Go Back   MP3Car.com > General > Mp3car Forum Suggestions/Comments
Old 11-18-2007, 06:55 AM   #1
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Code Tags Not working correctly
The [CODE ] [ /CODE ] tags are cropping the text if it is too long. There is a scrollbar on the bottom. Since the "yellow-ish" part extends the correct table width, I am not sure why there is a frame inside of it with a fixed width. Looks pretty bad IMHO.
Old 11-19-2007, 01:30 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
looking into it.
thanks for brining it up.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Audio not working correctly in SD nicehomeslice Infill T3 7 02-08-2008 12:52 AM
SPV M700 / HTC P3600 not working with Phonecontrol Tracert PhoneControl 0 07-13-2007 11:16 PM
BR-3 VB6 Sample Source Code Zharvek Engine Management, OBD-II, Engine Diagnostics, etc. 0 06-15-2007 08:43 AM
Head Unit 'code' - help! Laidback Car Audio 41 06-10-2005 09:53 AM
Everything working correctly? bgoodman Off Topic 16 09-15-2002 01:13 AM
