Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com
Old 06-14-2009, 06:33 PM   #1
Carz is an unknown quantity at this point
Infill G4 wiring harness connector
Is the wiring harness connector to Infill G4 a standard type where I can get it from any audio workshop or is it a specific one that I can order?
I'm looking to remove my G4 from the dash to work from home but w/o pulling out the the cables that are already crimped so I've to leave the original connector in the car intact with the cables.
Carz is offline   Reply With Quote
Old 06-16-2009, 11:10 PM   #2
Deric's Avatar
Deric is an unknown quantity at this point
If you have the G4 harness connected to say a metra harness that plugs into your original stereo harness (follow-that?) it might be easier to go to a junkyard and cut the radio harness and plug the adapter into it to bench test.
Deric is offline   Reply With Quote
Old 06-17-2009, 03:25 AM   #3
Hi Deric,
Thanks for replying.
I'm not sure I get you cos I don't have much background in electrical wiring stuffs and car audio wiring.
Perhaps I do not know how to describe it better to begin with to receive help I can understand. Let me try again.
From what I can see, the cables that originate from the car do not have the original connector intact (I opted w/o default stereo when I bought my car) but rather the ends are crimped to the ends of the G4 wiring harness and in turn the G4 plastic connector on the harness connects to the G4. Hope I make sense. What is the industry standard name for this plastic connector so I can refer to it correctly. Is this connector a standard fit for most if not all car stereo that I can purchase from car audio shop? I know I'll have to match the pinout of the G4 to get the the 12v, acc and ground to work on the bench.
Otherwise, without the connector, what can I do to power up the G4 on the bench if I want to avoid recrimping each time I take the G4 in and out of my car.
I'm hoping the short answer is yes, the connector is a standard fit and I can get it from most car audio shop.
Sorry for being such a noob.
Old 06-20-2009, 11:05 AM   #4
Deric's Avatar
There are kits available that let you plug into your factory stereo harness without cutting the connections.
This harness is a bridge between the factory harness and the Infill harness. If you don't have one of these in your setup and the infill was either crimped or soldered directly to the factory harness I would cut the connections and replace them with male and female spade connectors
This would allow you to easily remove the unit from car and connect it on the work bench.
Hope this helps
Old 06-29-2009, 07:42 PM   #5
Thanks Deric! I will seek local shops to get something like these.
Old 07-02-2009, 10:28 AM   #6
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
For the spade connectors he listed-- just make sure you electrical tape the metal connection, otherwise, they could short out on other spade connections, and that could cause all sorts of problems..
soundman98 is offline   Reply With Quote
Old 07-02-2009, 06:42 PM   #7
I was thinking about it and went online to search that there are those with insulators.
Cheers!
Infill G4 buzzing. adri3an Car Audio 2 06-02-2008 02:55 AM
Will Infill G4 fit VW Golf IV??? TRONiC Mp3Car Infill G4 - Double Din Car Computer 4 01-26-2008 03:58 AM
First impressions, bugs and features of Infill G4 & Street Deck 1.1.0.0 DAE51D StreetDeck 34 11-06-2007 03:42 PM
How does Streetdeck know it is on an Infill G4, and how do I disable that? drakino StreetDeck 7 08-13-2007 07:15 PM
Req DVD functions from Infill G4 in CF SUNAJ Centrafuse 1 07-26-2007 12:49 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
