Go Back   MP3Car.com > News & Announcements > Mp3Car Blog Talk
Old 06-15-2009, 08:57 AM   #1
mp3Car Staff
optikalefx's Avatar
optikalefx is on a distinguished road
CarNetix P2140 (part 2) - Power your laptop with Goce from mp3Car
Goce from mp3Car will walk you through the steps necessary to power your laptop using unregulated ~6~24 volts with only the p2140 and the wire your laptop power adapter came with.
(If it says it's a private video, it's lying)
-For this project you need the following materials:
-p2140 and 8pin molex output harness
-Wire strippers 14-22 gauge
-Bench battery
-Multimeter
-Shrink tubing and heat shrink tubing gun OR electrical tape
-Solder gun and non leaded solder
-laptop and its power brick
-knife or scissors
To finalize this project you should do a continuity test on the stripped wire to find out which is positive and which is negative. Then you can twist and solder the p2140 output wires to the cut laptop brick wires. Turn it on to test it one more time, and then plug it into your laptop to test.
optikalefx is offline   Reply With Quote
carnetix to power a laptop as well as charge its battery? sharpmusic How to Power a Laptop 5 08-20-2009 02:15 PM
how to power laptop and charge battery with carnetix sharpmusic Laptops, Netbooks, Tablets, UMPCs, etc. 2 06-29-2009 07:20 AM
Carnetix Power to Laptop Wiring? AznArkitekt Laptops, Netbooks, Tablets, UMPCs, etc. 6 02-05-2007 07:53 AM
Question about Laptop Power on/off ashiq32 Laptops, Netbooks, Tablets, UMPCs, etc. 1 02-01-2007 09:11 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
