Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Mp3Car Infill G4 - Double Din Car Computer
Old 07-13-2007, 10:05 PM   #1
johnk is an unknown quantity at this point
USB hub sold with G4 is not adequate; doesn't work with at least some external drives
I think that you guys need to choose a different USB hub to sell with the G4.
On my original G4, the USB hub did not work for my Western Digital Passport drive (the drive's power light came on, but was not seen by Windows). I went out and bought my own hub, and it worked fine.
After my G4 was stolen, I decided to try ordering the same hub again, just to see if maybe the first one was faulty. But, no, it fails just like the first one.
johnk is offline   Reply With Quote
Old 07-22-2007, 02:28 PM   #2
7racer is on a distinguished road
John,
what hub did you end up getting?
7racer is offline   Reply With Quote
Old 07-29-2007, 06:17 PM   #3
I forget what hub I got with my first G4, but the one I bought at a store recently after purchasing my second G4 also does not work with the external hard drive.
Now that I think about it, I am not 100% certain that I did find a hub that worked with the first G4... I may have only been able to get it to work when using the front USB port. But the hub was stolen with the first G4, so I can't be sure.
Old 07-29-2007, 06:21 PM   #4
thanks. I don't have anything like a harddrive to power. I just need to power my datalogit for engine/afr monitoring; a track GPS sensor; and the bluetooth wifi. I don't think I will have a problem, but still need to test it out.
Bob
Old 09-08-2007, 02:34 AM   #5
ABTsportsline's Avatar
ABTsportsline is on a distinguished road
i think the problem comes down to power draw from the USB hub. If you are using external drives which are powered THROUGH the USB hub, you might have issues. If you use externally-powered drives, or thumb drives, you should have problem.
ABTsportsline is offline   Reply With Quote
Old 09-26-2007, 09:15 AM   #6
Remford's Avatar
Remford is an unknown quantity at this point
Yep. The drive is going to need power from SOMEWHERE, after all. That means if there's no power directly to the drive itself, any peripheral hub it's connected to is going to have to be powered, especially given the inherently low power design inherent to CarPC's. Even if it's not mentioned specifically in the documentation, it really shouldn't be all that big a surprise.
Remford is offline   Reply With Quote
Is DC powered USB hub good idea? civic5zigen Power Supplies 6 10-21-2005 06:29 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
FS: Toshiba External Slimline CD-RW/DVD Drive USB 2.0 - Built-In Batt. Pack!!! hd54321 Classified Archive 18 05-07-2005 02:02 PM
External USB Aluminum case for laptop hard drives jarubio General Hardware Discussion 9 04-19-2005 08:24 AM
USB Hub External Power tejesh83 Power Supplies 2 09-11-2003 06:35 PM
