After spaceman's question about eject cd button not found, i tried toi do it in neocarscript.
And it WORKS !
So, here's how to do it:
1. create a blank NCS using a text editor
2. copy/paste this code
Code:
' EXAMPLE NEOCAR SCRIPT
'INFORMATIONS
NAME=Eject CD/DVD Script
AUTHOR=netsuo
DATE=2005.04.19 08:15:00
DESCRIPTION=Eject the CD/DVD Rom
EXECUTE=FUNCTION:Eject DVD/CD-Rom
' FUNCTION:XXX : XXX is your function's name. While setting this, never executed but added to the actions list. You can then access this function using buttons actions in skin.xml (Example: <ACTION>SCRIPTS_FUNCTION;your_function_name</ACTION>)
' NMC_START : executed while starting NMC, after loading skin and config
' NMC_CLOSE : executed while stopping NMC
' MODULE_START:XXX : executed on start of desired module (where XXX is one of the following: ALL/APPLICATIONS/VIDEO/AUDIO/PHOTOS/FILELIST/MAIN)
' MODULE_CLOSE:XXX : executed on start of desired module (where XXX is one of the following: ALL/APPLICATIONS/VIDEO/AUDIO/PHOTOS/FILELIST/MAIN)
' TRACK_START:XXX : executed when track starts playing (where XXX is one of the following: APPLICATIONS/VIDEO/AUDIO/PHOTOS)
' TRACK_END:XXX : excuted when track ends (where XXX is one of the following: APPLICATIONS/VIDEO/AUDIO)
' TIMER : executed in a timer with "100" msec interval
' IMPORTANT NOTE : you can combine EXECUTE events by adding a "|" seperator. Example: MODULE_CLOSE:AUDIO|MODULE_START:AUDIO
'START CUSTOM SCRIPT
'-> here between "START" and "END" you can enter any VBScript code. (see NCS reference for objects available)
NCS_START
'Use WMP to eject CDRom
Set oWMP = CreateObject("WMPlayer.OCX.7")
Set colCDROMs = oWMP.cdromCollection
if colCDROMs.Count >= 1 then
For i = 0 to colCDROMs.Count - 1
colCDROMs.Item(i).Eject
Next
End If
NCS_END
3. Copy the file in scripts folder
4. Open NPC and select the button you want to become "EJECT CD/DVD"
5. Dble-click on it
6. In actions list, select "SCRIPTS_FUNCTION"
7. Choose your function in the combobox
8. Save skin.
9. Run NMC, click on your button and... YEAH
Hope you like it, it shows the power of NCS
