Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Mp3Car Infill G4 - Double Din Car Computer
Old 11-10-2007, 05:01 PM   #1
sbraab is an unknown quantity at this point
Thumbs up XM Direct to G4 Mic in Howto
Ok, I finally got my XM direct working with my G4 mic input. I had two problems the first was a ground loop and the other was a level mismatch. I used a pair of 12db line level attenuators and a ground loop isolator to get everything sounding decent. You might do a little better with more than 12db, but that was all I had lying around and it doesn't appear to cause any clipping on the mic input anymore. You may not need the ground loop isolator, but if you get noise with the engine running that will probably do the trick.
sbraab is offline   Reply With Quote
Advertisement Sponsored links
XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer Will Albers General MP3Car Discussion 2 03-27-2006 09:49 PM
Possible to split XM Direct cable to computer and XM commander? Jemmi General Hardware Discussion 3 12-14-2005 03:07 PM
XM Direct digital adapter or XM PC cable with SkyFi2??? LATEOTT Hardware Development 0 01-19-2005 03:18 PM
Using an XM direct as an XMPCR dacndar General Hardware Discussion 20 10-17-2004 02:21 AM
