Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com
Old 06-28-2007, 09:16 PM   #1
~*77*~ is on a distinguished road
Rooftop GPS/Cellular/PCS/WiFi antenna
I have been looking at this lil' fella.
Would love to consolidate my wifi, gps, and xm antennas. Right now GPS is on the trunk deck, XM is inside on the rear shelf, and wifi is in the trunk.
What GPS receivers have an antenna connection compatible? I just have a USB receiver with no plugs, and most I see are the same.
It doesn't mention satellite radio support... Would it be possible?
Thanks.
Mostly Useless Info - Free Image Host
~*77*~ is offline   Reply With Quote
Old 06-29-2007, 06:58 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You'd still have your XM puck on the roof. This unit has GPS, WiFi and Cellphone antenna.
Your best bet would be to get an OEM GPS unit. They're available.
You might be able to connect that antenna to a 'puck' style receiver with some deft soldering, but I don't think it would be worth it at all.
No.
Quote:
Thanks.
Your'e welcome.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-29-2007, 07:18 AM   #3
jpuype's Avatar
jpuype is an unknown quantity at this point
Thanks.
I'm using this :
http://http://cgi.benl.ebay.be/GlobalSat-CompactFlash-CF-DELL-IPAQ-PDA-GPS-SiRF-3_W0QQitemZ170119176320QQihZ007QQcategoryZ4668QQrd Z1QQssPageNameZWD1VQQcmdZViewItem
And I found an adapter cable that links it directly to the FME connector that the Hirschmann antenna provides.
The receiver by itself does a pretty poor job picking up satellites but when in the car trunk and connected to the external it does pick up on average 7 to 9 sats.
I'm pretty happy with the setup, it is the only antenna I have on my car. XM is not available here in Europe and the Radio antenna is incorporated in the rear windshield of my BMW.
Clean and efficient.
Sincerely,
Jurgen
jpuype is offline   Reply With Quote
Old 07-01-2007, 02:43 AM   #4
96CalibraYE is an unknown quantity at this point
i wanna get one. it would def look cool, but still a little pricy, even with the discount. coz i live in Australia, it increases the price, so its closer to $100 for me for an antenna. but if someone has a second hand one there getting rid of :P
96CalibraYE is offline   Reply With Quote
Old 07-10-2007, 02:02 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I am using mine with the Spark Fun Electronics ET301 reciever and an adapter. I love it.
The OEM integration fits my needs precisely and looks 10x better than just having a USB puck on the dash or hidden where it won't get as good of a signal as this set-up.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 08-28-2007, 12:36 PM   #6
pdloader's Avatar
pdloader is an unknown quantity at this point
Guys I'm in the planning stage. I wanted to know if this antenna would work with the BU 353 GPS receiver? (I haven't bought this receiver yet but I'm planning to) I mean is there any way I can connect that receiver to this antenna?
Thanks in advance...
{Quotes}----------------------------{Quotes}
In theory, theory and practice are the same, but in practice, they never are.
A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality.
pdloader is offline   Reply With Quote
Old 08-28-2007, 12:41 PM   #7
_
The BU-353 is an antenna and a reciever in one. The MP3Car.com is just an antenna, you need a reciever to go with it (many times an OEM style reciever is used here). The other issue is that the BU-353 doesn't even have a port to connect an additional antenna to...so it's not even possible. Unless of course you take it apart and see if there's a port inside..but then I'd have to ask why you would do that?
Jan Bennett
Old 08-29-2007, 02:09 PM   #8
pdloader's Avatar
So I guess I should be fine with just the BU-353 itself. right? (I don't need the WiFi or Cellphone reception of this antenna anyways. )
Old 08-29-2007, 03:22 PM   #9
_
Yes.
Jan Bennett
Old 09-25-2007, 01:18 AM   #10
mmaverick's Avatar
mmaverick is an unknown quantity at this point
Is it possible to use this antenna for FM radio reception? if not, do you know a work-around in order to put this antenna in the OEM FM radio antenna place and still get FM radio reception by other means?
mmaverick is offline   Reply With Quote
Old 09-25-2007, 03:05 AM   #11
jpuype's Avatar
Depends on what you need and what model/make your car is.
-VW has similar antenna's that incorporate FM and GPS, but I have my doubts about
WLAN being in that.
-Same thing with 'the shark fin' type antenna's some actually have FM (and/or GPS capabilities)
Ofcourse you could simpy go for an FM antenna to be fixed to the car windshield.
Sincerely,
Jurgen
Old 09-25-2007, 10:41 AM   #12
_
you'll need a seperate AM/FM antenna to get it.
Jan Bennett
Calling all XM experts... 2 antenna wires vs. 1 Nola111 Car Audio 11 03-10-2009 08:13 AM
Radioshark to Car Antenna theminor Car Audio 50 10-04-2007 06:15 AM
Accommodating my GPS and WiFi antenna portabuddy Fabrication 7 11-26-2006 03:25 PM
Hacking a Holux GM-210 for external antenna (doesn't work) mpquattro GPS 9 04-22-2006 09:22 AM
Rooftop 3-in-1 antenna daPyr0x Wireless Communications 3 02-19-2006 10:42 PM
