Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com
Old 02-25-2008, 06:55 PM   #1
darth sidious lite
Fiberoptic's Avatar
Fiberoptic will become famous soon enoughFiberoptic will become famous soon enough
Intel Boards D201GLY vs D201GLY2 vs D201GLY2A Comparision Chart & Photos
As many of you may know the D201GLY was previously upgraded to the D201GLY2 adding a new south bridge as well as SATA ports. The Fan was also removed on this D201GLY2 revision. Intel has now announced and now shipping a D201GLY2A.
We have called our Intel engineering team and confirmed that the only difference on the two boards (D201GLY2 vs D201GLY2A) is a fan. After taking the photos I can see a change to the cache heat sink, but that was not documented.
As of today, both are in stock on the Mp3car Store.
D201GLY - Discontinued
Link for D201GLY2 (no fan) - Mp3car part MTB-053
Link for D201GLY2A (fan) - Mp3car part MTB-054
D201GLY Photo: (Full size here)
D201GLY2 Photo:(Full size here)
D201GLY2A Photo: (Full size here)
Fiberoptic is offline   Reply With Quote
Old 02-25-2008, 08:05 PM   #2
Lithoss is an unknown quantity at this point
Just the fan between 2 and 2A? Whats the point of that? i guess just bulletproof cooling for the low power consumption version?
Lithoss is offline   Reply With Quote
Old 02-25-2008, 08:08 PM   #3
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
I added a fan that moves air across both of the heat sinks on my D201GLY2. It seemed warmer than I prefer while I installed the OS on the bench.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 02-25-2008, 09:18 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Me too. You couldn't comfortably put your hand on it. Adding even a tiny fan makes it barely warm.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 02-26-2008, 07:50 AM   #5
Yeah i did too... i put it blowing down on the northbridge heatsink goes. i also replaced the stock processor heatsink with a smaller one. works great!
Old 02-26-2008, 08:16 AM   #6
TruckinMP3's Avatar
What heat sink did you use and how did you remove the old one?
TruckinMP3
Read the FAQ!
Old 02-26-2008, 08:55 AM   #7
Bugbyte's Avatar
I didn't. I went ghetto and used a fan from a dead Via M10000. It fit snugly between the power supply board and the heatsink. It blows sideways across the heatsink. I suppose I should secure it with tape or something but it is in there nicely and I'll decide later if I need to do that.
I reasoned (rationalized?) that if it falls off I'm no worse off than I was without it.
Want to:
-Where is the iBug?
Old 02-26-2008, 05:42 PM   #8
darth sidious lite
Fiberoptic's Avatar
According to our sales rep some undefined chassis had cooling problems on the D201GLY2 inspiring the upgrade to 2A.
Old 02-26-2008, 05:52 PM   #9
TruckinMP3's Avatar
Goof, I was asking lithoss
TruckinMP3
Read the FAQ!
Old 02-26-2008, 06:24 PM   #10
stroths's Avatar
stroths is an unknown quantity at this point
I ended up putting a cheap P3 socket 370 heatsink & fan I picked up at my local Fry's for $7. It's not low profile, but it is almost exactly the same dimensions as the original heat sink except I get a fan included in that height. The 50mm ball bearing fan is fairly quiet and it keeps the CPU cooler. The one I got is an Evercool CF-5B-H.
Now I just need to find a similar solution for the other heat sink.
There are some larger capacitors on either side of the processor, so you have to be careful to get a heatsink that will fit.
stroths is offline   Reply With Quote
Old 02-26-2008, 08:51 PM   #11
Bugbyte's Avatar
Well, I still didn't.
Want to:
-Where is the iBug?
Old 02-27-2008, 07:47 AM   #12
i grabbed one of the northbridge heatsinks off of an old dead nforce board i had. an asus a7n266 mobo to be exact. its smaller than the stock one, but cools just as well from what i can tell (with airflow)
Old 03-04-2008, 12:02 AM   #13
Dramey is an unknown quantity at this point
I have the D201GLY. My only gripe with the board so far is that it takes 10 seconds or longer just to get past the Intel splash screen. Other than that it's been running great about 4 months now. Do the newer versions boot up any faster?
Dramey is offline   Reply With Quote
Old 03-04-2008, 10:13 PM   #14
Bugbyte's Avatar
try this. Also, read post 213.
Want to:
-Where is the iBug?
Old 03-10-2008, 09:03 PM   #15
cbutters is an unknown quantity at this point
Hello Everyone.
I have a couple D201GLY2's for use in various situations, NAS and also as a CarPC. I figured out how to undervolt the D201GLY2 to 1.1volts vs the 1.35 volts, which makes it run a lot cooler.
I also have done some mods to the heatsink. You can check out my results here:
http://www.exoid.com/?page_id=155
Hope this helps some people out.
cbutters is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Intel MINI-ITX board - D201GLYL & D201GLY jmbickham General Hardware Discussion 297 09-30-2008 03:30 PM
Intel D201GLY BIOS Petition, Mobo selection (C2D?) and test results! Lope General Hardware Discussion 11 09-02-2008 07:55 PM
Intel boards carpcguy Classified Archive 15 10-14-2006 09:17 PM
Shuttle sv24 or fv24 michael_16j General Hardware Discussion 6 06-05-2006 03:56 PM
