Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Mobile Impact
Closed Thread
Old 08-24-2005, 11:36 AM   #46
thankyou. i had been trying to rename/save as .m3u on several different playlists but it wasn't working
however i just tested it with those thracks and it worked fine.
however because of the state of the playlists that media player chucks out i think it will be just as quick to go through mobile impact and create them track by track.
that is unless you're planning to do something that will make it easier in the next couple of weeks?
My install... check it out!
www.mp3car.com/vbulletin/showthread.php?t=56599
GreenBeast is offline
Old 08-24-2005, 12:15 PM   #47
Mobile Impact Creator
reddeath30's Avatar
Sorry, probably no major changes in the next couple of week, but I will toy around with the playlist and see if I can make it move multiple files into the list instead of one at a time.
Mobile Impact
Highly innovative car computer multimedia/entertainment system software.
http://mobileimpact.biz.tm
reddeath30 is offline
Old 08-24-2005, 01:35 PM   #48
i've been told of a fairly easy way of doing it using DOS should don't rush or anything!
thanks for your help
Old 08-24-2005, 06:49 PM   #49
reddeath30's Avatar
I coded it so that it can add all the files in the directory at once.
I am trying to get it to just add specific selected files, but am having some difficulties with that part.
Mobile Impact
Old 08-25-2005, 07:20 AM   #50
oh so you can add all the files?
i thought you had to do it one by one?
Old 08-25-2005, 07:50 AM   #51
i've noticed a little 'glitch', you can't have playlists in a folder without another folder in there with them
Old 08-25-2005, 07:51 AM   #52
I think the instructions are on post #40.
As far as the resolution, can this one be run at 600X800 instead of 800x600? Does anyone have a skin done at this resolution? I am trying to find a frontend with skin that will work for my setup. But so far just have an empty XP system sitting in my trunk.
Stacker is offline
Old 08-25-2005, 08:06 AM   #53
reddeath30's Avatar
I just added that feature, I havent updated it.
The playlist saves in the same directory that shows in the left screen, so you have to make sure you know where the file is saving when you save it. So if you are in C:\Media\Mp3\Will Smith\ on the left and you add all the songs over to the right screen, then you name the playlist and then save it, you should immediately see the playlist file shown at the bottom of the list on the left. If you want to save the playlist here: C:\Media\Mp3 then you have to go back to show that directory on the left if you want the playlist file to save there. I hope this explains it, if not let me know. Thanks.
Mobile Impact
Old 08-25-2005, 08:10 AM   #54
reddeath30's Avatar
Sorry no, it is hard coded at 800 x 600. Im guessing that you have your screen turned vertically, instead of horizontally. This has got to be kind of difficult to make things work right with any of the front ends available. I dont even thing that you can create skins for any of them as they are all stuck on horizontal measurements. Whats the reason that you installed your monitor virtically and not horizontally?
Mobile Impact
Old 08-25-2005, 08:13 AM   #55
right ok then.
can you reopen a playlist in the playlist section and then choose to save it somewhere else?
and for anyone else who wants to add tracks in bulk through windows,
open a DOS prompt window and navigate the prompt to the directory where your music is
then type
dir /b /s >'filename'.txt put your required file name here
this will dump all of the file paths in that directory into a txt file. you can then open this and move the specific tracks/albums to a playlist file (.m3u) for use in mobile impact)
Old 08-25-2005, 10:48 AM   #56
reddeath30's Avatar
Yes, just open the playlist file so the contents appear on the right, then navigate to a different directory and hit save list.
Mobile Impact
Old 08-25-2005, 12:10 PM   #57
ok cool
Old 08-25-2005, 12:26 PM   #58
got playlist working.
however just discovered you can't shuffle in playlist mode!!!
any chance you can sort that?
Old 08-25-2005, 01:32 PM   #59
reddeath30's Avatar
I took great lengths in making sure that the shuffle worked in both file and playlist mode. The program shuffles within a single playlist. It will not shuffle between several different playlists however. Like if you have a directory list of several m3u files, it will only play within the selected m3u file, it will keep repeating the same playlist until a different playlist file is selected.
Mobile Impact
Old 08-25-2005, 03:32 PM   #60
right ok. well i had a directory of playlists but i only want it to shuffle through the one selected so thats fine but it doesn't work
sorry to have thrown so many things at you the last few days
Closed Thread
AstraMac Frontend Progress Update iKenndac MacCar 58 06-09-2007 03:52 PM
Completed Requests and Features xBrady GPSSecure 0 05-17-2005 02:43 AM
GPS Update fequency and Dead Reckoning Scouse Monkey GPS 31 05-12-2005 05:46 AM
MediaEngine Development Progress Update CarComp Media Engine 23 01-07-2005 12:53 PM
