G'day,
This is my first post here and I'm afraid it's going to be a long one. My name's sckeLL and I'm from Victoria, Australia. I don't currently have a car pc but have been reading about them here and at other places for the last few months. I'm a PC enthusiast and a geek. I have no car/engine knowledge and very limited electronics knowledge. I'm also a hobbiest C# developer, and have been looking at Centrafuse and will hopefully be able to contribute something to the community once I get up and running.
The reason I want a car PC is for storing and playing a lot of music; storing data and a portable internet connection (I work on the field in IT, and don't currently have a laptop); development; GPS (I get lost a lot).
So what I'm hoping is to have as many sensors in the thing as I can for playing around with and logging data, including thermometers, accelerometer, ODBII, etc.
My car is a 2000 Mitsubishi Magna (nothing special).
http://users.cyberone.com.au/twistie/car09001.jpg.
I like it because it's black.
A couple of months ago, in preparation for this, I upgraded the stock CD player to a 5 channel amp in the boot (F/R/Sub). Currently there's just a MP3/CD head unit plugged in to the Cadence FXA-5100.
At the moment there's a fat wire running from the battery to the amp. The 'remote on' (or acc) cable is running to both the amp in the boot and the head unit.
So here's what I've picked out:
PC
Boot:- M4-ATX 250W Intelligent DC-DC PSU
- Intel BLKD945GCLF2D Mini-ITX Motherboard with Integrated Atom™ Processor
- Major Brand 320GB 2.5" SATA Hard Drive
- 2GB DDR2 DIMM 800MHz, PC2-6400 RAM
- Fusion Brain Version 4.0
Front:- Slot load DVDR USB
- Unknown monitor.. see below.
Sensors, Etc
- In/on Parcel rack:- BU-353 Weather-proof GPS Receiver
- Fusion Photosensor
- Fusion Accelerometer (see if i can pull 0.1Gs!)
- Fusion Thermometer
- WiFi 802.11b/g USB Mini-Adapter
- Bluetooth receiver
- Wireless broadband dongle
- Some USB hubs
- Exterior:- Fusion Thermometer
- Ultrasonic Distance Sensor (Front and Rear)
- Front:- ElmScan 5 Bluetooth OBD-II Scan Tool 422000
- USB Hub(s).
As far as software goes, I'll be using Windows 7 (probably 32 bit due to the 2gb ram limitation on the MB) and Centrafuse (most likely with custom plugins).
I'm planning to mount a panel in to the parcel shelf to plug in all the USB dongles.
I'm not too sure where I'm going to mount the PC at this stage, but I don't think I'll have too much trouble there (The boot is already useless due to a gas tank and the amp/sub anyway).
Now as this is quite an ambitious (and excessive
) project, I have a few questions that I was hoping you guys could help me with.
1. Power.
a) Would I be able to use the same cable from the battery as the one for the amp? The amp's cable has a 60amp fuse at both ends, and I think is 4 Guage. The amp is never used at full volume (all of the gains on the amp are always set under 1/2).
b) If I can't use the same cable, how would I go about wiring this? Another cable running up the same side of the car as the amp's power cable from the battery?
c) Is this power supply sufficient to power all of the USB devices I listed (and probably more)? Is there a better one I should look at for powering this many devices? and..
d) From what I read, it sounds like I need to power the screen from the power supply.
e) Would I be better off just getting something like
this and getting a "real" power supply + have the ability to plug in normal devices like powered USB hubs? Or will this break something?
2. GPS and other receivers.
a) This BU-353 device seems so much cheaper than most devices. Does anyone know if it work properly in Australia?
b) Does the window interfere with Wireless (3g) internet, 802.11b/g and bluetooth, or can all of these be mounted on the parcel rack?
3. Screen/mounting.
I haven't really decided on the screen. Ideally I'd like a single DIN one which is my only option where I won't have to cut up the plastic around the head unit. The forum seems to be littered with problems with the only one on the store here (the Zenarc), and since I live in Australia I don't really want to have to ship anything back to the US. My budget for the screen would max out at $400-500 usd.
So does anyone have any suggestions? Ebay seems to have some on sale cheap, which says it's model is HF0701A (ebay is pretty much the only google result for that). Anyone have any info on this, or any other in dash (preferably single DIN) VGA touch screens?
Short of this, I guess I'll try to cut my headunit panel thing to fit double DIN and get one of the brackets for Lilliput displays off eBay. I'd much prefer not to do this.
4. Am I doing anything stupid/wrong? Any suggestions for my list are welcome, as well as any cables I'm likely to forget. Standard USB cables etc are no problem, but I don't want to have to reorder cables over the net while my car's in pieces and would prefer not to pull it apart twice (it's still not fully assembled from putting the stereo in).
Thanks in advance for any input.
sckeLL.
