09-19-2006, 12:41 AM
#1
I should've eaten the blue pill.
[FRONTEND] MMC (Mobile Media Center) Dev Release
So I said I would release a version this weekend... well I decided to release the development release now. It is dev quality. It will have errors and bugs, but I would like to get some feedback on the speed on the UI and feedback on the Music Module, which is the only one enabled on this version.
You need .NET Framework 2.0 installed for it to work.
Please give me feedback so I can make this a great quality application. I am back at square one on the testing since so much has been rewritten.
http://www.hybrid-mobile.com/dm/down...v_ release.zip
Thanks in advance!
09-19-2006, 01:25 AM
#2
bump
Just wanted to make sure everyone seen this before going to bed. I will be very active on this project again. So with everyones help I can make this one of the best front ends on here. I know I can not do it alone though... I need help. So please download and test, give feedback and we can go from there. I will have a more completed version ready for this weekend as promised too.
Good night
09-19-2006, 09:07 AM
#3
Phone Control Moderator
Hi Ben, glad you're back
I did just a quick test and that's what I've found:
- All (sound) files: take incredibly long to scroll to top/end(on about 2100 songs). It ends up with this exception:
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at System.Collections.Generic.List`1.get_Item(Int32 index)
at HybridMobile.Controls.MmcListBox.addTimer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MobileMediaCenter
Assembly Version: 0.8.1000.7
Win32 Version: 0.8.1000.7
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/MobileMediaCenter.exe
HybridMobile.Membranes
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Membranes.DLL
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Intellified
Assembly Version: 1.0.2452.42114
Win32 Version: 1.0.2452.42114
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/Intellified.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Controls.DLL
HybridMobile.Media
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Media.DLL
Transcend.Translucent
Assembly Version: 1.0.2452.42065
Win32 Version: 1.0.2452.42065
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/Transcend.Translucent.DLL
HybridMobile.Xm
Assembly Version: 1.0.2452.42115
Win32 Version: 1.0.2452.42115
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Xm.DLL
Transcend.Translucent.X
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/Transcend.Translucent.X.DLL
HybridMobile.DirectX.DirectShow
CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.DirectX.DirectShow.DLL
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
- scrolling through albums: list disappears
- same on artists... (probably this influences all other lists)
- Pause / play button doesn't switch bitmap on first click (but on second) so it gets out of sync with the real state.
- searching within an album will deliver this exception:
Code:
System.Data.SyntaxErrorException: Syntax error: Missing operand after 'E' operator.
at System.Data.ExpressionParser.Parse()
at System.Data.DataExpression..ctor(DataTable table, String expression, Type type)
at System.Data.Select..ctor(DataTable table, String filterExpression, String sort, DataViewRowState recordStates)
at System.Data.DataTable.Select(String filterExpression)
at HybridMobile.Media.MediaLibrary.GetAlbumSongByString(String album, String searchString)
at MobileMediaCenter.MmcForm.SearchTextBox_TextChanged(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnTextChanged(EventArgs e)
at System.Windows.Forms.TextBoxBase.OnTextChanged(EventArgs e)
at System.Windows.Forms.Control.set_Text(String value)
at System.Windows.Forms.TextBoxBase.set_Text(String value)
at System.Windows.Forms.TextBox.set_Text(String value)
at MobileMediaCenter.OskForm.button_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
~~CUT~~
enabled.
For example:
<configuration>
</configuration>
- scrollbar get's not refreshed when switch albumd (when the amount of songs in the new album is smaller then in the one before)
- Equalizer: slider for left/right balance looks misplaced / can't be moved
That's it so far.
I'm using a German XP SP2 with latest .NET 2.0 installed.
09-19-2006, 10:14 AM
#4
Thanks! Glad to be back. Thank you very much for the testing and feedback. I will work on these issues today
Code:
mscorlib
MobileMediaCenter
System
System.Drawing
Intellified
System.Xml
HybridMobile.Media
HybridMobile.Xm
System.Data
enabled.
For example:
<configuration>
</configuration>
Code:
~~CUT~~
enabled.
For example:
<configuration>
</configuration>
That's it so far.
09-20-2006, 03:28 PM
#5
I am posting the latest dev build this evening. I fixed most of the issues minus the play/pause button image. This requires a change in the skinning system which I am rebuilding from the ground up anyway...
I did fix the browse mode issues, scrolling issues and the EQ problem. The EQ is also enabled in this build.
Thanks again Zoro for the feedback.
09-20-2006, 03:35 PM
#6
Ok, I'll give it another try when you've posted it.
09-21-2006, 03:33 PM
#7
Any findings on the error with visuals? Running xp, m10000, standard setup. Just closes and or locks on visuals and music changes. Love the interface/program!!!
09-21-2006, 06:53 PM
#8
http://www.hybrid-mobile.com/dm/down...C_devpatch.zip
Here is the latest dev patch:
Just unzip and overwrite old files with new ones.
Fixed list box control bugs.
EQ and Fader enabled and fixed.
Search functions fixed for each mode.
Visuals can be switched now by clicking Hybrid Logo while in visual mode.
Please download and test
09-21-2006, 07:16 PM
#9
bump
need feedback please
thanks in advance
09-22-2006, 04:24 AM
#10
bump
thanks in advance
Oh, those young, hot blooded kids
Looking good now
09-22-2006, 03:29 PM
#11
I will install this one tonight. Dl'd the previous one and the problem I had was fixed then! Keep it up! I will post anything I find on this one!
P.S.
This is by far the best program I have used for my carpc. FAST!
09-23-2006, 08:52 AM
#12
I get the same problem as with the last program. "Mmc.exe has encounted a problem and needs to close"
This is the log.
Application Session Started 2006-09-23 14:50
Information logged at 14:50:31
Initializing Components...
Switching DVD Region to Region Free...
Initializing Sound Engine... Device Found - NVIDIA(R) nForce(TM) Audio
Loading Winamp Input Plugins...
Getting media paths and checking media database...
Checking for Hybrid CECU...
09-23-2006, 10:00 AM
#13
cheap custom title
Good news you're back coding!
This has been the fastest front-end I've seen thus far!
When I find some time, I'll test it...
09-23-2006, 11:13 AM
#14
This is probably a dumb question, but you have removed all old versions of MMC right? and then just ran this one from the folder you unzipped it into?
This is the log.
09-23-2006, 11:14 AM
#15
JC,
Holy crap... been a long time since I seen you  I am so glad to be back on the project again... it is going to be way better this time around, trust me. Got a lot of great things I am going to be doing with MMC. Appreciate you helping me out with testing!
| Thread Tools |
| Display Modes |
Linear Mode
