Go Back   MP3Car.com > Mp3Car Technical > Newbie > Newbie - Proposed setup
Old 06-04-2009, 02:17 PM   #1
Vzeed9oo is an unknown quantity at this point
Lightbulb CarPC budget challenge
Ok Car gods,
I have a challenge for you. I'm looking to set up a car pc in my new 2010 Camaro. Here are some things that it MUST have:
Flip down monitor
BluTooth suppot
GPS receiver
Wireless Internet to link to my home network
DVD/CD support
Ipod jack
Auto startup/shutdown
5.1 surround sound support
Optional but preferable:
A/V jack for optional gaming system
Voice Control system
The challenge is my budget. I want to build it for under $800. I've posted this on a few other forums and gotten some interesting responses. I best so far has been:
1. VMI70 7inch IN-DASH VGA touchscreen Here - $280
2. Intel BOXD945GCLF w/ an integrated 1.6ghz Atom - Newegg.com - $65
3. 1x2gb DDR2 800 Ram - Newegg.com - $23
4. M1-ATX 90 Watt PSU - mp3car.com - $75
5. BU-353 Weather-proof GPS Receiver - mp3car.com - $38
6. cirago BTA-3210 USB 2.0 Micro Bluetooth Dongle - newegg.com - $15
7. Ampie Car Computer Case - mp3car.com - $70
8. Fujitsu MHW2080BJ 80GB 7200 RPM 2.5" SATA - newegg.com - $40
9. Rosewill RNX-G1W 802.11b/g usb adapter - newegg.com - $20
10.NEW Grand total - $625
EDIT: I forgot to mention that I already have the speaker assembly and amp covered through the Boston Acoustics 5.1 system that came with the car. I will also be using a USB dvd player for the initial set up, then sharing a drive on my home network to do future loads.
Darque: Great call on the touch screen, I missed that it didn't have vga. Let me know what you think of the above. No dvd player, but it is 1 din and has vga
What do you think?
Vzeed9oo
Vzeed9oo is offline   Reply With Quote
Advertisement Sponsored links
Old 06-04-2009, 10:33 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
That touchscreen will not control the PC.
Furthermore, you'd need composite video signal to go to that headunit and the motherboard you specified doesn't have a composite video out. Even if you get a device to convert the VGA signal to composite, the image quality will be at a low resolution and look sub-par at best.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-04-2009, 10:52 PM   #3
Flaring_Afro's Avatar
Flaring_Afro is an unknown quantity at this point
you'll need a center speaker for a true 5.1 sound effect. also, you'll probably need an aftermarket amp to connect it to your sound system too.
and then im not sure where you plan on mounting the screen because it doesnt look like you will be able to mount a single din or screen and make it look right....
EDIT: You also forgot a slot load dvd player. if you want something that can play dvds and not just cds it'll cost you. i think it'll beat least $80 for that, plus another 100 (at least) for the amps.
Acer Netbook with 160hdd and 1.60 Ghtz atom - to be installed
Flaring_Afro is offline   Reply With Quote
Old 06-05-2009, 07:06 AM   #4
5.1 surround is pointless in a car, at least in many peoples' eyes.
The OP didn't spec out any speakers at all.. No sub.. No left/right/front/rear or center.
The OP did spec a DVD headunit that would cover CD/DVD playback.
It's not a good solution at all, which I pointed out. But he DID cover that part of the build.
Old 06-05-2009, 10:05 AM   #5
I agree I dont think theres a point, but he said he wanted it. Also, I highly doubt the camaros come with a "5.1" system. It might have something like an 8 speaker setup, but i doubt it actually has a center speaker in the dash (could be wrong).
Look into the factory amp if you havent too. It might only have a high input (non rca) that a computer cant put out. Just because its called "bouston acoustic" doesnt mean it wil be like their aftermarket amps or even made by them. The "bose" systems arent really bose either. Just a heads up.
Old 06-06-2009, 02:42 AM   #6
djfourmoney is an unknown quantity at this point
Troll Maybe?
No replies since his/her's post and have you even seen the Camaro's dash layout before starting a food fight over 5.1 audio?
Is there even a dash kit available???
I haven't seen a new Camaro inside yet, especially one with factory Navigation which I'm positive is an option.
Nobody has any idea what were working with here, so why comment????
djfourmoney is offline   Reply With Quote
Old 06-06-2009, 12:05 PM   #7
^ no of course there isnt a dash kit available the car was only sold for a few months. that doesnt mean anything though. as i mentioned it would be hard but its possible to get a screen in there. he might even plan on a whole new custom dash for all you know. the camaro costs as much as a vette so people with them tend to have a good amount of money.
Old 06-06-2009, 02:29 PM   #8
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Darque is correct, neverrrrrrrrrrrrrrrrrrrrr use RCA, the quality will be so bad. I know that you had a budget, but if you can have a screen molded into the dash.
Agree on the slot load DVD. Also when you have to add programs, the DVD slot will come in handy.
I 100% disagree. I had 5.1 with center being phantom (what most Car PC use), and when I finally installed a real center, i could hear a difference. When I decided to upgrade to 7.1 surround sound the difference was even greater. All that was with cr@ppy amps. I cant wait to see how it all sounds on PDX amps and good speakers.
LOL OMG.... Couls they have made a more awkward dash. Its nice that its retro, but d@mn...... I do have an idea.... Maybe you can go with dashboard devices visor screens, that way no dash mods are needed, here is the link.
When you go to the page scroll down to the ENV-50c. All you would have to do is put the main part of the unit maybe in the glove box, then the screen as the driver visor.
http://www.dashboarddevices.com/products.htm
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 06-07-2009, 03:05 AM   #9
The camaro is less than half the cost of a vette and just about half with the options
Old 06-07-2009, 04:27 PM   #10
^ almost every dealer was selling the V6 for over $36k, and the V8 for a lot more. There have been many threads circling around forums with people asking if they should get a C6 or a V8 camaro.
Old 06-08-2009, 09:11 AM   #11
Supply and demand kinda sucks right now, especially with the car companies. MSRP direct from factory price is about $24,600 for the V6 and $31,000 for the v8. Still more expensive than the challenger and the mustang though
Old 06-12-2009, 04:10 PM   #12
asplodzor's Avatar
asplodzor is an unknown quantity at this point
Quote: Originally Posted by Vzeed9oo View Post
1. VMI70 7inch IN-DASH VGA touchscreen here - $280
Uh guys? I don't know if Vzeed9oo edited this post after you all were talking about Composite RCA connections, but screen linked is VGA compatible... it even comes with a VGA cord.
From the ebay listing:
Quote:
Features:
7" TFT LCD XGA/VGA touchscreen color display
Resolution 720x400 to 1280x1024 (Native resolution: 800x480)
WIDESCREEN 16:9 aspect ratio
PAL/NTSC
Mount Type: in-dash (1-DIN)
Video Input: XGA/VGA input (15 pin D-SUB)
2 RCA video inputs
Display brightness (with touchscreen): 400cd/mē
6 month warranty
No radio built-in
asplodzor is offline   Reply With Quote
Old 06-12-2009, 04:22 PM   #13
asplodzor's Avatar
What do you think?
Vzeed9oo
Oh geez, I is stoopid twofold - I somehow completely missed this part of the OP, and I'm still in the moderated comments limbo, so I can't edit my post immediately. Oh well.
Old 07-06-2009, 04:09 PM   #14
HumungousBacon's Avatar
HumungousBacon can only hope to improve
My question is if you just bought a 2009 camaro which are going for around like $30000 why the need for a "budget" pc lol. well i guess if you spent all your money on the car lol.
HumungousBacon is offline   Reply With Quote
Old 07-06-2009, 04:36 PM   #15
smcnally is an unknown quantity at this point
I'm brand new here and researching equipment myself. I'm also trying to spend as little as possible but not go so cheap that I wind up upgrading 2 months from now
One thing I noticed about the parts list though is this...
When you take these 4 items (the barebones PC components) you really aren't saving any money by buying the parts...especially when you are paying shipping from 2 different suppliers.
For about $20 more you could get THIS barebones kit, have a faster atom processor, and double the RAM.
smcnally is offline   Reply With Quote
Tags
budget, camaro, challenge, proposed
Carpc for 500.00? possible? 20tibby_gt06 Newbie 20 09-09-2008 02:09 AM
?'s about a new CarPC for a Scion tC. MadAsHell Newbie 0 11-30-2006 01:44 PM
1965 VW Beetle - Low budget CarPc jbk Worklogs 6 08-25-2006 06:49 AM
For Sale: CarPC EZ v.2.5d stevent76 Classified Archive 0 12-23-2005 09:55 PM
CarPC Gets BLACKOUT! when monitor is connected! Sympotonic General Hardware Discussion 25 12-08-2005 04:30 PM
