Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Mobile Impact
Old 03-28-2006, 10:13 PM   #1
DaveB's Avatar
Button request: Minimize
Quite often I need to get to windows explorer to do something. I run with my windows taskbar hidden and with MI running full screen.
Currently, there is no built-in way to minimize MI allowing us to go to explorer. We either have to use an external keyboard command to swap to the windows taskbar or use the MI "exit program" button and shutdown MI. Then we have to start MI back up when we're done in windows.
I would like to see a new "Minimize" button added to the MI control screen (which currently has the shutdown/hibernate and other option buttons). There is room below and to the left of the "Log Off" button where a new button could be added. Although I think I would put the log off button in that open spot and put the "minimize" button where "log off" button is currently located.
Does this sound like a good addition for a future update?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
DaveB is offline   Reply With Quote
Old 03-29-2006, 01:15 AM   #2
thats a good idea
My install... check it out!
www.mp3car.com/vbulletin/showthread.php?t=56599
GreenBeast is offline   Reply With Quote
Old 03-29-2006, 08:37 AM   #3
I think so to
serious juju is offline   Reply With Quote
Old 03-30-2006, 07:48 AM   #4
Mobile Impact Creator
reddeath30's Avatar
Set up explorer.exe in the external applications module, or any other program you wish to run outside of MI.
Mobile Impact
Highly innovative car computer multimedia/entertainment system software.
http://mobileimpact.biz.tm
reddeath30 is offline   Reply With Quote
Old 03-30-2006, 08:47 AM   #5
I will give that a try
Old 03-31-2006, 10:03 AM   #6
things seem to work fine using external apps for me....i have G-force visual which i use for media player, it works fine through MI and it has its own toolbar to adjust the effects, the only one thing i found is if you click on MI though, the toolbar would disappear behind it and you'd have to exit MI to get to it if you are using touch/mouse only control. i was lucky enough that the program had "always run on top of other programs" function as does alot of software.
loving the program
BMW-steve is offline   Reply With Quote
Old 12-14-2006, 11:44 PM   #7
What about adding a minimize button under the "shutdown" menu? i cant imagine it being too hard to implement. Ill try putting explorer in the external app list for now.
AllShowNoGo is offline   Reply With Quote
Old 12-15-2006, 03:58 PM   #8
treetop777's Avatar
A minimize button would sure look nice right under the logoff button
treetop777 is online now   Reply With Quote
Old 12-15-2006, 09:12 PM   #9
I was sitting a long time at my testing machine at work thinking what would mobile impact might need... I was searching on google for an external app to eject a cd\dvd.. theres a few i found but it got busy so i couldnt add it in..
maybe the functionality is already there inside MI and I dont see it.
using Mobile Impact,Waiting on the rds radio.
nigwhyrito is offline   Reply With Quote
Old 12-16-2006, 08:32 AM   #10
reddeath30's Avatar
I might be able to put the eject button in the DVD/CD module as the new version has a totally redone and combined module. Thanks for the suggestion.
Mobile Impact
Old 12-20-2006, 02:10 AM   #11
we87's Avatar
I will add a request for the minimize button, it sounds like a great idea! I have wanted to minimize MI before so I can see the need for it.
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Everything is in the car and working.
I painted the cilpboard mount and it looks good.
Shutdown/Startup is working excellent!
View My Progress Here
we87 is offline   Reply With Quote
Old 01-01-2007, 11:35 AM   #12
i'd enjoy a minimize button as well
senseless228 is offline   Reply With Quote
Old 01-02-2007, 01:31 PM   #13
I'm spending my day looking at varios front ends, and MI is currently a front runner due to that I haven't actually installed it yet, but this should work...
open notepad and type
[Shell]
Command=2
IconFile=explorer.exe,3
[Taskbar]
Command=ToggleDesktop
save this file as minimize.scf (or anything you like with a scf extension) add an external application in MI that points to the scf file ... this file is the same as the windows show desktop button from the quicklaunch taskbar.
You can also just find your quicklaunch folder and run the "show desktop.scf" file from there ... wasn't sure if MI could handle the space in the file name though since I haven't tested it.
-Aaron
mindspan is offline   Reply With Quote
Old 01-02-2007, 05:45 PM   #14
treetop777's Avatar
Interesting!..i got to try this..
Old 01-02-2007, 06:58 PM   #15
Zeroaviation's Avatar
..workx for me!
Im a pilot.
I have become a cross control stall.
Zeroaviation is offline   Reply With Quote
bottom left button being selected randomly ITL RR Skins 4 01-03-2006 08:12 AM
Trying to hack my laptop power button Stevo759 Laptops, Tablets, UPMCs, etc. 7 12-14-2005 09:29 PM
Can a hovering button be implemented ? tolisn Road Runner 4 10-15-2005 11:11 AM
button repeating bug? scott_fx Centrafuse 3 02-23-2005 11:35 PM
OPUS plus power button The Grinch Power Supplies 2 07-25-2004 01:55 PM
