The MP3car.com Store
Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Infill G4 - Double Din Car Computer
Thread Tools Display Modes
Old 08-01-2001, 03:00 PM   #1
My Photos: (0)
MargeJ.
I'm quite tempted to install vista (again) on my Infill. However i had a little sound issue when i installed it the first time. My back speakers would only play some surround sound, not the real full sound if you understand? I could not get it to work properly, did you?
eliaz is offline   Reply With Quote
Sponsored Links
Old 08-01-2001, 03:21 PM   #2
marci's CarPC Specs
marci's Avatar
Vehicle: daihatsu Rocky (Feroza F300)
My Photos: (14)
:-) maybe i build it back again. but normally the other one 2DIN Device without PC is for me the better choice i think. CID650 :-) But i think the radio of the CID650 is same bad like the radio of the Infill G4, and donīt have RDS (radio Data system) and Travel information.
(is a stupid Radio)
At the moment i have installed a Becker Casscade Pro Radio with exellent Radio, maybe next summer i change someting again. Let us see, what centrafuse brings :-)
marci is offline   Reply With Quote
Old 10-03-2007, 11:38 AM   #3
marci's CarPC Specs
marci's Avatar
My Photos: (14)
Infill G4 Windows Vista drivers?
Hi @all,
anybody knows where i become vista compatible drivers for testing?
I mean not the basic Computer drivers from VIA or realtek, i Need the ICU and Touchscreen drivers, maybe (but not really necessary) the Infill station software for testing? (remote control).
Vista has some features for Multimonitoring that i needed.
Old 10-03-2007, 12:22 PM   #4
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
I can't even begin to fathom how poorly Vista would run on a G4.....
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 10-03-2007, 12:54 PM   #5
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Quote: Originally Posted by marci View Post
Hi @all,
What features for multiple monitors? The only possibilities I see that could be useful would be clone (XP can do) or stretch across multiple (XP can do). If you want 2 independant cursors on 2 independant screens, then XP can do that too but not natively. And since you are on a G4, dual monitors, is going to be hellish at best.
Old 10-03-2007, 12:55 PM   #6
marci's CarPC Specs
marci's Avatar
My Photos: (14)
hehe :-) yes thatīs right, but iīm customized always my OS to minimum, like a XP embedded OS, thats my new vision - make a vista embedded OS. (I do that for my company much times ago, so i need to do this for my carpc too :-).
for the multimonitoring: it works with xp thats right, with two touchpads too. but external USB VGA card and the second USB Touchscreen recognizing after hibernating is working better in vista. I want to strip vista to minimum, but before i start that (terrible) work i need all Vista drivers. :-)
maybe thatīs only a idea, if i found a solution with XP than i run on XP again.. (so the work should do another :-)))))
Old 11-06-2007, 12:04 PM   #7
My Photos: (0)
Did you have any luck with finding vista drivers for touchscreen and ICU?
Old 01-09-2008, 12:42 AM   #8
My Photos: (0)
Actually, all of the XP drivers work perfectly in Vista.
Performance feels about the same as XP. Vista recognizes the hardware in your computer and scales itself down to work well on lower end processors such as the Via Esther. Vista's a smart OS actually and after installing it, I found that it didn't use up much more RAM than XP and the animations in media center seemed a bit more smooth than XP on the same system. Alot of the extraneous services will be turned off on lower end systems to save memory when you install it. You can even tweak it further and turn some more services off.
Recommendations: turn off user account control. It's going to prompt you a bazillion times while installing the drivers. Also, you'll get a red box that says the drivers may not be safe. Install them anyways; everything works just fine in Vista as of yet (can't say from SD, I'm testing out Centrafuse atm).
MargeJ is offline   Reply With Quote
Old 01-09-2008, 01:20 AM   #9
marci's CarPC Specs
marci's Avatar
My Photos: (14)
thank you :-) I have tried it some months befor too. But at the moment my G4 sleeps well on the Desk of my room where court exhibits are kept :-) I need other solutions, G4 is not bad, but at the moment not perfect as well ;-)
Old 01-09-2008, 01:51 AM   #10
My Photos: (0)
You don't like the Infill? I reckon it's not the most powerful out there and on my second car I've got a Core 2 car pc, but it almost brings a tear to my eyes to hear about one sitting on a desk :O Im tempted to buy it off you!
Sponsored Links
Old 01-09-2008, 03:40 PM   #11
My Photos: (0)
MargeJ.
I might consider installing vista again on my infill. The reason why I dropped it was because i had some sound issues with it. It would only play some sort of sorround sound in my back speakers, not the "full" sound. Did you have this problem?
Old 01-10-2008, 01:15 AM   #12
My Photos: (0)
That's the first I've heard of that problem, but there's so many driver revisions that you may have had one that wasn't fully compatible. I'll check to see what driver revision I have, but I believe I got it directly from VIA
Old 01-13-2008, 10:10 PM   #13
My Photos: (0)
Unhappy
Did you guys get the touchscreen working in Vista? I just installed Vista on my G4, but I can't get the touchscreen to work for some reason, I even downloaded the Infill drivers from cartft and installed it as a usb device.
dally28 is offline   Reply With Quote
Old 01-14-2008, 12:48 AM   #14
My Photos: (0)
You have to install it from the device manager, after running the touchscreen driver setup.
Old 01-14-2008, 11:37 AM   #15
My Photos: (0)
Cool
I tried installing it from device manager also, and it can not find the drivers, hmm. I will try again and see what happens. Thanks...
Sponsored Links
vB code is On
Trackbacks are Off
Vista experiences anyone? Nomader Road Runner 80 01-10-2008 08:01 PM
First impressions, bugs and features of Infill G4 & Street Deck 1.1.0.0 DAE51D StreetDeck 34 11-06-2007 02:42 PM
CF 1.2 on Infill G4 SUNAJ Centrafuse 10 08-21-2007 06:38 AM
Infill G4 TheMaskedMan General MP3Car Discussion 12 02-18-2007 07:43 AM
Run WinCE & XP together ShawJohn Software & Software Development 12 11-07-2005 05:09 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
