Go Back   MP3Car.com > Mp3Car Technical > Newbie > Newbie - Proposed setup
Old 05-12-2009, 07:05 PM   #1
03BlackoutSSS is an unknown quantity at this point
here is what I am thinking...
Instead of doing what I normally do, buy a whole bunch of new stuff, and build a good whatever, I have an old tower that I no longer use. Its an Emachines E2615...the following info from the sticker on the tower...
Athelon XP Processor
120G HD Ultra DMA
3D S3 Graphics Pro Savage 8
512K DDR
I would like to go about starting this Car PC the monetary frugal method and use whatever I have currently. I plan on building a new box out of fiberglass(fully vented, are there any drawbacks to using fiberglass), to reposition the components so I can put them somewhere discreet inside the cab.
I know that I will need a new power supply. Is there anything special I should know about the power supply because of the HD that I plan on using?
Also, will the video card be able to support the newer LCD screen and things like that?
I will have more questions very soon.
Thanks fellas.
03BlackoutSSS is offline   Reply With Quote
Old 05-13-2009, 10:27 AM   #2
corc is an unknown quantity at this point
I'm hoping you meant to put 512MB DDR? Only 512K of memory will severely damper your ability to do well...anything. The video card should be able to support newer LCDs but you will get a significantly decreased quality of video, especially if you plan on playing things like MP4s, AVIs, and DVDs.
corc is offline   Reply With Quote
Old 05-13-2009, 11:13 PM   #3
yeah, nice catch. 512MB is what I meant. As for my intent with the machine...basic stuff. Not a movie buff, just a normal functioning puter. Nav, satellite/mp3 audio, possible rev camera, autowolf (or similar) and bluetooth.
My only concern is my ability to do all that at once, should I feel the need to? What would I need to change to get the multi-taskability out of this machine?
Old 05-14-2009, 12:51 AM   #4
Multitasking comes primarily from the memory available with your machine, but the processing power helps. Could you be more specific as to the type of Athlon in your computer? Upgrading the memory would definitely not hurt. DDR RAM is incredibly cheap these days and could give you the extra boost you need.
However, the computer you have will probably work just fine for the time being and should be easily upgradeable later should you need it.
Old 05-14-2009, 06:07 AM   #5
nalav's Avatar
nalav is on a distinguished road
A trimmed down Linux install would be able to do everything you want with those specs easily. A Windows install would need at least more memory, and possibly a better cpu depending on which model you have. 512mb memory just wouldn't be enough for that on Windows.
Pretty sure there never was a 512kb DDR stick
nalav is offline   Reply With Quote
Old 05-14-2009, 08:46 AM   #6
lbergamo's Avatar
lbergamo is an unknown quantity at this point
Hello,
I kinda did what you were describing. Check out my post if you want...
http://www.mp3car.com/vbulletin/show...-vanputer.html
lbergamo is offline   Reply With Quote
Old 05-14-2009, 05:46 PM   #7
Nice work. The basic idea is exactly the same, however I want to go the route of factory installed look. But thats basically what I am going for.
Old 05-14-2009, 05:52 PM   #8
As for the processor, whatever came stock in an Emachines E2615. regarding the OS, what if I was to setup windows XP or Vista (I have discs for both) to run effectively nothing on startup, only what is required and boot straight into a different front end? Would that still absorb too much memory to be able to run multiple tasks? If I am not mistaken, I think I can double the memory currently in there. I think there is one bay, with a 512 stick in there, which I can replace with a 1024 (if its available). I imagine that would help, no?
Old 05-15-2009, 08:21 AM   #9
Ramb0_Command0's Avatar
Ramb0_Command0 is on a distinguished road
yea I would suggest putting 1024 in if you can, ram is one of the cheapest and most cost effective ways to increase the speed of your computer.
You can run xp on 512, you just can't do anything very fast.
I would definitely go ahead and install XP, you could try disabling some services you don't need look here for more info, look at the table a ways down under the tweaked column.
The video card should be fine too, most screens are run at around 800x600 so its not exactly Hi-Def or anything. You probably won't be able to run visualizations or movies or anything very well, but it will get the job done for music.
Car PC status
Got a new car... Suffering from withdrawal/separation anxiety.
I'd give it about 2 weeks before I have a computer up in the dash ;)
Ramb0_Command0 is offline   Reply With Quote
Old 05-19-2009, 05:42 PM   #10
Here is another question...
I have an 03 Silverado SS. Installed right now is the Pioneer AVH P4000. Now when I installed this thing, I had to get a some magic box that would allow me to retain the door chime, and airbag (one specific function that I can't remember at the moment).
If I was to remove the head unit in favor of a touch screen, but left the magic box in there, would I retain all the funtions, or does the box have to be connected to a head unit.
What I would prefer to do is use the screen on the head unit as the interface for the computer. The only input that I remember being there that I could se working for me is a USB Port. Is this a possibility or a dream?
Old 05-19-2009, 06:14 PM   #11
lbergamo's Avatar
Hello,
Could you give some more details in regards to this "magic box".
Thank You
Leo
Old 05-19-2009, 06:29 PM   #12
here is the head unit...
http://www.crutchfield.com/p_130AVHP...p4000&tp=20217
and the "magic box"...
http://www.bestbuy.com/site/olspage....=1218018676185
Old 05-21-2009, 11:13 AM   #13
Yea It looks like you should be able to plug the rca cables from that box into the input of the sound card, you would need a RCA -> 3.5mm(headphone jack) adapter. Or you could leave the audio output not plugged in and not have the dinger.
The only issue to that would be if you had an onboard sound card that only has 3 jacks and you have it set to 5.1 mode, then it usually switches the input to the rear speaker output. But if you got a soundcard then you would definitely be able to do it.
Also the sound wouldn't only come out of the speaker when the computer is on.
Another option would be to put the output from that box directly into your amps, using a RCA Y cable with two inputs and one output. That way the sound would come out whether or not the computer was on.
Car PC status
Ok so I am thinking about taking the plunge Valhalla MacCar 4 06-30-2006 08:46 PM
Thinking of trashing the MII12000 and getting a 2Ghz Celeron miztahsparklez General Hardware Discussion 11 06-22-2006 11:46 PM
Thinking Of Getting New Car [HoP] General Hardware Discussion 0 05-13-2006 11:10 AM
Thinking about going manual.. Song0330 Off Topic 79 02-21-2006 04:34 PM
Tricking the head unit into thinking the mp3car is a cd changer SeenaStyle General Hardware Discussion 1 05-02-2000 01:06 AM
