The MP3car.com Store
Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Infill G4 - Double Din Car Computer
Thread Tools Display Modes
Old 06-30-2007, 09:36 PM   #1
My Photos: (0)
G4 and screen flicker?
Well, after such a long time, I've finally gotten around to actually installing the G4 in the truck. I had to do a lot of dash trimming to make it fit, but it goes in now without problem.
My issue now is that it flickers when plugged into the factory harness. No issues on the test bench--even removed it and brought it back in to make sure I didn't stress the wiring too much and short something. No problems at all. Annoying flicker when plugged in.
I searched around for some troubleshooting tips, but I didn't see anything posted that seemed to solve anyone's problems. Any ideas on how to best start isolating this problem?
Thx,
Rip
RipNRun is offline   Reply With Quote
Sponsored Links
Old 07-01-2007, 11:42 AM   #2
IandI's CarPC Specs
My Photos: (0)
Unhook the illumination wire and see if it solves the problem. The illumination wire can't have varying voltage, just on or off. I am pretty sure that will fix your problem. You can use a relay instead of directly connecting to the factory illumination wire to fix it.
IandI is offline   Reply With Quote
Old 07-01-2007, 10:07 PM   #3
JasonMK's CarPC Specs
JasonMK's Avatar
Vehicle: 2007/Saturn/VUE
My Photos: (47)
The wiring kit for my 2007 Saturn VUE (GMOS-LAN-06) has both an illumination (orange wire) and a dimmer (orange/white). Which one should I connect if I want to avoid this flicker issue myself. I haven't installed it yet, just mapping out what all the wires need to be connected to.
JasonMK is offline   Reply With Quote
Old 07-01-2007, 10:34 PM   #4
My Photos: (0)
IandI, you're onto something there.
I figured out a few things. Just an FYI in case anyone else has this problem.
As long as it's set for daytime, there's no flicker problem. When it adjusts for night, it flickers when there's any dimming at all. If I adjust the interior dash lights to full (which I never drive with on full), then the flicker stops.
However, if I adjust the screen brightness settings so that ultimately there's no real switching of the G4 from daylight to night modes, of course, there's no flicker.
Hope that helps someone out there...
Rip
Old 07-03-2007, 06:21 AM   #5
Vehicle: 2006 VW GTI
My Photos: (4)
had the same problem.
Just wired a relay in place so when lights are on the G4 has a full power source.
Deadeye is offline   Reply With Quote
Old 07-03-2007, 06:39 AM   #6
Mp3Car Staff
Fiberoptic's CarPC Specs
Fiberoptic's Avatar
Vehicle: 2006 Toyota Scion
My Photos: (0)
Now what would be very cools is have the backlight of the g4 dimmable based on that varying g4 voltage. Somehow I doubt this is a standard voltage range, but none the less this could be an interesting idea to incorporate.
Fiberoptic is offline   Reply With Quote
Old 07-05-2007, 06:51 PM   #7
My Photos: (0)
That would be sweet. Even on the darkest setting, the G4 is still a bit bright for me at night.
I may have to try the relay thing... No matter what I do, the Nav maps flash with the illumination wire connected.
--Rip
Sponsored Links
Trackbacks are Off
G4 review johnk Mp3Car Infill G4 - Double Din Car Computer 61 12-12-2007 11:25 AM
FS: cracked screen iBook G4 - mccdeuce Classified Archive 11 07-08-2006 02:48 PM
Sponsored Links
Ad Management by RedTyger
