Go Back   MP3Car.com > Mp3Car Technical > Newbie > Newbie - Proposed setup
Old 04-10-2009, 09:47 AM   #1
MichaelPlace is on a distinguished road
Wiring Diagram
Hi all, just thought I'd post my planned wiring diagram. The m2ATX is in the boot, there is a single piece of 7 core running down the drivers side of the car.
I want to completely attach the 7" screen's 4 wires to the M2-ATX. So that if i remove the whole system from my car to fit in another one I only need to wire in 3 wires for the M2-ATX. The screen will then still be wired in to the m2 ATX in the PC - Nice and simple.
cheers for any help!
MichaelPlace is offline   Reply With Quote
Old 04-10-2009, 01:26 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Thread moved to proposed setups.
To answer your question, if you mean that you will wire the screen to the M2's 12v pos output, expecting it to work only when the computer is turned on, the answer is yes. Just make sure you calculate the loads on each rail of the M2 to keep from overloading the 12v rail with the screen.
Also, I think -12v is the same thing as ground but you should check this with a multimeter.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 04-10-2009, 01:30 PM   #3
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
You should verify that your screen needs -12v, the m2 does indeed put out -12 volts with respect to ground, but that seems VERY odd that the screen would require -12volts.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 04-10-2009, 01:31 PM   #4
My screen needs 4 inputs:
* Earth
* +12
* -12
* Ignition
What I'm asking is: For the 'ignition' can I just use the same +12v feed from the M2 ATX as I use on the +12v input?
Are you saying I won't need to wire in a -12v?
Old 04-10-2009, 01:32 PM   #5
hang on just a sec i'll take a picture of the wiring diagram I've been given...
Old 04-10-2009, 01:33 PM   #6
malcom2073's Avatar
* Earth
* +12
* -12
* Ignition
If it uses ignition to know when to turn the screen on, yes you can use the +12v feed from the M2ATX.
I'm not saying you won't need a -12V, I just said it's very odd that a screen would require that, cars do not usually have -12v (with respect to ground), so by that logic there is NO way to hook this screen up without an ATX power supply of some sort.
That's just odd, do you have a datasheet for your screen we can look at? I'm willing to bet it's expecting ground for that instead of -12v. Bad documentation perhaps.
Old 04-10-2009, 01:45 PM   #7
oh you guys are brilliant, it's my mistake, it is two x grounds not a -12v
this is the connector:
is there a difference between the green wire ground and the black wire ground?
Old 04-10-2009, 01:46 PM   #8
malcom2073's Avatar
Whew! That could have been a bad mistake. plugging the -12V into a ground would provide the screen with 24 volts potential, and probably blow more than just the power supply. Glad you got it sorted out
Old 04-10-2009, 01:49 PM   #9
It's going to be my brother who wires the thing in (5 years experience at an auto electricians!) so he would have put me right. I just wanted to make sure I understood what was going on!
Cheers,
next question - Do i need to add any other Fuse on this system, there is one on the input to the screen - as you can see. Do I need to fuse the input to the M2-ATX?
Old 04-11-2009, 05:27 PM   #10
skeet2331's Avatar
skeet2331 is on a distinguished road
You always want to fuse the line within 18 in of the battery. Even less is better. the M2-atx will have a 15 amp fuse built in.
Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
My 2000 Saturn SL2 Worklog
skeet2331 is offline   Reply With Quote
Old 04-12-2009, 07:09 AM   #11
Probably obvious next question, what type of fuse should I buy? Any links would be gratefully received
Wiring diagram for Laptop with H701 and Crux controller. Suggestions appreciated Startingline13 Newbie 0 12-05-2008 03:32 PM
Wiring Diagram Audio and Component on a Jetta VW 2000 volfiregon Car Audio 9 08-02-2007 05:02 PM
AutoPage 860 + 2000 Honda Civic Wiring diagram Help! pcmofo Hardware Development 4 01-14-2007 07:19 PM
Wiring diagram for Opel Corsa wade Car Audio 0 10-10-2005 04:56 AM
datalux 4x20 red lcd wiring diagram? etrik LCD/Display 0 12-07-2001 04:35 PM
