Quote: Originally Posted by
Azrael_Lyk
Hi I was wondering, is it possible to embed other emulators, for example for PSX and PS2, or is it only possible to add the in the apps menu?
I would like very much to add the PSX and PS2 emulators to the emulator module, however right now there arent any PS2 emulators that actually work right. I have found an outstanding PSX emulator, PSXeven, but it has 2 major problems. The first problem is that the iso files are all extremely large and range anywhere from 300 to 700 megs, which is somewhat impractical as far as hard drive space is concerned. Of course the users that have 250 gig hard drives dont have to worry about it. The 2nd and most crucial problem is this is the only stable emulator that will run ISO files and not actually run from the cd, and it doesnt work with my code that I use to open and run the program with the selected ISO file. The last time that I worked on this was a couple of years ago, and unfortunately PSXeven has not had any updates since 2005, so the situation hasnt changed. You can set up any program to run out of the external application module, so all you would have to do is set it up in there. Also the new version has the ability to set up and embed any GPS program into the GPS module. I have tested it and found that you can embed just about any and every program in the GPS module, so if you dont use GPs you can set it up to open from there. The new release will be out by the end of the month.
