My setup so far
Hi all.
After much reading on these forums I have started my project. This is where I am up to now:
Intel DG945GCLF
1gb memory
250gb SATA laptop drive
M2-ATX supply
GPS receiver (installed in front window, but it looks more like an alarm thing)
Centrafuse software (with Igo-pc)
Mobile broadband dongle
Still deciding on what screen I should get (lilliput or Xenarc)
Up to now I have installed the wires required. I have a 4g wire (fused near battery) running to a 4 way distribution block, down to 8g wire powering 2 amps (this has been like this for the last 5 years, so this is running fine). These are earthed together at the back of the car.
Then running a 15amp (16g) power cable to the M2-ATX from the distribution block. The earth for this is just connected to the body of the car (16g wire).
I also have the IGN cable from the M2 running to a kill switch so I can stop the Pc from firing up if needed.
I'm just awaiting delivery of my Voom box then I can connect it all up!
I'm going to install a RJ45 connection as well (somewhere) and a USB hub so I can transfer files etc.
How does this all sound up to now? Any suggestions?
Oh the car is a Nissan pulsar (Almera) N16 series one hatchback.
Cheers all
Jonathan
Reason: Added model of Intel board
