Go Back   MP3Car.com > General > Mp3car Forum Suggestions/Comments
Old 05-23-2008, 10:01 AM   #1
kmarlowe is an unknown quantity at this point
Hiding / Changing Post Datestamps?
Anyone know how to make it less obvious that I'm posting from work? Ideally, I'd hide / change the timestamp on a post... ideas?
kmarlowe is offline   Reply With Quote
Old 05-23-2008, 11:52 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
that would require getting into the database and changing the fields on every single post you've made or will make manually. I can tell you right now it's not going to happen.
Messing with the database like that is generally not a good idea.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 05-23-2008, 02:41 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Change your timezone on whatever PC you want to "hide"
Can't Go Past POST. What's Wrong? sama Power Supplies 6 08-22-2006 09:57 PM
