Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Mp3Car Infill G4 - Double Din Car Computer
Old 05-24-2008, 06:01 AM   #1
haiminger is an unknown quantity at this point
INFILL G4 SCREEN ALIGNMENT Problem
I've got a strange problem with my unit.
From time to time, the touch screen alignment is going crazy, and I'm unable to use the higher half of my touch screen.
If I try to press a button on the upper side of the screen, I get a response from a button on the middle of the screen (Im using Centrafuse, but it also happens in normanl windows XP desktop).
This comes and goes, and it drives me crazy.
Has this been seen before? Any solutions avilable ?
Thanks in advance for your help
Haim
haiminger is offline   Reply With Quote
Old 05-24-2008, 02:46 PM   #2
johnk is an unknown quantity at this point
I've never had that, but there is an alignment utility. I think it's in the Start Menu and maybe also in Control panel (has "Infill" in the name I think). But if it's just intermittent maybe that won't help.
johnk is offline   Reply With Quote
Old 05-29-2008, 12:30 AM   #3
JasonMK's Avatar
JasonMK is an unknown quantity at this point
You tell us? How did haiminger's suggestion work out or did you find something else that did? [or did you learn to live with it...perish the thought!]
_______________________________________________
All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
JasonMK is offline   Reply With Quote
Old 05-29-2008, 04:02 PM   #4
Status so far
I was allready aware regerading the Infill G4 alignment utility.
It does not help. the problem comes and goes without a constant I can point that causing the problem to happen.
Old 06-13-2008, 07:16 AM   #5
samail is an unknown quantity at this point
Hi,
Do you use your infill in a warm environment or without switching on the air condition?
Sam
www.carputer.sg
samail is offline   Reply With Quote
Old 06-13-2008, 07:38 AM   #6
Quote: Originally Posted by samail View Post
Hi,
Sam
Yes I do, and it does seem to be part of the problem. when the car is parked in the open for a few hours, the problem is there when I start the car, and it ssems to go away after the car cools down
Old 06-13-2008, 08:06 AM   #7
Hi,
This seems to be a problem with touchscreen. I believe the resistive component in the touchscreen sheet may have expanded thus the readings is different. When the temperature on the screen gets too hot, you will experience out of alignment or not sensitive at all. In your case, upper half of screen not working.
The only solution is to keep the screen cool. Down in Singapore, if we operate the Infill without turning on the air condition, we will experience alignment out.
Sam
www.carputer.sg
Infill G4 completely off when switching ignition off deniax Mp3Car Infill G4 - Double Din Car Computer 4 07-13-2008 03:08 AM
G4 ICU Problem RavagerRay General Hardware Discussion 10 06-24-2008 10:04 AM
INFILL G4 - Australian and New Zealand Questions Answered INFILLG4 General MP3Car Discussion 20 04-30-2008 12:21 AM
7" Dynamix (LinITX) LCD - white screen problem xraycat LCD/Display 2 10-22-2007 01:43 PM
