The MP3car.com Store
Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Infill G4 - Double Din Car Computer
Closed Thread
Thread Tools Display Modes
Old 03-12-2007, 12:14 PM   #1
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
FAQ G4 Pictures and Specs.
Estimated Release Date: April 16th, 2007
Features:
CPU: C7 1.5GHz
Memory: 512MB DDR2 (SODIMM)
LCD: 800 X 480 6.5″ Touch Screen
Audio: HD Audio CODEC
USB: Front 1 port / Rear 2 port
HDD: 40GB HDD
DVD-ROM: DVD Combo
RADIO: FM section:87.5~108 MHz / AM section:153~1710 KHz
AMP: 44W x 4CH max (22w x 4ch nominal)
GPS: GPS Module
The connections on the back of the G4 are as follows:
  • 2 USB plugs
  • Mono Center RCA output (blue)* - 2.5v output measured
  • Mono Sub RCA output (orange)* - 2.5v output measured
  • Rear Camera Input (yellow)
  • TV Out (yellow) - NTFS
  • GPS Antenna Port
  • DMB Antenna (Non-Functional - DMB hardware is not included in the US version)
  • Microphone
  • Radio (Motorolla Female)
Here's a listing of the various wires out of harness:
  • Green/Black - Rear Left Negative
  • Green - Rear Left Positive
  • White - Front Left Positive
  • White/Black - Front Left Negative
  • Purple/Black - Rear Right Negative
  • Purple - Rear Right Positive
  • Gray - Front Right Positive
  • Gray/Black - Front Right Negative
  • Light Green - Reverse Gear
  • Orange/White - Illumination
  • Pink - Attenuator
  • Brown - Remocom - This is for steering wheel control
  • Blue - Antenna Turn On
  • Light Blue - Hand Brake
  • Blue/White - Amplifier Turn On
  • Red - Accessory
What's in the package:
  • Remote
  • Magnetic GPS antenna and interior mounting plate
  • Mounting Screws
  • Stylus
  • A/V breakout cable
  • USB Extention Cable
  • Harness to connect the unit to your speakers and for all other connections
Additional Parts (NOT Included) You May Need for the Install:
  • Car Specific Double DIN Kit / Face Plate
  • Car Specific Wire Harness
  • Car Antenna Converter
Other Notes:
  • The rearview camera input is completely implemented in hardware. It is activated when it detects you are in reverse through the use of reverse gear detection wire and switches the display from the computer to the rearview camera. The computer does not have to be booted for this to work.
  • The screen has 7 different tilt angles. The angle is remembered when starting up and the screen completely closes when it is turned off. To tilt the screen, just press and hold anywhere in StreetDeck where there is not a button. If the top of the screen is pressed, the top tilts in, if the bottom is pressed, the bottom tilts in.
Features supported in StreetDeck:
  • BlueTooth (yes, BT!)
  • AM/FM Radio
  • GPS
  • DVD playback
  • CD playback
  • OBD-II scanning
  • Internet Radio
  • Navigation
  • You can set the color of the user interface to match your car.
  • Video Play Back
*Please note: If hookinig up to an amplifier and not using the built in one, this unit only has 2 RCA outs. 1 for a mono-sub channel and 1 for a mono center channel. The suggested solution is to pick up a USB sound card. I will be listing some options for this shortly.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
FS: Lilliput 7" touch screen ::pictures included:: latin_racer Classified Archive 17 09-19-2005 08:44 PM
F/S: JL 12w7 Subwoofer with box!!! Pictures inside neema12 Classified Archive 10 08-29-2005 08:45 PM
FEELER: Apple iBook G4 12" with extra memory Red GTi VR6 Classified Archive 0 05-30-2005 07:51 AM
Post YourPC specs RogerWilco General Hardware Discussion 77 10-03-2004 02:40 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
