Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Mp3Car Infill G4 - Double Din Car Computer
Old 04-23-2007, 09:16 AM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
G4 F.A.Q. - Please read here before posting your questions!
Since the same questions seem to be popping up on a regular basis, this FAQ should help to answer some of those very questions.
Can I replace the hard drive in the G4?
While it is possible to replace the hard drive in the G4, it is not recomended for a few reasons.
1. The StreetDeck team has spent countless hours preparing the G4 sofware. This includes heavily tweaking the Windows install to allow for the best possible performance, fast boot times, licensing installs, driver installs to utilize the AM/FM radio and other devices.
2. StreetDeck is locked to your hard drive. If you replace the hard drive, you will have to have StreetDeck reregistered.
3. We cannot provide warranty support on G4s that have been opened up.
Can I replace the memory in the G4?
While it is possible to replace the memory in the G4, it is not recomended for a few reasons.
1. The StreetDeck team has spent countless hours preparing the G4 sofware. This includes heavily tweaking the Windows install to allow for the best possible performance, fast boot times, licensing installs, driver installs to utilize the AM/FM radio and other devices. The team has done all of this with the knowledge that the system comes with 512MB of memory.
2. While many people have their own preferences for hardware options for Windows, this system has been optimized to work just fine with 512MB of memory.
Can I use XYZ maps with this hardware?
While this question is more related to the software StreetDeck, it has been asked in this forum numerous times and as such I feel it should be answerd here.
StreetDeck uses Map Point maps. If Microsoft Map Point has map support for your country, then you are good. Otherwise, you will have to set your mapping software to launch externally from StreetDeck.
Questions about Steering Wheel Control?
From this post.
Quote: Originally Posted by god_of_cpu
Right now Steering Wheel controls are non-functional for the G4 for all US cars, you can get around this right now by buying an SWI-X.
We are still working with Infill to get the integrated steering wheel controller
solution working for the US and support for the cars sold here. The hardware is there and hopefully will work for some people some day after just a software update. It will only work with cars that use resistive steering wheel controls. This will exclude all cars that use the CAN bus for streering wheel controls. The older your car is, the more likely it is to work through resistive controls. Even if your car has resistive steering wheel controls it may never work with the G4 as each car manufacturer implements thier resistive controls in a different way sometimes even varying between model and year.
The best way to tell if your car is capable of being supported by the G4 is seeing if it supported by PAC SWI-X. If it is, it is probably likely to work with the G4, however, we haven't been able to fully test any cars yet and I am really just making an educated guess that this is true. In any case, don't bother asking if your car will be compatible yet cause we just don't know, nor are we at the stage yet where we can begin compatibility testing and there is still a good chance that we may never be able to get the Streering Wheel Controller working for any US cars.
If things go as planned, there will be a patch for StreetDeck that will allow you to hook up your steering wheel controls to the G4. Most likely we will not be able to tell you how to hook up your steering wheel controls for your specific car and it will not be a trivial task for most people to figure out how to do it. The best we will be able to do until we build a steering wheel controller install database is tell you generally how they work. For example, my car requires adding an extra resistor in the right place to get all the controls to read anything.
If you buy a G4, the only advice I can give you until we can confirm there will be a patch for it is to purchase it assuming the integrated steering wheel controls will never work for your car and the only way to get them to work is to purchase a SWI-X
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
INFILL G4 - Australian and New Zealand Questions Answered INFILLG4 General MP3Car Discussion 20 04-30-2008 12:21 AM
Questions about my setup and the Carnetix P1900... Nola111 Power Supplies 2 05-14-2007 08:35 PM
Will someone be willing to answer a few questions about the Vietnam War for an essay? guitar333 Off Topic 6 05-25-2005 12:53 PM
Lots of questions.. long post. rach Newbie 8 11-13-2004 11:53 PM
Final questions 4.9 EF Futura Newbie 1 06-20-2004 11:06 PM
