01-31-2008, 09:45 AM
#1
Vehicle: 98 VW Golf
Crash Logs and Bug Reports (and any other program tomfoolery)
Did Neon Boombox misbehave? We would like to know about it! If you could post your crash log here it would be greatly appreciated!
a crash log can be found>>> ~/library/logs/crashreporter/project-x...
02-02-2008, 03:40 AM
#2
Vehicle: 2007 Subaru Outback 2.5i AT BiFuel
I'm sorry being the first one!
Anyway, I would like to test your nice looking Neon Boombox but my MacBook Pro (with an italian Leopard Mac OS X) refuses to run it. Attached you can find the crash log.
Hope you can help!
Thanks.
02-02-2008, 03:03 PM
#3
Vehicle: 2005 Saturn Ion
Thank you DeltaBi for your interest in NeonBoombox.
I cannot tell from the crash log why you are unable to launch our program (the program crashes somewhere in apples frameworks, not in my program itself). I suspect that either your itunes XML file is corrupt or has improper permission (or perhaps NeonBoombox itself has been set with faulty permissions), or something to do with your italian localization. If you could please open your console app in your utilities folder and post the output after trying again to launch NeonBoombox and I'm sure I can be of more assistance.
02-02-2008, 03:15 PM
#4
Vehicle: 99/pontiac/transAm
neon boombox crash
hi i am having the exact same problem on the same machine (macbook pro) but without the italian localization. here is the log that appeared in the console:
2/2/08 3:11:41 PM Project-X[14966] initializing dial...
2/2/08 3:11:41 PM Project-X[14966] ModuleController initialized...
2/2/08 3:11:41 PM Project-X[14966] loading (9) module(s)...
2/2/08 3:11:41 PM Project-X[14966] appdelegate attempting to insert to dial...
2/2/08 3:11:41 PM Project-X[14966] remaining button count:12 module:<PXGamesModuleController: 0x16b990>
2/2/08 3:11:41 PM Project-X[14966] loaded module: com.Project-X.PXGamesModule
2/2/08 3:11:41 PM Project-X[14966] remaining button count:11 module:<PXGPSModuleController: 0x1d28b0>
2/2/08 3:11:41 PM Project-X[14966] loaded module: com.Project-X.PXGPSModule
2/2/08 3:11:41 PM Project-X[14966] remaining button count:10 module:<PXInternetModuleController: 0x1dda80>
2/2/08 3:11:41 PM Project-X[14966] loaded module: com.Project-X.PXInternetModule
2/2/08 3:11:41 PM Project-X[14966] remaining button count:9 module:<PXMediaViewerController: 0x119d50>
2/2/08 3:11:41 PM Project-X[14966] loaded module: com.Project-X.PXMediaViewer
2/2/08 3:11:41 PM Project-X[14966] initializing music controller
2/2/08 3:11:43 PM com.apple.launchd[71] ([0x0-0x1c41c4].com.Project-X.Project-X[14966]) Exited abnormally: Segmentation fault
hope this helps, and i hope a fix comes soon! i am very excited to try and use this software!
02-02-2008, 03:28 PM
#5
yeah the crash comes somewhere in the music module init process so it surely must have something to do with the itunes xml (i hope) will you please delete it then open itunes and quit itunes to recreate it. then check the permissions on it and try again. In the mean time i will step up the error checking and reporting in the music module init and post a build here that will help me better understand where the problem is.
thank you guys for helping out with getting this thing off the ground. expect a new build tonight, and hopefully a fix shortly after
02-02-2008, 03:56 PM
#6
I tried after a rebuild of the itunes xml file, but the crash persisted.
However with an empty iTunes library the application starts without any problem.... I'll try to understand if the crash depends on some attributes of the MP3 files.
02-02-2008, 04:05 PM
#7
ok anybody having the trouble described above please download this build and post your console output for me please. (only download and post this builds output if you are in fact having this very problem please)
02-02-2008, 04:07 PM
#8
ok i need to figure out how to post an attachment apparently. I do have a theory that the crashing is related to foreign characters in the file name... or one of the other file attributes. can somebody verify this?
02-02-2008, 05:35 PM
#9
i cant verify that, but i did download the previous build you just posted and here is the log from the console here it is:
2/2/08 5:33:24 PM Project-X[15050] initializing dial...
2/2/08 5:33:24 PM Project-X[15050] ModuleController initialized...
2/2/08 5:33:24 PM Project-X[15050] loading (9) module(s)...
2/2/08 5:33:24 PM Project-X[15050] appdelegate attempting to insert to dial...
2/2/08 5:33:24 PM Project-X[15050] remaining button count:12 module:<PXGamesModuleController: 0x1cdbc0>
2/2/08 5:33:24 PM Project-X[15050] loaded module: com.Project-X.PXGamesModule
2/2/08 5:33:24 PM Project-X[15050] remaining button count:11 module:<PXGPSModuleController: 0x1d8420>
2/2/08 5:33:24 PM Project-X[15050] loaded module: com.Project-X.PXGPSModule
2/2/08 5:33:24 PM Project-X[15050] remaining button count:10 module:<PXInternetModuleController: 0x1dff50>
2/2/08 5:33:24 PM Project-X[15050] loaded module: com.Project-X.PXInternetModule
2/2/08 5:33:24 PM Project-X[15050] remaining button count:9 module:<PXMediaViewerController: 0x1ea530>
2/2/08 5:33:25 PM Project-X[15050] loaded module: com.Project-X.PXMediaViewer
2/2/08 5:33:25 PM Project-X[15050] initializing music controller
2/2/08 5:33:25 PM Project-X[15050] opening iTunes XML
2/2/08 5:33:27 PM com.apple.launchd[71] ([0x0-0x1cb1cb].com.Project-X.NeonBoombox[15050]) Exited abnormally: Segmentation fault
once again, hope this helps!
02-02-2008, 05:43 PM
#10
so here is a genius idea I just had. how about people having this post their iTunes XML files, if you all don't mind. It will be alot easier for me to track the problem if I have a copy of one that makes Neonboombox crash
02-02-2008, 11:44 PM
#11
here is a copy of my itunes xml file i hope you can find something in there!
02-03-2008, 01:25 AM
#12
well i can tell you this much. it is definitely something in the xml file that makes it crash. i am investigating. get back to you as soon as I have an answer
02-03-2008, 07:38 PM
#13
Resolved (hopefully)
ok lets give this build a try and see if it works
edit: forgot to reset something so while it would launch it would not work propperly I have done that now and this build should now work
02-04-2008, 03:00 PM
#14
ok that build did work. thanks for the help
02-04-2008, 03:02 PM
#15
Vehicle: 98 VW Golf
Thank you for YOUR help!
| Thread Tools |
| Display Modes |
Linear Mode
