Quote: Originally Posted by
IandI
Is there a reason why you can't eliminate the relay and wire the GRN/BLK wire of the CNX-P5V directly to the USB power from the G4?
Started reading the
Carnetix manual and the same question popped into my mind.
Too bad this question is left unanswered.
Quote:
Also, wouldn't it be a good idea to fuse the 5v output prior to the device or hub?
Now this question is answered in the manual. Yes, you should use a fuse.
Pim
