Quote: Originally Posted by
Imran
I will try disabling the the wireless card, and I will post the processes that are running. I installed the K-lite codec pack and WMP 10. Thanks for the help will keep you posted.
Imran
That may be the problem, we have experienced codec conflicts with mpeg-2 decoding for DVD's and the K-lite pack. If this is indeed the issue, then unfortunately you would have to load windows from scratch to eliminate the k-lite codecs, unistalling them often leaves pieces that are near impossible to find. Then when you reload, only load the specific codecs needed for the files you have. As an example, I use Xvid codec for all my DVD movies converted to AVI and then I install power DVD which installs the DVD decoding codec and then i stop there. On rare occassion that I get a video, I install the 3ivx or Divx codec, but most stuff is in Xvid these days. I try to be really carefull about codecs because they alone can cause a world of issues. Hope this helps.
