Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > NeoCar Media Center
Old 06-13-2005, 01:34 PM   #1
netsuo's Avatar
Preview: NMC Hardware Control
Here's a preview of my current work for my own carPC: a hardware control module.
Images a better than words, here's a video showing my Velleman K8055 USB Interface card in NMC.
Im using ONLY neocarscript to manage the custom module you will see in the video.
http://www.danstagueule.ch/forumStuf...re_control.avi
NS - neocar suite
http://www.neocarmediacenter.com
netsuo is offline   Reply With Quote
Old 06-13-2005, 02:13 PM   #2
karifan's Avatar
that's awesome! you´re crazy man!
that is everything which was still missing in my car!
Will it be possible to access the interface with own script functions?
sure I think! but you have to give us code samples about using the DLL with NCS..!
karifan is offline   Reply With Quote
Old 06-13-2005, 02:24 PM   #3
netsuo's Avatar
I will give all my work about this thing
All will be possible. For now, my first NCS is to show actual values of IN/OUTs of the card.
Another one is starting amplifier at audio start, and dislabing it at NMC close.
I will do a "temperature" regulator starting fans upon CPU or mainboard overheating.
Everything is possible with NCS. The "hardware control" module is a custom module created with NPC and managed ONLY with NCS.
With next version you will be able to create any module you want, as in this video
NS - neocar suite
Old 06-14-2005, 01:27 AM   #4
NiN^_^NiN's Avatar
ohhhh im gonna have fun with this
so many ideas i have must find time to make them but this is a great feature it's more feature packed that almost all frontends now
Sorry to go offtopic but how's the FD Module going? and how soon till we get to test the new nmc
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 06-14-2005, 03:28 AM   #5
netsuo's Avatar
As soon as i finished it
Seriously, i don't know. I'm developping as i can, slowly. I'm more interested on doing my own carPC these days..
NS - neocar suite
Old 06-15-2005, 09:16 AM   #6
I saw a phone icon, does that mean you are going to integrate mobiles too ?
Think I'm gonna buy a Velleman kit too, but first have to learn to program a bit I suppose.
Veeery nice done.
Car : Hyundai Tucson
Carpc :
Lilliput 7" touchscreen indash 90% done
PSU : M2-ATX
Epia M10K /512DDR/80GB Maxtor
Software : Windows XP Pro 100% done
RR with DigitalFX skin
In car : 80% done
gyro is offline   Reply With Quote
Old 06-16-2005, 04:25 AM   #7
NiN^_^NiN's Avatar
Could each of these buttons launch a exe?
No trying to embed it just launching a EXE file.
If so then alot of hardware devices and other things could be used if u create a batch file or whatever and have it run in the background then close itself.
Altho the only issue i have with nmc is the video playback i know thats being fixed but everything else is running smoothly altho im still working on my external webcam app to record into a divx file while driving (sitting on the dash right now)
i've got it working but it's using windows dialogs when you save the divx file so im trying to bypass that but for now it works.
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 06-16-2005, 05:02 AM   #8
netsuo's Avatar
FOr the 13783 time: ALL IS IN NCS IN THIS MODULE. So all can be made..
NS - neocar suite
Old 06-16-2005, 07:08 AM   #9
NiN^_^NiN's Avatar
oh yeah sorry my brain is fried with this webcam thing
I get you now
For anyone who doesn't know NCS is scripts which uses VB Script/ WSH Scripts so it can launch exe etc.
It can do quite a bit but it is a scripting language so it is limited.
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 06-16-2005, 07:13 AM   #10
karifan's Avatar
@NiN^_^NiN
you could already start or close easily an exe or a batch file in the background with NCS..
with something like:
Code:
Set WSHShell = CreateObject("WScript.Shell") WSHShell.Run """'C:\Program Files\app\app.exe"""
Old 06-16-2005, 08:52 AM   #11
karifan's Avatar
have you taken a look at sourceforge.net...? there are many interesting projects about capturing webcam source...
I have done this with java/jmf .. works fine.. but hard to setup..
Old 06-16-2005, 09:06 AM   #12
NiN^_^NiN's Avatar
actually i've just got it all working and with a NMC skin
Only problem is i can't set the compression
have to use the windows dialog to use divx otherwise it's raw video and thats just HUGE
Least there is a 3bg limit on the file tho.
I'll release a demo soon for ppl to test in NMC or standalone
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 06-16-2005, 12:27 PM   #13
karifan's Avatar
yeah and therefore I suggest you, to use 'VLC media player'!
You can make everything with that tool..
e.g. starting your webcam source through 'vlc command line options' as an external application in NMC.. hope netsuo will fix that cmd bug
a command like:
Quote:
c:\vlc.exe dshow:// :dshow-vdev="PC Camera (6005 CIF)" :dshow-adev="Intel(r) integriertes Audio" :no-dshow-size="320x240" :dshow-config :no-dshow-tuner
note:the 'PC Camera (6005 CIF)' is the WDM driver name of my Webcam
looks like:
or you can simply start-transcoding/close vlc in background with NCS with every available decoder and bitrate on your machine, to capture the output in a file.. with options like:
Quote:
c:\vlc.exe dshow:// :dshow-vdev="PC Camera (6005 CIF)" :dshow-adev="Intel(r) integriertes Audio" :dshow-size="320x240" :dshow-config :no-dshow-tuner :sout=#transcode{vcodec=mp4v,vb=1024,scale=1,acode c=mpga,ab=192,channels=2}:duplicate{dst=std{access =file,mux=ts,url="C:\output.mpg"}}
vlc is very simple and have guis to create that code above.
@netsuo, sorry to gone offtopic too but its kind a 'hardware control' too
Old 06-16-2005, 01:24 PM   #14
Jeep's Avatar
Video ??
Hi!
What codec did you use to make the video? I only get audio, no video.
Why not make a WindowsMedia file, it's smaler and needs no special codecs to play. http://www.microsoft.com/windows/win...r/default.aspx
Jeep is offline   Reply With Quote
Old 06-16-2005, 01:39 PM   #15
netsuo's Avatar
No problems on offtopic !!
I'm very happy with your tests on NCS !! Give me mooooore
EDIT: i forgot to say that hardware control is up and running in my car
NS - neocar suite
CarPC Remote Control feature liquid_smoke PhoneControl 174 04-06-2005 02:21 AM
NMC 07 development status netsuo NeoCar Media Center 15 11-03-2004 03:18 AM
USB FM/AM tuner with RDS/RBDS Seth General Hardware Discussion 333 08-29-2004 06:02 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 01:42 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 10:43 AM
