Go Back   MP3Car.com > Mp3Car Technical > Newbie > Newbie - Proposed setup
Old 02-18-2009, 01:02 AM   #1
ibm_jennifer is an unknown quantity at this point
My Car PC setup with M4 ATX
Friends,
I have bought a M4 ATX Power supply and decided to go with the following config. for my new Car PC. Please let me know will 250w enough for this and also provide your suggestions.
Motherboard: Gigabyte GA-EG31MF-S2
Graphics: Sappire HD 4350 512 MB
RAM: 2*1 GB DDR2 RAM
Proc: Intel E6700
HDD: 300GB Seagate SATA 7200.8
Wi-Fi+Bluetooth 2 in 1 adapter
3MP CCD Webcamera
16GB USB Pen Drive
So my question, will the above setup can be handled by M4-ATX? If I connect any DVD Drive or 60mm fans, will it be OK?
Any suggestion for a better processor like E7300/Q6600 over this?
ibm_jennifer is offline   Reply With Quote
Old 02-18-2009, 01:20 PM   #2
WuNgUn's Avatar
WuNgUn is on a distinguished road
What are you using for sound??
Your likely going to run ito problems, especially if you use PCI sound card.
One word: OPUS
WuNgUn is offline   Reply With Quote
Old 02-18-2009, 01:23 PM   #3
jhowle is an unknown quantity at this point
um depending on your climate i would stick with a lower power setup and one that generates less heat. I chose and intel board with the atom chip integrated, im using the onboard sound and video with 256md of video ram, 2 gig ddr2 memory, and 16 gig SSD hard drive etc etc and my machines run of less then 1.5 amps and runs cool even with ambiant heat in the car. OPUS or Mini-Box are great but im going to tell you that if your gonna run a quad core cpu with the choice of video card you made you gonna need more power then a M4 ATX can give you.
My desktop is a quad cored and i have an equivelant geforce 9800 and i use a 650 watt power supply and it runs at peak all the time so if your trying to use a 300 wat M4 ATX i would see if you can put 2 in there cause you will need both
jhowle is offline   Reply With Quote
Old 02-18-2009, 01:36 PM   #4
I am not limited by the space factor as I can install 10 more desktop PCs in my car boot(its TATA SAFARI). So I choose a Micro ATX Cabinet.
Currently I am not going to use any Sound card, but may be a ASUS Xonar in future if power permits.
The graphics card is a low profile one and it takes only 20w at maximum load.
The Motherboard is the best energy efficient one and my proc is Core 2 Duo E6700/7200. As per the review in http://www.tomshardware.com/reviews/...1,2039-13.html the motherboard and proc takes maximum of 70w at full load.
Will I am fine? Should I need to switch to a 2.5" SATA HDD instead of a 3.5" HDD?
Will I need to use E7200 instead of E6700?
Old 02-18-2009, 01:44 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Not so much the load of the PCI card as the vibration. Just make sure you have it bolted down firmly. I've dealt with several threads over the past years where they thought the hard drive was bad and it turned out to be a PCI card or power connection.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 02-18-2009, 01:52 PM   #6
miko55's Avatar
miko55 is an unknown quantity at this point
No need for such proc power. Use a MB which has most of the stuff integrated.
Slovenia, Europe
best on-line radio
miko55 is offline   Reply With Quote
Old 02-18-2009, 01:59 PM   #7
No plan for external sound card now.
The motherboard is an energy efficient one and as per http://www.tomshardware.com/reviews/...1,2039-13.html the board with E7200 will take only 70w at max. load.
The graphics card is a fanless low profile card and it takes only 25w at maximum load.
So I have 150w left.
Will I need to use a 2.5" HDD instead of the 3.5" HDD?
And the external USB Hub is self powered. Will I need to change to E7200 instead of E6700 (I have a spare E6700 with me!!!)
No friend, I cant trust the atom proc. as I will do some graphics works, need to run two external headrest monitors (dual display).
Old 02-18-2009, 02:43 PM   #8
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Thread moved, new topic was added to the Newbie section.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 02-19-2009, 10:58 AM   #9
Firends,
I bought a new 10.4 touchscreen LCD Display today. It has a film attached to the screen with lot of bubbles. It looks weird and ugly. Is it the protective film or anything for the touchscreen functionality? Can I remove the film, will it affect the functionality of the touchscreen. please guide me.
Old 02-19-2009, 11:32 AM   #10
Tidder's Avatar
It sounds like it's the cling wrap type of plastic cover to protect the screen. You can remove it.
Tidder
Try RevFE
Best Quote EVER!!
Old 02-21-2009, 05:33 AM   #11
Sir,
I have tried to remove the plastic cover from the screen. But its sticked permanently and not coming out? Is it something like protection film? But it looks weird and cant live with this. Please check the attached photo:
The big image:
http://img10.imageshack.us/img10/7484/imga2491.jpg
Old 02-21-2009, 05:51 AM   #12
Tidder's Avatar
Why not contact the people that you bought it from? It still looks like a protective film to me, but maybe you should contact them?
Tidder
Try RevFE
Best Quote EVER!!
Old 02-21-2009, 06:29 AM   #13
Its a chineease product and they have no idea about it(?). Is it possible to remove the protective film from the screen?
Old 02-21-2009, 07:33 AM   #14
Tidder's Avatar
If the seller doesn't know, do you really expect someone here to?
Maybe you should start by linking to the seller page, or giving a brand name... you know, some real information about the screen.
Other than that, you tell us. Is it possible to remove it?
Tidder
Try RevFE
Best Quote EVER!!
Old 03-23-2009, 02:37 PM   #15
rijk is an unknown quantity at this point
Quote: Originally Posted by ibm_jennifer View Post
Sir,
Looks like you pealed a bit in the lower left corner. Is it sticky on the screen where you took the protective film away, or clean. If its clean than its just a protective cover and you can take the rest of as well. If it is a sticky surface than your not meant to take it off.
The difficult in getting it off is also because it has a static charge.
rijk is offline   Reply With Quote
New to Car PC, here is my setup. BarinaHum Newbie 6 11-06-2006 09:16 PM
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 06:15 PM
