I'll try to answer what I can, but you may want to browse the FAQ for a good start
http://www.mp3car.com/vbulletin/advfaq.php
Quote: Originally Posted by
Petrie
I look at the mp3car store at their computer bundles and it looks like I only get a ruggedized PC. If I take that, is the AM/FM audio missing? Some of their nice enclosures, don't look like they can handle the FM tuner.
I'm not sure which PC bundle you're looking at, but it would need something like
http://store.mp3car.com/HQCT_1_0_Hig..._p/com-009.htm for radio. Personally, I would go with an HD Radio with MJS Cable
http://www.mp3car.com/vbulletin/user...hlight=mitchjs
The Directed DMHD1000 or Visteon HDZ300 will work with mitch's cable. The Directed unit is cheap
http://www.amazon.com/DIRECTED-DMHD1...7286433&sr=8-1
approx $60 + 25 for the cable is much cheaper than the HQCT.
Petrie
On the FM tuner, I don't see where it connects to the external arial.
If you go with the HQCT, you will need a wiring kit
http://store.mo-co-so.com/hqctiwiringkit-p-96.html
It includes the Motorola adapter which you can plug a standard motorola antenna connector into.
http://store.mo-co-so.com/index.php?...roducts_id=110
You may need an adapter to convert your car antenna plug into motorola. Not sure about the exact details of your car but this is a subaru adapter that is available:
http://www.amazon.com/dp/B000K53QAQ/...0&linkCode=asn
Look around for what will fit your car.
If you go with HD Radio, it also accepts a motorola connection.
Petrie
If this has the usual PC outputs how do you hook up to the factory 20+ pin plug for the speakers.
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
not sure what the pinout is for your plug, but I got a wiring harness and connected directly to my factory amp with RCAs as outlined in the above FAQ. You can check out crutchfield to find a wiring harness that fits your car.
You can find some other STI projects here to get help. You can also go to your car specific forums for audio help.
Petrie
At the moment, I cannot figure out if RoadRunner or RideRunner is available for download and where to get it which is why I'll probably go with Centrafuse as the front end over XP.
http://www.nisuautomotive.com/catalo...php?cPath=2_22
May take more to setup, but it's free. I'm using Centrafuse and am happy with it.
Petrie
I can see that Centrafuse have support for phones but how does that tie in with the mp3car computers?
You will need a bluetooth dongle. I use
http://store.mo-co-so.com/100m330usb...iant-p-64.html
Works great with Centrafuse.
