Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > NeoCar Media Center
Old 07-17-2005, 04:04 PM   #1
How to add GPS support?
Hi there,
I´ve been searching on the forum about this topic with no luck. I would like to use mapmonkey embeded into NeoCar the same way you can do so with RR... is that possible?
Thnx
eduardovdr is offline   Reply With Quote
Old 07-17-2005, 10:50 PM   #2
NiN^_^NiN's Avatar
it's possible im at work so i'll tell you how to do it if no1 else does by the time i get home.
you should look at the external.xml file in the app folder (atleast i think thats right)
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 08-07-2005, 07:57 AM   #3
try this >> (make some changes for destinator like the drive and filename)
<?xml version="1.0" encoding="ISO-8859-1"?>
<application>
<!-- Path to the application -->
<chemin>C:\FreeDrive\FreeDrive.exe</chemin>
<!-- Command line -->
<ligne_commande></ligne_commande>
<!-- Preview image -->
<apercu></apercu>
<!-- Window finding text -->
<texte_recherche>free drive 0.85</texte_recherche>
<!-- Description -->
<description>gps freedrive</description>
<!-- Run embedded "in-skin" -->
<run_embedded>0</run_embedded>
<!-- Show application always on top of other -->
<ontop>0</ontop>
<!-- Remove borders of the app. Just set offset for Top,Right,Bottom,Left -->
<borders_remove>30,5,5,5</borders_remove>
<!-- Allow multiples instances for application -->
<allow_multiple_instances>1</allow_multiple_instances>
</application>
Make it a xml file and open through applications
No one got it working through the GPS button by the way?
redbrains is offline   Reply With Quote
Old 08-08-2005, 01:09 PM   #4
Got it... When I push the GPS button freedrive starts!! NICE
Old 08-08-2005, 10:02 PM   #5
NiN^_^NiN's Avatar
just a quick note i would change
to:
<texte_recherche>free drive</texte_recherche>
just so when u update the exe file and the version number changes from 0.85 you won't have to edit the xml file
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 08-09-2005, 06:41 AM   #6
to:
it is the window finding text and I tried it with another app
(soundcontrol) and the xml file still says free drive 0.85 but it is working!
So it's ok like this.
It's nicer to do it your way.
cheers
Old 08-09-2005, 08:33 AM   #7
NiN^_^NiN's Avatar
it is working cause your loading that app i think it actually locks the app quicker to NMC if the window text is the same as the app.
Not to sure about that netsuo will have to tell us.
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 08-13-2005, 11:51 PM   #8
how do you link it to the GPS button?
WhiteRabbit is offline   Reply With Quote
Old 08-14-2005, 04:51 AM   #9
NiN^_^NiN's Avatar
open up the light skin in NMC skin editor then click on all the GPS icons on each seperate page (main, audio, video etc pages)
double click on the gps buttons on each seperate page and a properties page opens up
select EXTERNAL_APPLICATION_LOAD under the short press action
Then next to it you can select the XML file that launches the gps program
Hope this helps you
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 08-14-2005, 06:03 PM   #10
it did. works like a champ, thanks!
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 01:24 PM
Proper Installation of GPS Receiver ummagawd GPS 5 04-22-2005 11:07 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 01:34 AM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 05:08 PM
Music and GPS Michael Szilagyi GPS 1 02-28-2003 02:26 AM
