Go Back   MP3Car.com > Mp3Car Technical > MacCar > Neon Boombox
Old 06-04-2008, 11:59 AM   #61
NeonDev's Avatar
NeonDev is an unknown quantity at this point
if you navigate to NeonBoombox/contents/resources/modules and delete the radio module it should finish launching. the only reasons I can think that would be crashing are that either you aren't using the latest download (available only in the update thread, not on the site) or you have either an XM radio attached or another USB serial device that the radio module has mistaken for a radio
check us out at: www.neonboombox.com
NeonDev is offline   Reply With Quote
Old 06-04-2008, 12:05 PM   #62
pepsibobby's Avatar
pepsibobby is on a distinguished road
That works. Good job. Quick response. YEAH!!!!!
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
pepsibobby is offline   Reply With Quote
Old 06-06-2008, 10:29 AM   #63
golfguy's Avatar
golfguy is an unknown quantity at this point
Been using NBB daily for a month now and I want to thank you for some great work. I'm really pleased with the software and especially your progress. I continue to have the problem with the control buttons disappearing with this release. Now it is the reverse control that is missing (previously the pause/play and then the forward). As previously, the the touch target still works properly, so function is not impaired, the control image just does not show up in the bottom bar. I'll check the log when I get a chance, but that's the only functional bug I have right now.
Once again, awesome job, keep up the good work.
Any day is a good day for golf.
Mazdaspeed6 Carputer Progress:
(Check Speedy's Install)
Purchase [*****] 100%
Design [*****] 100%
Install [*****] 100% (Stable for now...)
golfguy is offline   Reply With Quote
Old 06-06-2008, 10:47 AM   #64
NeonDev's Avatar
well thank you for your support.
I definitely need to figure that out but you are the only one that I have heard having that problem... farther more if it is not always the same ones missing that doesn't point to a damaged bundle like I had previously suggested. I think Ill tweak the NIB today and put up a minor release with that and some apple remote fixes.
Edit: think I have the problem figured out. it is probably the same problem I am having with the main screen dial. it is core animation related and I don't yet know how to fix it. I have however disabled the core animation layer on the track details screen which will prevent the problem. obviously when I do actually need to use core animation on that screen (which I will, I have some sweet things planned) I will have to re-enable it. hopefully by then I will know how to fix it.
I do want to know why you are the only one reporting it.... What computer do you use? maybe it is related to the chronic Macbook and macbook pro graphical glitches.
Old 06-20-2008, 12:15 AM   #65
crzunch is an unknown quantity at this point
Command: Neon Boombox
Path: /Users/Crzunch/Desktop/Neon Boombox.app/Contents/MacOS/Neon Boombox
Parent: WindowServer [68]
Version: ??? (PublicRelease7)
PID: 602
Thread: Unknown
Link (dyld) error:
Library not loaded: /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
Referenced from: /Users/Crzunch/Desktop/Neon Boombox.app/Contents/MacOS/../Frameworks/NeonBoomboxSDK.framework/Versions/A/NeonBoomboxSDK
Reason: image not found
THIS IS MY CRASH ERROR LOG
crzunch is offline   Reply With Quote
Old 06-20-2008, 12:32 AM   #66
NeonDev's Avatar
NBB is crashing because the quicklook framework isn't loaded. I suspect that you are running mac os x 10.4 or earlier. NBB requires 10.5. If you are in fact running 10.5 you have something seriously wrong with your install and will likely need to reinstall your system
Old 06-20-2008, 09:32 AM   #67
no i have 10.4 lol where i can i get 10.5 ive looked all night is that one i need to buy
Old 06-20-2008, 10:19 AM   #68
NeonDev's Avatar
yeah I recommend ebay. you can nab a copy for less than $100
Old 07-02-2008, 08:39 AM   #69
hanzov69 is an unknown quantity at this point
NeonBoomBox 1.0RC 3
Mac Mini
-OS X 10.5.4
-2.0ghz Core2 Duo
-1gb Ram
-800x600
Bugs:
#1 NBB doesn't seem to save Volume state between launches. It will always restart with Volume at Full. (Update: Yes it does. Sometimes. Seems sporadic..?)
#2 If playing a video, pause video, return to pane view.
Restart video. Screen will go black. Right click -> "Play" will start video, but audio only. Still black screen.
Normal CMD-Q will exit app normally, otherwise it's "stuck".
#3 (minor) Track info does not appear at the top of Modules, Date/Time only
#4 On Screen Keyboard - Keys are cropped along top edge, close button is compressed/overlapped
Crash:
This is reproducible on my end, however it may be linked to the way I am using NBB.
Steps to Reproduce:
Launch NBB, play any music, stop music, then attempt to play Video. NBB crashes.
If no music has been played, video will play without issue.
Specific considerations:
I am operating my Mac Mini via "Screen Sharing" or "Apple Remote Desktop". This occurs in both instances (not certain, but I believe both use VNC for access, so it's the exact same).
My set up is not such that I can dedicate a monitor/mouse/keyboard to the Mini (yet).
nbb-crash.tar
hanzov69 is offline   Reply With Quote
Old 07-02-2008, 10:00 AM   #70
Also:
Info.plist reports it as 1.0 RC 1 (overlooked internal update, or is the server linked to wrong version?)
Old 07-02-2008, 10:32 AM   #71
NeonDev's Avatar
the volume in the options window is the system volume so if you change your system volume between launches it will obviously be different, but if you like I can save the volume state and restore it on relaunch. if you are referring to the track volume, I am not saving that either, tho I am using the volume setting from the first song played, but I am totally willing to save that info between launches as well.
I was completely unaware of this bug thank you for pointing that out. expect a fix in the next release. I'll prolly try and get rid of that contextual menu too (didn't even know that came up).
yes that has been temporarily disabled.
yeah I do all my programming and testing on a larger monitor so that hasn't really been an issue for me. I will fix that soon.
Crash:
Steps to Reproduce:
Indeed that does crash NBB! news to me and I don't have a clue as to why at the moment, but I expect to be able to fix it by the next release as well. I suspect this and the other movie player bug are perhaps related
BTW yes the version info is wrong, I have a terrible track record of remembering to change that. expect that to be fixed in the next release too
Old 07-02-2008, 10:36 AM   #72
No worries, if you don't mind the bug reports, I don't mind filing them
Have you considered setting up a slightly more formal bug tracking system? Maybe Trac (or even a super basic wiki)?
Old 07-02-2008, 12:31 PM   #73
NeonDev's Avatar
yes i would very much like to do that but as you can tell from visiting our site it is a shambles and nobody has had much time to put it back together yet alone implement new features on it... seriously tho keep up the bug reports i don't yet have a car pc so i don't get to do much real world testing.
Old 07-02-2008, 06:11 PM   #74
hammer32 is on a distinguished road
Got a quick crash log from today with the new build. I was in the music function selecting a song to play when it crashed:
Process: Neon Boombox [109]
Path: /Applications/Neon Boombox.app/Contents/MacOS/Neon Boombox
Identifier: com.Project-X.NeonBoombox
Version: ??? (1.0 RC 1)
Code Type: X86 (Native)
Parent Process: launchd [77]
Date/Time: 2008-07-02 17:04:29.336 -0500
OS Version: Mac OS X 10.5.3 (9D34)
Report Version: 6
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Crashed Thread: 5
Application Specific Information:
objc[109]: FREED(id): message readTimeoutAsTimeval: sent to freed object=0x1baed430
Thread 0:
0 com.apple.QuickTime 0x9431d856 _ZeroOutMoviesError + 0
1 com.apple.QuickTime 0x941b21f1 EnterMovies + 11
2 com.apple.QTKit 0x940f3575 +[QTMovie initialize] + 54
3 libobjc.A.dylib 0x922acb78 _class_initialize + 367
4 libobjc.A.dylib 0x922ab4f9 _class_lookupMethodAndLoadCache + 81
5 libobjc.A.dylib 0x922bb736 objc_msgSend + 102
6 com.apple.AppKit 0x945e3c23 -[NSApplication sendAction:to:from:] + 112
7 com.apple.AppKit 0x945e3b60 -[NSControl sendAction:to:] + 108
8 com.Project-X.NeonBoomboxSDK 0x0002ed76 -[PXBrowserTableView sendAction:to:] + 277
9 com.apple.AppKit 0x9462bb5f -[NSTableView _sendAction:to:row:column:] + 271
10 com.apple.AppKit 0x94629ec9 -[NSTableView mouseDown:] + 8228
11 com.apple.AppKit 0x9466cfe7 forwardMethod + 113
12 com.apple.AppKit 0x945e088b -[NSWindow sendEvent:] + 5381
13 com.Project-X.NeonBoomboxSDK 0x0002a694 -[PXWindow sendEvent:] + 240
14 com.apple.AppKit 0x945ad431 -[NSApplication sendEvent:] + 2941
15 com.Project-X.NeonBoombox 0x0000a834 -[PXApplication sendEvent:] + 390
16 com.apple.AppKit 0x9450ae27 -[NSApplication run] + 847
17 com.apple.AppKit 0x944d8030 NSApplicationMain + 574
18 com.Project-X.NeonBoombox 0x000027f6 start + 54
Thread 1:
0 libSystem.B.dylib 0x9151968e __semwait_signal + 10
1 libSystem.B.dylib 0x9154436d pthread_cond_wait$UNIX2003 + 73
2 libGLProgrammability.dylib 0x91cac432 glvmDoWork + 162
3 libSystem.B.dylib 0x915436f5 _pthread_start + 321
4 libSystem.B.dylib 0x915435b2 thread_start + 34
Thread 2:
2 com.apple.CoreVideo 0x93584687 CVDisplayLink::runIOThread() + 1087
Thread 3:
2 com.apple.QuartzCore 0x92536e51 fe_fragment_thread + 54
Thread 4:
0 libSystem.B.dylib 0x915124a6 mach_msg_trap + 10
1 libSystem.B.dylib 0x91519c9c mach_msg + 72
2 com.apple.CoreFoundation 0x94d930be CFRunLoopRunSpecific + 1806
3 com.apple.CoreFoundation 0x94d93cf8 CFRunLoopRunInMode + 88
4 com.apple.audio.CoreAudio 0x934d6464 HALRunLoop::OwnThread(void*) + 160
5 com.apple.audio.CoreAudio 0x934d6300 CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x915436f5 _pthread_start + 321
7 libSystem.B.dylib 0x915435b2 thread_start + 34
Thread 5 Crashed:
0 libobjc.A.dylib 0x922abeba _objc_error + 116
1 libobjc.A.dylib 0x922abef0 __objc_error + 52
2 libobjc.A.dylib 0x922aa8f7 _freedHandler + 58
3 com.Project-X.NeonBoomboxSDK 0x00031e41 -[AMSerialPort(AMSerialPortAdditionsPrivate) readAndStopAfterBytes:bytes:stopAtChar:stopChar:er ror:] + 283
4 com.yourcompany.PXRadioModule 0x1a5c15ba -[PXRadioModuleController readNextRadioDataIntoBuffers] + 357
5 com.yourcompany.PXRadioModule 0x1a5c174a -[PXRadioModuleController updateAllChannelsInfo] + 280
6 com.yourcompany.PXRadioModule 0x1a5c11cb -[PXRadioModuleController initializeRadio] + 370
7 com.apple.Foundation 0x96ff1f1d -[NSThread main] + 45
8 com.apple.Foundation 0x96ff1ac4 __NSThread__main__ + 308
9 libSystem.B.dylib 0x915436f5 _pthread_start + 321
10 libSystem.B.dylib 0x915435b2 thread_start + 34
Thread 5 crashed with X86 Thread State (32-bit):
eax: 0x1baeb310 ebx: 0x922abe57 ecx: 0x1baeb310 edx: 0x1baeb360
edi: 0x1baed5a0 esi: 0x923841e8 ebp: 0xb022fb18 esp: 0xb022fad0
ss: 0x0000001f efl: 0x00010286 eip: 0x922abeba cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0xffe1736c
Thanks,
Sean
hammer32 is offline   Reply With Quote
Old 07-02-2008, 06:32 PM   #75
NeonDev's Avatar
Ah i see you were using the radio ;-).
you wouldn't happen to have the console output from the time of the crash would you?
also is this crash reproduce-able?
I can honestly say I have never gotten a program to crash by sending a "bad instruction" to the CPU before
(BTW there will be a new build of the radio module this week as well as 1.0 RC 4)
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
