System Information
Time of this report: 6/8/2006, 22:05:45
Machine name: DEEFAULT
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.051019-1519)
Language: English (Regional Setting: English)
System Manufacturer: GATEWA
System Model: N2DTM026
BIOS: BIOS Date: 10/19/04 21:11:20 Ver: 08.00.10
Processor: Intel(R) Celeron(R) CPU 2.66GHz
Memory: 494MB RAM
Page File: 119MB used, 1037MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No General MIDI DLS file was specified in the registry.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) 82865G Graphics Controller
Manufacturer: Intel Corporation
Chip type: Intel(R) 82865G Graphics Controller
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_7147107B&REV_02
Display Memory: 96.0 MB
Current Mode: 800 x 600 (32 bit) (85Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: ialmrnt5.dll
Driver Version: 6.14.0010.3889 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/20/2004 15:11:00, 37951 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ialmnt5.sys
Mini VDD Date: 8/20/2004 15:26:00, 737874 bytes
Device Identifier: {D7B78E66-6632-11CF-FA7C-4D51A3C2CB35}
Vendor ID: 0x8086
Device ID: 0x2572
SubSys ID: 0x7147107B
Revision ID: 0x0002
Revision ID: 0x0002
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SoundMAX Digital Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_7147107B&REV_02
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: smwdm.sys
Driver Version: 5.12.0001.5240 (English)
WHQL Logo'd: Yes
Date and Size: 9/1/2004 12:17:46, 259648 bytes
Other Files:
Driver Provider: Analog Devices
HW Accel Level: Full
Cap Flags: 0xB5B
Min/Max Sample Rate: 8000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path:
DLS Version:
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SoundMAX Digital Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24DE
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/5/2006 10:40:32, 57984 bytes
| Driver: usbd.sys, 8/23/2001 07:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 17:14:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 16:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Upper Filters: egxfilter
| Service: i8042prt
| Driver: mouclass.sys, 3/20/2006 03:42:47, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
+ USB Touchscreen Controller(Universal)
| Vendor/Product ID: 0x0EEF, 0x0001
| Matching Device ID: usb\vid_0eef&pid_0001
| Service: xtouch
| Driver: xtouch.sys, 3/22/2006 12:59:26, 77952 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Sony Ericsson W800 USB WMC Modem
DirectPlay8 Modem Service Provider: Sony Ericsson W800 USB WMC Data Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 Serial Service Provider: COM6
DirectPlay8 Serial Service Provider: COM7
DirectPlay8 TCP/IP Service Provider: MS TCP Loopback interface - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 17.2 GB
Total Space: 19.5 GB
File System: NTFS
Model: WDC AC420400D
Drive: D:
Free Space: 81.1 GB
Total Space: 114.5 GB
File System: NTFS
Model: WDC WD1200BB-22GUA0
