ha ha don't thank me for the visuals thank apple (and chris for the aSTARisk)
but thank you anyway I am really pleased with them too. I hope the rumored visualizer in iTunes 8 is a QC visualizer so I can add a link to that as well.
Quote:
The Now Playing strip along the top gets a little cut off as well. Making that a few more pixels wider would be friendly to my fingers.
Im a bit confused as to what is getting cut off... I don't see it in your shot. are you talking about the ticker on the browser screen?
I will look into the button problem and should be able to fix it next build
Quote:
Finally, I'm not real crazy about filling the timeline scrubber behind the scroll thumb. I like the wide scrubber, but I prefer it unfilled. The white doesn't look right with all the rest of the darker colors. That's just me, though.
It wouldn't be hard to make it a preference. I prefer it filled myself but I may as well add an option in the theming engine.
I have adjusted the screen shown above for the next build. mostly just nudging things to look better. I did make the slider draw its outline using the font color settable in the main app prefs I don't know if that will make it look better for you or not. Obviously if you are going to use a white font color then it wouldn't help
should have a new build out early next week that will allow actual theme bundles to provide some presets and will stop washing out the controls when somebody opens NBB for the first time
. there won't be a way to define presets from inside NBB but you will be able to manually create an XML file and bundle it and install it the same way as modules are installed.
