The MP3car.com Store
Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Infill G4 - Double Din Car Computer
Thread Tools Search this Thread Display Modes
Old 05-28-2007, 07:58 PM   #1
My Photos: (0)
Question Infill G4 Battery Drainage
Id like to get a feel of how everyone powers off and on their G4 when they are daily using it.
Is it safe to keep the unit in "Stand By" mode overnight? will that drain the battery a signficant amount?
What about "Hibernation" mode? when should we be using these power saving modes?
What routine is a safe routine in terms of power management?
How long can I be running the G4 in the car without the alternator powering the battery before it starts to drain the battery enough to affect starting the car up?
I know most of these questions are subjective to the type of car and the type of battery, but Id like to get a feel of what people are doing
Tengoku is offline   Reply With Quote
Sponsored Links
Old 05-29-2007, 07:25 AM   #2
Vehicle: 2006 VW GTI
My Photos: (4)
The G4 will come out of standby and shutdown if the car has been off for 48 hours OR the battery voltage gets too low.
That said, I had some issues with my car. I use hibernate now without any problems. I don’t get the 4 second start-up by it only takes about 25 secs
Deadeye is offline   Reply With Quote
Old 05-29-2007, 08:09 AM   #3
johnk's CarPC Specs
Vehicle: 2000 Honda Prelude
My Photos: (9)
I use Standby and haven't had a battery problem in the last 2 weeks I've been using it, even letting the car be unused for more than 24 hours.
What issues did you have Deadeye?
johnk is offline   Reply With Quote
Old 06-02-2007, 02:08 AM   #4
My Photos: (4)
second day i had it, I drove to work. and parked
when i came back to car the remote would not unlock the car. (new car)
I had to unlock the doors manualy. The car did still start however.
I think it was the car warning me that the battrey is low.
Old 06-06-2007, 12:44 PM   #5
My Photos: (0)
I just received mine and a quick test showed 100ma current draw in stand by mode. This can take a battery down over the weekend and a small battery in a day. I will let you know the rest of the measurements when I test all operating conditions.
Hockeynut is offline   Reply With Quote
Old 06-07-2007, 10:28 AM   #6
StreetDeckAce's CarPC Specs
Vehicle: 2000/Audi/A6
My Photos: (0)
If you look in the manual for the G4 on page 14 there are specific measurements of G4 power usage. We have tested the G4 using standby for 10 days on the smallest automotive battery wal-mart sells. There was no significant drainage.
StreetDeckAce is offline   Reply With Quote
Old 06-07-2007, 11:38 AM   #7
Raw Wave
god_of_cpu's Avatar
Vehicle: 2003/Infiniti/G35 Sport Coupe
My Photos: (0)
The only way the G4 should drain your battery to the point where you couldn't start your car, assuming its hooked up correctly, is if there is something wrong with your battery.
If your battery is old or worn out, the G4 could drain it to a low, but startable level, but the battery could fail to retain its charge for much longer and then go dead. It shouldn't be possible to the G4 to completly "kill" your battery as it will stop drawing power as soon as low voltage is detected. Unlike what leaving the lights on in your car does which is it continues to draw power until the voltage is too low to power anything which is a much lower level then what the G4 will always stop drawing power at and not good for the life of your battery.
There are a number of things you can do to make sure that your battery can support standby without issue.
  1. Get your battery tested. Pepboys or other auto parts stores will usually test your battery for free and let you know if it needs to be replaced.
  2. Monitor the G4 closely for its abaility to remain on standby. If the G4 won't make it overnight on standby, its generally a bad sign that your battery needs replacing and if you wait too long before starting it again, you may need a jump.
  3. Switch the default shutdown method to use hibernate which shouldn't draw any power.
  4. Use the soft power switch in StreetDeck to shutdown and choose hibernate instead of standby when you are not at home, until you are sure of your battery
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Infill G4 - Now Shipping StreetDeckAce Mp3Car Infill G4 - Double Din Car Computer 146 08-02-2008 10:18 PM
Infill G4 StreetDeck install michelk Mp3Car Infill G4 - Double Din Car Computer 3 04-23-2007 12:47 PM
What kind of cap/amp? asong31 Car Audio 60 12-26-2006 01:30 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 09:31 PM
time to a dead car battery? chuckctv Newbie 6 08-20-2004 10:08 PM
Sponsored Links
Ad Management by RedTyger
