8 sec then it shows that error, any other ideas? once again its a Fresh Xp Full install with sp2, and wm9, flash and directx....
Im a pilot.
Old 08-09-2007, 01:21 PM   #48
tn6478's Avatar
tn6478 is an unknown quantity at this point
something is wrong with your windows. try installing VB install files. that might fix it and update to wmp10
tn6478 is offline   Reply With Quote
Old 08-09-2007, 06:13 PM   #49
gah, that sux, where would i find the VB files? the old version works fine, ill update the wmp tonight adn try again.... Thanx for all your help..
Im a pilot.
Old 08-09-2007, 11:13 PM   #50
tn6478's Avatar
go to rr download section and dl the files
Old 08-11-2007, 02:19 AM   #51
are u talking about RoadRunner download section like here? http://guino.home.insightbb.com/download.html im lost. lol
Im a pilot.
Old 08-12-2007, 06:04 PM   #52
tn6478's Avatar
Hey Red Shuffle isn't working right. Also the program doesn't save to the config files if MI does not exit. Meaning if the computer shut down do to a trigger it does not save setting to config files. Is it the only way it will save is to exit program.
Old 08-13-2007, 11:42 AM   #53
Mobile Impact Creator
reddeath30's Avatar
reddeath30 is on a distinguished road
The program can only respond to an event within the program. If the computer shuts down, there is no way for the program to know that it it happening. The program only saves when you hit one of the buttons in the exit menu. Im also aware of the problem with the shuffle, it works better than previous versions, but it still has some quirks.
Mobile Impact
Highly innovative car computer multimedia/entertainment system software.
http://mobileimpact.biz.tm
reddeath30 is offline   Reply With Quote
Old 08-13-2007, 08:05 PM   #54
suarezpedro's Avatar
suarezpedro is an unknown quantity at this point
Split Screen Button Missing on MI
Nice work reddeath!!
I'm a real fan of your work, and I think that MI really rocks; I mean, RR is very nice, but it's missing the Split Screen feature; which is one of my 'must to have...' (If you don't believe me, ask my kids...)
I hope that you can help me with this one, I can't find how to send a full screen video to the second screen in MI4; in the previous version, you had a 'Split Screen' button on the upper left corner when the video goes full screen, but I'm missing it on the new version.
What am I doing wrong??
suarezpedro is offline   Reply With Quote
Old 08-14-2007, 08:20 AM   #55
tn6478's Avatar
it still there dude i dont know what u are talking about. The split screen feature comes on when you click GPS or when you are in the music module there is a button for split screen.
Old 08-14-2007, 09:10 AM   #56
yeap, I can see that button too, but that one doesn't send a full screen video to the second monitor, it just send the actual view, which is the video playing in the small square.
To be honest, I'm not missing Barney or Nemo at all; but my kids are getting annoying!!! This is becoming an emergency.
Another issue is that the zoom buttons on the GPS view are not working. (I'm using Freedrive). This is not bothering me at all, but this is all about to be 200% perfect.
Old 08-14-2007, 12:26 PM   #57
tn6478's Avatar
u should set it to be active where it goes full screen in the ini after a couple of second. also if you have a graphic card like ati or nvdia it will do theater mode on the extended monitor automatically.
Old 08-14-2007, 03:20 PM   #58
reddeath30's Avatar
Ok, i think I know what the problem is, in prior versions there was a split screen button on the drivers screen when the video was switched to mini mode where the video is almost full screen except for the bottom bar. I take it that you passenger screen is not a touch screen? Let me know the exact details of your system. I havent had a real chance to test things fully on a dual screen system so you will be my guinea pig and beta tester. Let me know. Thanks.
Mobile Impact
Old 08-14-2007, 03:49 PM   #59
That's exactly what is happening; my passenger screen is a regular LCD with NO Touchscreen. It is connected to the TV OUT RCA Plug on my computer; surprisingly, the extended desktop on windows is working perfect.
This is what I have:
a) 7" Motorized Single Din Touchscreen on the dash. Connected to the VGA OUT Port (http://www.digitalww.com/store/prodd...prod=GL701TVCT)
b) VIA Motherboard with audio and video(S3 chip) integrated, enclosed in a VOOMPC box installed under the driver's seat (http://www.mini-box.com/VoomPC-2-Car...8&category=101)
c) 10.4" TFT Monitor (RCA Input) installed on the roof (http://cgi.ebay.com/ebaymotors/10-4-...spagenameZWDVW)
I will upload pictures, just give me a chance to clean up the mess and get rid of the Happy Meals' left overs.
Old 08-18-2007, 04:36 PM   #60
reddeath30's Avatar
Sorry about the delay in responding, when I got here to try to reply, mp3car stopped responding. Anyway... Here is what I will make it do, when you hit the split screen button, it will send the screen to the passenger side and expand the movie/visualization into full screen with mini button bar, then it will automatically go full screen after 30 seconds, then when you hit the Media button on the main menu or the gps module it will bring it back to the drivers screen unchanged in size.
Let me know if this sounds good or if you would like it to do something different.
Mobile Impact
[frontend] Mmc Rc2 New Release 05.23.2007 Bitoholic Mobile Media Center 71 04-09-2008 01:23 PM
