Go Back   MP3Car.com > Mp3Car Technical > MacCar > Neon Boombox
Old 05-14-2008, 10:16 AM   #46
hanzov69 is an unknown quantity at this point
And while the messages get older and older, this seems to confirm that this is not a bug:
Tim Monroe speaks again.
hanzov69 is offline   Reply With Quote
Old 05-14-2008, 12:46 PM   #47
NeonDev's Avatar
NeonDev is an unknown quantity at this point
thank you very much. that answers that. At this time playing protected movies is not possible at this time. Doesn't make much sense why they would provide support for music but not movies.
I could use that second link you provided to remove DRM video from the NBB library so that it doesn't even show up if you guys would like
check us out at: www.neonboombox.com
NeonDev is offline   Reply With Quote
Old 05-14-2008, 01:27 PM   #48
The only thing I can figure is this:
It is impossible to completely lock down audio with DRM. There a ton of utilities (and even old fashioned analog ways) to make perfect (or near perfect) copies of audio recordings without "breaking" the DRM.
DRM video on the other hand is a little easier to control. To the best of my knowledge, there is no easy way to make a lossless (or near lossless) copy of a DRMd video through analog or digital means, and they probably want to keep it that way.
It also occurs to me that with all the anti-trust stuff going on in the EU regarding Apples "monopoly" in the digital music realm, they can use the QTKit as an argument that they provide an "open" way to enable playback of purchased audio.
Conversely, Apple doesn't have a portable video stranglehold, so it's ok (from a litigation liability standpoint) to keep the video more restrictive.
Of course, this is all wild speculation
While I don't know what the effort would be like, perhaps rather than quietly removing DRMd video, perhaps it could get a little lock icon or the like, so that people understand that the video is there, it's just not playable. Maybe add a pref to hide "locked" video.
(At the rate I am throwing in my two cents, I am going to be a poor man!)
Old 05-14-2008, 01:58 PM   #49
golfguy's Avatar
golfguy is an unknown quantity at this point
I'd prefer just to not see items I can't play from the interface.
I wonder how Front Row does it? Apple must have a private API.
Any day is a good day for golf.
Mazdaspeed6 Carputer Progress:
(Check Speedy's Install)
Purchase [*****] 100%
Design [*****] 100%
Install [*****] 100% (Stable for now...)
golfguy is offline   Reply With Quote
Old 05-14-2008, 02:42 PM   #50
NeonDev's Avatar
well apple undoubtedly can decode the DRM video in any application they create they just don't have a public way of doing it like they do with the music. so yes it seems they have a private interface, and perhaps alot of googling may reveal somebody who has found out how to use it.
to my knowlege front row, itunes, and quicktime are the only apps capable of decoding DRM video. even other apple apps cannot.
Old 05-14-2008, 03:53 PM   #51
NeonDev's Avatar
looks like some people got close before they fell mysteriously silent.
http://www.mackb.com/Uwe/Forum.aspx/...ay-drm-ed-file
I wouldn't count on it happening without apple being the provider of the API which doesn't seem likely. DRM ****es me off so much. look at it only punish those of you who pay; its not fair. I guarantee you no pirates using NBB are having trouble watching their videos!
well the itunes.xml has a "protected" field that i can use to filter out videos that are protected. release 9 will no longer show protected videos at all.
Old 05-17-2008, 04:52 PM   #52
HEAVY8HITTERS is an unknown quantity at this point
well the application didn't crash but, in the music module where you select the artists NBB has created about 12 of the same artist (Nas) and is displaying the exact same content under each one. I checked itunes and nothing seems wrong so i checked front row and everything is under 1(Nas). So im not to sure. what do you think?
O never mind i fixed it some how
HEAVY8HITTERS is offline   Reply With Quote
Old 05-17-2008, 06:11 PM   #53
NeonDev's Avatar
yeah NBB doesn't "create" any thing in its library. it reads the iTunes library file. Usually when artists and the like appear duplicated it is because of a space at the end of one of the song tags or a capitalization issue as NBB is case sensitive at the moment but iTunes is not.
Old 05-21-2008, 01:34 PM   #54
golfguy's Avatar
In both release 9 versions I have had problems with the audio control row. In 9a the pause/play control did not appear in the row, but still worked when touched. In 9b the pause/play now appears but the forward control does not, and likewise still works when touched. Have you had any other reports of similar behavior?
Design [*****] 100%
Old 05-21-2008, 05:04 PM   #55
NeonDev's Avatar
no I haven't. that is a bit interesting. I would say it may have something to do with the button effects I was trying to integrate but that would only affect 9B and on.
I plan on releasing 9C late tonight/early tomorrow maybe that will mysteriously help.
what resolution are you on? also, open the console and see if there are messages about missing graphics.
Old 05-21-2008, 09:50 PM   #56
golfguy's Avatar
I have a Lilliput EBY701 at 800x480. I checked the console and the only NBB items were unhide and hide mouse events.
Design [*****] 100%
Old 05-22-2008, 12:18 AM   #57
NeonDev's Avatar
i know there are more messages than that posted...
i'm completely stumped. I even dropped my res down to 500x600 (the closest i can to 480x800). everything works perfectly for me. can you test it on another system or on a higher res? 800x600 maybe...
on another note I completely screwed up the guts of NBB tonight while working on some cool new things and it will take me another day or two in order to get a release out
Old 06-04-2008, 01:10 AM   #58
pepsibobby's Avatar
pepsibobby is on a distinguished road
No matter what resolution i run the program at, it opens up and then unexpectedly quits. I can get you a crash log if i knew where they were.
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
pepsibobby is offline   Reply With Quote
Old 06-04-2008, 01:34 AM   #59
NeonDev's Avatar
crash log should be at ~/library/logs/crash reporter
console output is even more valuable then crash logs. just open up the console application and copy and paste the output from NBB here and I can probably figure it out.
I going to have to ask if you are running leopard since if you are not you will get the same result.
Old 06-04-2008, 10:47 AM   #60
pepsibobby's Avatar
Boombox.app/Contents/MacOS/Neon\ Boombox ; exit;
2008-06-04 16:46:00.911 Neon Boombox[15944:10b] initializing dial...
2008-06-04 16:46:00.938 Neon Boombox[15944:10b] observing modules...
2008-06-04 16:46:00.967 Neon Boombox[15944:10b] keyboard create:x:0.000000, y:182.857147, w:2560.000000, h:765.291016
2008-06-04 16:46:00.972 Neon Boombox[15944:10b] ModuleController initialized...
2008-06-04 16:46:01.238 Neon Boombox[15944:10b] custom slider awake
2008-06-04 16:46:01.486 Neon Boombox[15944:10b] unhide mouse
2008-06-04 16:46:01.487 Neon Boombox[15944:671b] loading (9) module(s)...
2008-06-04 16:46:01.567 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:01.583 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:01.584 Neon Boombox[15944:10b] remaining button count:10 module:<PXGamesModuleController: 0x21c530>
2008-06-04 16:46:01.584 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:01.585 Neon Boombox[15944:10b] module:PXGamesModuleController index:0
2008-06-04 16:46:01.586 Neon Boombox[15944:10b] button added
2008-06-04 16:46:01.669 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:01.679 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:01.680 Neon Boombox[15944:10b] remaining button count:9 module:<PXGPSModuleController: 0x16a23a60>
2008-06-04 16:46:01.680 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:01.681 Neon Boombox[15944:10b] module:PXGPSModuleController index:1
2008-06-04 16:46:01.682 Neon Boombox[15944:10b] button added
2008-06-04 16:46:01.756 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:01.791 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:01.792 Neon Boombox[15944:10b] remaining button count:8 module:<PXInternetModuleController: 0x16a22670>
2008-06-04 16:46:01.792 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:01.792 Neon Boombox[15944:10b] module:PXInternetModuleController index:2
2008-06-04 16:46:01.794 Neon Boombox[15944:10b] button added
2008-06-04 16:46:01.803 Neon Boombox[15944:671b] initializing movie controller
2008-06-04 16:46:01.803 Neon Boombox[15944:671b] opening iTunes XML
2008-06-04 16:46:02.034 Neon Boombox[15944:671b] using location:~/Music/iTunes/iTunes Music Library.xml
2008-06-04 16:46:02.034 Neon Boombox[15944:671b] iTunes XML opened
2008-06-04 16:46:02.036 Neon Boombox[15944:671b] dividing library tracks
2008-06-04 16:46:02.041 Neon Boombox[15944:671b] checking for ready modules... 0 ready but not enabled
2008-06-04 16:46:02.042 Neon Boombox[15944:671b] module ready notification posted
2008-06-04 16:46:02.223 Neon Boombox[15944:671b] Unknown Window class PXVisualizerWindow in Interface Builder file,
creating generic Window instead
2008-06-04 16:46:02.477 Neon Boombox[15944:671b] custom slider awake
2008-06-04 16:46:02.544 Neon Boombox[15944:671b] awaking movie controller
2008-06-04 16:46:02.544 Neon Boombox[15944:671b] actions set
2008-06-04 16:46:02.546 Neon Boombox[15944:671b] movie module awoken
2008-06-04 16:46:02.549 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:02.804 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:02.804 Neon Boombox[15944:10b] remaining button count:7 module:<PXMediaViewerController: 0x16a0f9c0>
2008-06-04 16:46:02.805 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:02.805 Neon Boombox[15944:10b] module:PXMediaViewerController index:3
2008-06-04 16:46:02.807 Neon Boombox[15944:10b] button added
2008-06-04 16:46:02.823 Neon Boombox[15944:671b] initializing music controller
2008-06-04 16:46:02.824 Neon Boombox[15944:671b] opening iTunes XML
2008-06-04 16:46:03.054 Neon Boombox[15944:671b] using location:~/Music/iTunes/iTunes Music Library.xml
2008-06-04 16:46:03.055 Neon Boombox[15944:671b] iTunes XML opened
2008-06-04 16:46:03.107 Neon Boombox[15944:671b] toggle shuffle
2008-06-04 16:46:03.108 Neon Boombox[15944:671b] /Users/bobby/Desktop/Neon Boombox.app/Contents/Resources/Modules/PXMusicModule.module/Visualizers/
2008-06-04 16:46:03.184 Neon Boombox[15944:671b] custom slider awake
2008-06-04 16:46:03.553 Neon Boombox[15944:671b] custom slider awake
2008-06-04 16:46:03.728 Neon Boombox[15944:671b] awaking music controller
2008-06-04 16:46:03.729 Neon Boombox[15944:671b] selection changed
2008-06-04 16:46:03.729 Neon Boombox[15944:671b] browser level set
2008-06-04 16:46:03.730 Neon Boombox[15944:671b] music module awoken
2008-06-04 16:46:03.738 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:04.288 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:04.288 Neon Boombox[15944:10b] remaining button count:6 module:<PXMusicController: 0x1bdf7700>
2008-06-04 16:46:04.289 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:04.289 Neon Boombox[15944:10b] module:PXMusicController index:4
2008-06-04 16:46:04.291 Neon Boombox[15944:10b] button added
2008-06-04 16:46:04.297 Neon Boombox[15944:c81b] checking for ready modules... 1 ready but not enabled
2008-06-04 16:46:04.299 Neon Boombox[15944:c81b] enabled a waiting module... 0 still waiting
2008-06-04 16:46:04.312 Neon Boombox[15944:c81b] module activaited without wait
2008-06-04 16:46:04.312 Neon Boombox[15944:c81b] module ready notification posted
2008-06-04 16:46:04.425 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:04.499 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:04.500 Neon Boombox[15944:10b] remaining button count:5 module:<PXPhoneModuleController: 0x1b262850>
2008-06-04 16:46:04.500 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:04.501 Neon Boombox[15944:10b] module:PXPhoneModuleController index:5
2008-06-04 16:46:04.503 Neon Boombox[15944:10b] button added
2008-06-04 16:46:04.640 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:04.647 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:04.648 Neon Boombox[15944:10b] remaining button count:4 module:<PXPhotoModuleController: 0x16a37240>
2008-06-04 16:46:04.648 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:04.649 Neon Boombox[15944:10b] module:PXPhotoModuleController index:6
2008-06-04 16:46:04.650 Neon Boombox[15944:10b] button added
2008-06-04 16:46:04.663 Neon Boombox[15944:671b] channel table:0 rows
2008-06-04 16:46:04.876 Neon Boombox[15944:671b] An uncaught exception was raised
2008-06-04 16:46:04.877 Neon Boombox[15944:671b] *** -[NSCFArray objectAtIndex:]: index (0) beyond bounds (0)
2008-06-04 16:46:04.878 Neon Boombox[15944:671b] *** Terminating app due to uncaught exception 'NSRangeException', reason: '*** -[NSCFArray objectAtIndex:]: index (0) beyond bounds (0)'
2008-06-04 16:46:04.878 Neon Boombox[15944:671b] Stack: (
2494812747,
2490994939,
2494812203,
2494812266,
2519307231,
2518774296,
509310106,
11650,
2518795693,
2518794580,
2502659157,
2502658834
Trace/BPT trap
logout
[Process completed]
Yes I am running leopard. I have all updates as well. 10.5.2
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
